  4. Carpuride 702BS
Carpuride 702BS
14 Posts 9 Posters 3.6k Views 4 Watching
  • Neil Hinkinsundefined Offline
    Neil Hinkins
    Has anyone tried the Carpuride 701BS with MRA on a BMW gs
    Im trying to find out what the funtions are as in can you scroll the map in and out and clear down way points with the multi funtion wheel.
    Brian Sprottundefined Marius Grossundefined 2 Replies Last reply
    • Nick Carthewundefined Nick Carthew moved this topic from General Discussion on
    • Jörgenundefined Offline
      @Neil-Hinkins Hi, there are lot of discussions about Carpuride in this forum, try to use the search function.
      Her a starter: https://www.youtube.com/watch?v=_HX4-t5BZlM
      Leslie Barnesundefined 1 Reply Last reply
      • Neil Hinkinsundefined Neil Hinkins
        Brian Sprottundefined Offline
        Brian Sprott
        @Neil-Hinkins I have it Neil. You can zoom in and out on Apple Carplay but NOT currently on Android. It works perfectly by scrolling through the various options. It doesnt just zoom by scrolling the wheel. You have to scroll to the "+" or "-" and select from there. It is well worth it if you have Carplay IMO
        Neil Hinkinsundefined 1 Reply Last reply
          Marius Grossundefined Offline
          Marius Gross
          @Neil-Hinkins: I can confirm what Brian said. I recently tested the 702 BS with MRA and found that the zoom "+" or "-" does not work on Android. This is exactly why I bought the Carpuride, but I was not aware that this function does not work. I hope that a solution will be found soon.
          Neil Hinkinsundefined bluetuzundefined 2 Replies Last reply
          • Brian Sprottundefined Brian Sprott
            Neil Hinkins
            @Brian-Sprott Thank you for your answer it's exactly what I wanted to know.
            • Marius Grossundefined Marius Gross
              Neil Hinkins
              @Marius-Gross Thank you for your reply.
                bluetuzundefined Offline
                bluetuz
                @Marius-Gross I can confirm too. It is posible to zoom in CarPlay but not in Android Auto. Tested in both OS today
                • Fridjofundefined Offline
                  Fridjof
                  is there a schedule for the fix available?
                  best regards
                  • Jörgenundefined Jörgen
                    Leslie Barnesundefined Offline
                    Leslie Barnes
                    @Jörgen using google maps i have verbale directions but in MRA not? any suggestions?
                    Leslie
                    • Leslie Barnesundefined Leslie Barnes
                      Leslie
                      @Leslie-Barnes Oh, not directly. There are so many possibilities.
                      Are announcements switched off?
                      • Leslie Barnesundefined Offline
                        Leslie Barnes
                        Zo ver als ik weet alles staat aan
                          M. Schrijverundefined Offline
                          Selecteer een TTS Engine en selecteer een stem. Probeer het dan nog eens.
                          Deze staan nu op "onbekend"
                            Leslie Barnes
                            @M-Schrijver Thank you, that did the trick everything is working great now.
                              @Leslie-Barnes
                              Please show the current Fofo for setting. Thank you 👋
                              iPad 9. Gen iOS 26.4.2/ iPhone 16e iOS 26.4.2/ Navi iPhone Xr iOS 18.7.8 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                              bluetuzundefined
                              bluetuz
                              Brian Sprott
                              Marius Gross
                              Fridjofundefined
                              Fridjof
                              Leslie Barnes
                              Neil Hinkins
                              • Umweltzone in NL vermeiden da das WoMo nur die E4 Plakette hat
                              • INNOVV 2 CarPlay system for BMW
                                BMWBiker58undefined
                                BMWBiker58
                              • New beta! 5.1 (457)
                              • MRA V5.1.0 (458)- Karte nach Anruf verschwunden
                              • bochten classificatie
                                travel-lexwill.cyouundefined
                                travel-lexwill.cyou
                              • Remote Key Action for Waypoint List
                              • Compass with direction
                              • PDF download doesn't use English language
