  3. Difference between route on PC and navigation APP
6 Posts 4 Posters 1.2k Views
  • Steen B. Petersen Offline
    Steen B. Petersen
    Question:
    If I make a route on the PC the way I want it to be, It different when I open it in the navigation app, why? 🙂 🙂Screenshot_20230413_133003_com.myrouteapp.navigation.jpg Billede2.png
    Con Hennekens Nick Carthew 2 Replies Last reply
    • Steen B. Petersen Steen B. Petersen
      Question:
      @Steen-B-Petersen, That's because you made a route using the Open Street Map, while Navigation uses the HERE map. That's bound to have differences, sometimes based on tiny difference in speed calculations.
      Use the HERE map to plan your routes, and adding more shaping points helps too.
        Question:
        Nick Carthew Offline
        @Steen-B-Petersen Like @Con-Hennekens says, plus; for a route of that distance I would add several more route points.
          Steen B. Petersen
          I´ll do at once. Thank´s for your help 🙂
          • Dikke Wim Offline
            Dikke Wim Offline
            Dikke Wim
            @Steen-B-Petersen Zoals de suggestie hierboven: gebruik de Here map én laat via de Toolkit meer (vorm)punten genereren. Op zo'n afstand als jouw route zou ik zeker 90 waypoints willen hebben.
            • Dikke Wim Dikke Wim
              @Wim-Dictus said in Difference between route on PC and navigation APP:
              In itself correct, but this is probably meant more like an A2B route, and not for the beautiful scenery, or the exact following. I would not be frantic for some changes in this route if the purpose is solely to get to the destination.
              Steen B. Petersen
              Steen B. Petersen
              Dikke Wim
              Dikke Wim
              • Welke instelling
                1.1k
              • opslaan naar plantomtom
                chris 18
                chris 18
              • Seizoen sluitingen wegen
                PAT62
                PAT62
              • The slow death of Zumo...
                Thomas Schäfer
                Thomas Schäfer
              • New Zealand Touring Group
              • Rejoining routes
