Difference between route on PC and navigation APP
Question:
If I make a route on the PC the way I want it to be, It different when I open it in the navigation app, why?
Question:
@Steen-B-Petersen, That's because you made a route using the Open Street Map, while Navigation uses the HERE map. That's bound to have differences, sometimes based on tiny difference in speed calculations.
Use the HERE map to plan your routes, and adding more shaping points helps too.
Question:
@Steen-B-Petersen Like @Con-Hennekens says, plus; for a route of that distance I would add several more route points.
Iยดll do at once. Thankยดs for your help
@Steen-B-Petersen Zoals de suggestie hierboven: gebruik de Here map รฉn laat via de Toolkit meer (vorm)punten genereren. Op zo'n afstand als jouw route zou ik zeker 90 waypoints willen hebben.
@Wim-Dictus said in Difference between route on PC and navigation APP:
In itself correct, but this is probably meant more like an A2B route, and not for the beautiful scenery, or the exact following. I would not be frantic for some changes in this route if the purpose is solely to get to the destination.
With your input, this post could be even better ๐
