  3. Connector update
Connector update
18 Posts 12 Posters 3.8k Views 2 Watching
  • Leonm
    Leonm
    Leonm
    When I use export I get a message for connector update, but when i open the downloaded update there is a message that there is already an other version of this product installed. How do i remove the old version of connector? Can't find it in the apps.
    tony kranghand 2 Replies Last reply
    • Leonm Leonm
      tony kranghand
      tony kranghand
      tony kranghand
      @leon-o Hey a have the same problem today for the first time and I don't know how to solved that.
      • daan van de par
        daan van de par
        daan van de par
        the same problem here dont now how to go go on
        • Hans van de Ven MR.MRA
          Hi all, remove the connector and reinstall the new connector
          Nick Vandemoortele 1 Reply Last reply
          • Jim McClintock
            Jim McClintock
            Jim McClintock
            How do you remove the connector? That's the question.
            gary k 1 Reply Last reply
            • Jim McClintock Jim McClintock
              gary k
              gary k
              gary k
              @Jim-McClintock i am having the same problem, can not find out how to remove
                Nick Vandemoortele
                Nick Vandemoortele
                Nick Vandemoortele
                @Hans-van-de-Ven-MRA-Master how to remove the connector?
                • Nick Vandemoortele Nick Vandemoortele
                  gary k
                  gary k
                  gary k
                  @Nick-Vandemoortele thanks Nick for the reply, yes that is what I'm having problems with, is how to remove connector so I can do the updates.
                    Hi all,
                    Via the control panel in windows
                    • Nick Carthew
                      If you are unable to update the connector, perform the following steps:
                      1. Search Windows for Control Panel
                      2. Click on "uninstall a program"
                      3. Find the connector of MyRoute-app
                      4. Right click with your mouse on the MyRoute-app application
                      5. Click on "delete"
                      6. Once the file has been deleted, you can install the new connector from ww.myrouteapp.com or run the file just downloaded.
                        If the above steps do not work, please contact the MyRoute-app support.
                      Helmut Saurer 1 Reply Last reply
                      • Leonm Leonm
                        tony kranghand
                        tony kranghand
                        tony kranghand
                        This post is deleted!
                          Helmut Saurer
                          Helmut Saurer
                          Helmut Saurer
                          wrote on last edited by Helmut Saurer
                          @Nick-Carthew Danke Nick. So funktioniert es.
                          • TorqueRider
                            @jan-thijssen
                            Dag Jan, ik denk dat je gebruikt maakt van de MRA planner app.
                            Die is bedoeld om routes te plannen/maken. Niet om te navigeren en daarom krijg je geen aanwijzingen.
                            • sudolea
                              sudolea
                              sudolea
                              @jan-thijssen Jan, als ik jou vraag goed begreep, vrees ik dat bovenstaand antwoord jou op het verkeerde been zou kunnen zetten. Want de navigatie-stembegeleiding moeten in jouw GPS worden aangezet, daar komt MRA niet in tussen, dit is een instelling in jouw GPS zélf. Dat vereist, uiteraard, een (meestal bluetooth) connectie tussen jouw GPS en jouw helmsysteem.
                              • sudolea sudolea
                                @sudolea said in Connector update:
                                Oeioei. En zo is het. Mijn antwoord slaat nergens op 😞
                                • TorqueRider
                                  • TorqueRider
                                    @jan-thijssen
                                    Met een Gold abonnement krijg je meer functies voor het plannen van jouw routes.
                                    Het heeft geen invloed op de gesproken aanwijzingen van jouw Garmin XT.
                                      @jan-thijssen
                                      Jan als je de route start op het startpunt krijg je dan wel aanwijzingen?
                                      sudolea
                                      sudolea
                                      Nick Vandemoortele
                                      Nick Vandemoortele
                                      Helmut Saurer
                                      Helmut Saurer
                                      tony kranghand
                                      tony kranghand
                                      gary k
                                      gary k
                                      Jim McClintock
                                      Jim McClintock
                                      daan van de par
                                      daan van de par
                                      Leonm
                                      Leonm
                                        Glenn.B
                                        Glenn.B
                                        3.7k
                                        Robineke
                                        Robineke
                                      • Overlay Routes like the App does and waypoints without routes
                                        Rob Kelley
                                        Rob Kelley
                                      • How to plan correctly
                                      • Brittany routes
                                        Tony 13
                                        Tony 13
                                      • Slow Favorites
