  3. Connector update
Connector update
18 Posts 12 Posters 2.2k Views 2 Watching
  • Leonmundefined Offline
    Leonm
    When I use export I get a message for connector update, but when i open the downloaded update there is a message that there is already an other version of this product installed. How do i remove the old version of connector? Can't find it in the apps.
    tony kranghandundefined 2 Replies Last reply
    • Leonmundefined Leonm
      tony kranghandundefined Offline
      tony kranghand
      @leon-o Hey a have the same problem today for the first time and I don't know how to solved that.
      • daan van de parundefined Offline
        daan van de par
        the same problem here dont now how to go go on
        • Hans van de Ven MR.MRAundefined Online
          Hi all, remove the connector and reinstall the new connector
          Nick Vandemoorteleundefined 1 Reply Last reply
          • Jim McClintockundefined Offline
            Jim McClintock
            How do you remove the connector? That's the question.
            gary kundefined 1 Reply Last reply
            • Jim McClintockundefined Jim McClintock
              gary kundefined Offline
              gary k
              @Jim-McClintock i am having the same problem, can not find out how to remove
                Nick Vandemoorteleundefined Offline
                Nick Vandemoortele
                @Hans-van-de-Ven-MRA-Master how to remove the connector?
                • Nick Vandemoorteleundefined Nick Vandemoortele
                  gary k
                  @Nick-Vandemoortele thanks Nick for the reply, yes that is what I'm having problems with, is how to remove connector so I can do the updates.
                    Hi all,
                    Via the control panel in windows
                      If you are unable to update the connector, perform the following steps:
                      1. Search Windows for Control Panel
                      2. Click on "uninstall a program"
                      3. Find the connector of MyRoute-app
                      4. Right click with your mouse on the MyRoute-app application
                      5. Click on "delete"
                      6. Once the file has been deleted, you can install the new connector from ww.myrouteapp.com or run the file just downloaded.
                        If the above steps do not work, please contact the MyRoute-app support.
                      Helmut Saurerundefined 1 Reply Last reply
                        tony kranghand
                          Helmut Saurerundefined Offline
                          Helmut Saurer
                          wrote on last edited by Helmut Saurer
                          @Nick-Carthew Danke Nick. So funktioniert es.
                            Jack van Tilburg
                            @jan-thijssen
                            Dag Jan, ik denk dat je gebruikt maakt van de MRA planner app.
                            Die is bedoeld om routes te plannen/maken. Niet om te navigeren en daarom krijg je geen aanwijzingen.
                            • sudoleaundefined Offline
                              sudolea
                              @jan-thijssen Jan, als ik jou vraag goed begreep, vrees ik dat bovenstaand antwoord jou op het verkeerde been zou kunnen zetten. Want de navigatie-stembegeleiding moeten in jouw GPS worden aangezet, daar komt MRA niet in tussen, dit is een instelling in jouw GPS zélf. Dat vereist, uiteraard, een (meestal bluetooth) connectie tussen jouw GPS en jouw helmsysteem.
                              • sudoleaundefined sudolea
                                Jack van Tilburg
                                @sudolea said in Connector update:
                                Oeioei. En zo is het. Mijn antwoord slaat nergens op 😞
                                  Jack van Tilburg
                                    Jack van Tilburg
                                    @jan-thijssen
                                    Met een Gold abonnement krijg je meer functies voor het plannen van jouw routes.
                                    Het heeft geen invloed op de gesproken aanwijzingen van jouw Garmin XT.
                                      @jan-thijssen
                                      Jan als je de route start op het startpunt krijg je dan wel aanwijzingen?
                                      Jack van Tilburg
                                      sudoleaundefined
                                      sudolea
                                      Nick Vandemoortele
                                      Helmut Saurer
                                      tony kranghand
                                      gary kundefined
                                      gary k
                                      Jim McClintock
                                      daan van de par
                                      Leonmundefined
                                      Leonm
                                        973
                                      • batterij verbruik
                                        CD130undefined
                                      • Flitsmeister
                                      • In bibliotheek: rondrit vs route optie
                                      • Carpuride
                                        guenniguenzelsenundefined
                                        guenniguenzelsen
                                      • WEB-version of From-To, heavily curved, avoid highway
                                      • GPS positie freeze
                                        Mark Vroomenundefined
                                        Mark Vroomen
