  3. Connector update
Connector update
18 Posts 12 Posters 4.4k Views 2 Watching
  • daan van de par
    daan van de par
    daan van de par
    the same problem here dont now how to go go on
    • HABVEN aka MrMRA
      Hi all, remove the connector and reinstall the new connector
      Nick Vandemoortele 1 Reply Last reply
      • Jim McClintock
        Jim McClintock
        Jim McClintock
        How do you remove the connector? That's the question.
        gary k 1 Reply Last reply
        • Jim McClintock Jim McClintock
          gary k
          gary k
          gary k
          @Jim-McClintock i am having the same problem, can not find out how to remove
            Nick Vandemoortele
            Nick Vandemoortele
            Nick Vandemoortele
            @Hans-van-de-Ven-MRA-Master how to remove the connector?
            • Nick Vandemoortele Nick Vandemoortele
              gary k
              gary k
              gary k
              @Nick-Vandemoortele thanks Nick for the reply, yes that is what I'm having problems with, is how to remove connector so I can do the updates.
              • HABVEN aka MrMRA
                Hi all,
                Via the control panel in windows
                • Nick Carthew
                  If you are unable to update the connector, perform the following steps:
                  1. Search Windows for Control Panel
                  2. Click on "uninstall a program"
                  3. Find the connector of MyRoute-app
                  4. Right click with your mouse on the MyRoute-app application
                  5. Click on "delete"
                  6. Once the file has been deleted, you can install the new connector from ww.myrouteapp.com or run the file just downloaded.
                    If the above steps do not work, please contact the MyRoute-app support.
                  Helmut Saurer 1 Reply Last reply
                  • Leonm Leonm
                    When I use export I get a message for connector update, but when i open the downloaded update there is a message that there is already an other version of this product installed. How do i remove the old version of connector? Can't find it in the apps.
                    tony kranghand
                    tony kranghand
                    tony kranghand
                      Helmut Saurer
                      Helmut Saurer
                      Helmut Saurer
                      wrote on last edited by Helmut Saurer
                      @Nick-Carthew Danke Nick. So funktioniert es.
                      • TorqueRider
                        @jan-thijssen
                        Dag Jan, ik denk dat je gebruikt maakt van de MRA planner app.
                        Die is bedoeld om routes te plannen/maken. Niet om te navigeren en daarom krijg je geen aanwijzingen.
                        • sudolea
                          sudolea
                          sudolea
                          @jan-thijssen Jan, als ik jou vraag goed begreep, vrees ik dat bovenstaand antwoord jou op het verkeerde been zou kunnen zetten. Want de navigatie-stembegeleiding moeten in jouw GPS worden aangezet, daar komt MRA niet in tussen, dit is een instelling in jouw GPS zélf. Dat vereist, uiteraard, een (meestal bluetooth) connectie tussen jouw GPS en jouw helmsysteem.
                          • sudolea sudolea
                            @sudolea said in Connector update:
                            Oeioei. En zo is het. Mijn antwoord slaat nergens op 😞
                            • TorqueRider
                              • TorqueRider
                                @jan-thijssen
                                Met een Gold abonnement krijg je meer functies voor het plannen van jouw routes.
                                Het heeft geen invloed op de gesproken aanwijzingen van jouw Garmin XT.
                                • HABVEN aka MrMRA
                                  @jan-thijssen
                                  Jan als je de route start op het startpunt krijg je dan wel aanwijzingen?
                                  sudolea
                                  sudolea
                                  Nick Vandemoortele
                                  Nick Vandemoortele
                                  Helmut Saurer
                                  Helmut Saurer
                                  tony kranghand
                                  tony kranghand
                                  gary k
                                  gary k
                                  Jim McClintock
                                  Jim McClintock
                                  daan van de par
                                  daan van de par
                                  Leonm
                                  Leonm
                                  • Newsletter optimisation
                                  • How can I change colours in the route overview?
                                    Kudee
                                    Kudee
                                  • Next: Ich brauche Hilfe zu POI und Favoriten!
                                  • MRA AI Routeplanner - Improvement
                                  • route aanklikken in overzichtskaart
                                  • Walking route options
