  4. Since upgrade Quick Route seems locked in scenic
scenic lockquick route
4 Posts 3 Posters 1.1k Views 2 Watching
  • David Gillies
    David Gillies
    David Gillies
    Hi I am a relatively new user (Gold) and recently attended an excellent Webex.
    Since upgrading to the latest version on my IPhone I seem to be having an issue with Quick routing selecting motorways in the UK using the App.
    When I go into the App.
    If I am in a location away from home I select my favourite of home (I have tried Car and Motorbike routing option).
    This seems to default to Scenic as a routing option. I have no other options either in Car or Motorbike.
    If I go in to select the options I notice Highway
    option is off. Selecting this seems to make zero difference to routing.
    The app will calculate a rote fro where I am but refuses to select any motorways even if the shortest and quickest from where I am.
    I have tried the route planner option and selecting where I am and adding as a first waypoint and selecting my home favourite as my next and it will use motorways perfectly but it is a bit frustrating having to always create a route rather than just select from the landing page.
    Is it just me or a known issue ?
    Marinus van Deudekom Rob Verhoeff 2 Replies Last reply
    • David Gillies David Gillies
      @David-Gillies i'm quite sure it's in your settings.
      Could you share screenshots of the settings
        @David-Gillies I suspect you are making a mistaken assumption. When you select a favourite, you will see this image at the bottom of your screen...
        It may look as though Scenic is selected because the button is highlighted in yellow; however, this is not the case. If you tap Navigate directly from this screen, the navigation will guide you to your destination via the fastest route — including motorways. If you tap Scenic, you can then choose which types of roads the navigation should avoid.
        I believe it works as designed. If that is not the intended usecase, then I must have misunderstood your question.
        David Gillies 1 Reply Last reply
          David Gillies
          David Gillies
          David Gillies
          @Rob-Verhoeff Hi Rob fabulous thanks so much your 100% correct user error !! So sorry your suggestion worked perfect problem solved thanks so much.
          David Gillies
          David Gillies
            Alderweireld Rudi 0
            Alderweireld Rudi 0
          • Weather as a service
            Andy Smith 5
            Andy Smith 5
          • Lane view in Android Auto
            denWINNE
            denWINNE
