somewhat new to MRA, but have done research on this forum
Surely the functionality to do this exists -
All you have to do is upload the POIs into a named folder you create,e.g 'MyPOIs' and then on this screen select the group and select box Move at the bottom
and there is an option to select favourites
John
@John-Matthews-0 You are offering a solution from the BETA website. The question has been asked in the classic website section of the forum. Please do not confuse the two.
Apology - I did, but at least the user now can see what is coming ...
John
ok, and Yes I am a MRA next lifetime user, so not sure if I have to pay the upgrade fee.
and yes I was thining about going ahead and moving to the beta now. I live in Atlanta, GA and riding season is not 100% over, but for the most part I put my bike away Dec 15 - Feb 15 and do maintenance etc. I also do a lot of my route work in those "dead months" I need to determine if I need to pay the upgrade
might do that this week and get a head start -
@randy-etheridge my question would be why do you want 500 points as favourites
500 favourites is a lot of general pointswould it not be more useful to split the 500 points into categories & then upload each category set to MRA
you could then enable/disable viewing each category type depending on what topic/category you were interested at the time@BMcG so interesting that you think 500 favorites is a lot.
but in simple terms in Basecamp when I try to create a route ALL points are visual on the Map.I maybe incorrect, but currently in MRA classic, not BETA POI are only visible I think at 10KL. I need my view way farther out than that. usually around 60KL.
so having items as POI, at least in classic has not worked for me. I am rarely at a 10KL view, so POI do not show.
Again I am very new to MRA, I am a BaseCamp 15 year veteran. I have taught classes on Basecamp. But I recently started riding with some new riders and they only use MRA phone app. While I still have a Garmin XT. So in order for them to have the route, I currently build all my routes in Basecamp and then export and then import into MRA. actually works very well, and the other riders appreciate the effort.
Over the winter months I want to learn more about MRA. Hence this starting question.
I do understand the POI as specific groups, i.e. restaurants, gas stations, roads, scenic view etc. And maybe I need to adjust the way I work, but for me, I tend to work in large areas, So I want all restaurants, gas stations, roads, scenic stops etc say in a 60 mile radius of XYZ location, then I want all the same items in another 60 mile radius of location ABC, etc.
90% of my riding, is trailering to a location say, Canaan Valley, WV and then riding that area for a week, then will trailer to Gunnison, CO and ride that are for a week, then Red Lodge,MT etc.
so the idea of POI in large groups, at this point does not really work for me. But again maybe I just need to rethink how I work.
Like I said I am learning
might do that this week and get a head startok, and Yes I am a MRA next lifetime user, so not sure if I have to pay the upgrade fee.
you will not have to, 15 February you get upgraded.
you could then enable/disable viewing each category type depending on what topic/category you were interested at the time@randy-etheridge my question would be why do you want 500 points as favourites
you could then enable/disable viewing each category type depending on what topic/category you were interested at the time500 is peanuts...
I try to load the Michelin Restaurant GPI file into my browser...
Went out of memory
@randy-etheridge I was trying to imply 500 is a lot of "favourites" especially for one area
of course you can have hundred/thousands/millions of POI but if they are not relevant to the category or area your looking at the number is pretty pointless& yes the fact that poi do not appear in MRA till zoomed in is a bit of a bug bear
personal/marked POI's appear at 10km can be a pain but even more painful is the selected categories in the MRA POI library do not appear till 1 km
the idea is to try & not over clutter the mapI do not know how the new Beta planner handles POI but I do know it has be hugely changed
I had also numerous POI's/waypoints in Basecamp. I had them organized in folders. To convert them to MRA, i saved the folders one by one .GPX files and gave the filename the name of the folder. For instance I had a folder "Alpes" and in that folder a subfolder "Passes" and "Tunnels" and some more. The first folder I saved with the filename "Alpes Passes.GPX", the second "Alpes Tunnels.GPX" etc. etc. etc.
I uploaded these files to the Poi section library in MRA and I had al of my "special points" organized in the same why as in Basecamp. To activate or deactivate the points on the map use the eye-symbol before the filename.
I am now lazy lying on the couch and therefore not able to show a printscreen, but I think this direction can help you. -
Thank you. Yes, basically I’m doing exactly what you’re doing as far as bringing the POI data in
Has someone noted in the post above the problem is you have to zoom into 10 km, I think it is for any POI to be viewable
And for the most part, that just does not work for the way I build routes
But as that same poster noted, who knows what February 15 will bring
I will wait and see -
This part got me thinking.....
What if you have a large collection of POI all in one file and you want certain POI's along your route.
I tried with Overpass API to get it out of Openstreetmap, but that is not very stable and unpredictable
Also the way @travellexxie uses is what I use in MRA now, because of the design inside MRA.As a Garmin user I find the export and import of GPX routes into MRA difficult: You can import a route and loose the POI and then have to transfer them into your route one by one from a POI Libary you have to import separte. And because MRA has only the description field, you sometime loose info that was in your imported GPX file.
So I made my own Poi Editor ( It is in the Forum routes section).
But back to the above Quote.
Some body asked me if I could make a search and replace function for POI and was busy doing that, when the above came around.. So what if ???We have 2 POI options:
- One big file of POI's
- Different folders with POI's in category
And we have a MRA Route/track/POI or we have some track downloaded we want to use.
We want all the public Loo's along the route and the restaurants within a 5 km range because of old age and a bladder problem....
So @randy-etheridge just came along and got me thinking.
I have my application that can search/edit POI's, read GPX/KML and has a part that is not working properly and POI's in my collection.
So I asked my AI friend.. what if we make something that searches selected POI along the track in a range we can change and add the POI to the track layer so the User can edit and save this together with the track in a file that he can share with his friends with different Navigation programs.
My program is written a little around the Garmin POI as I have a Edge for Cycling and some Outdoor stuff for walking in the mountains (Zumo is bricked some time ago..)This is wat "we" made:
01 MRA route/track/poi exported as GPX 1.1 Via points, shaping points and POI are read into the WEB application
- 02 One or more GPX files are also loaded into the application, read, and listed.*
- 03 The selection can be edited, changed, POI added and deleted. After this the file with track can be saved as merged file or the POI can be saved as a Garmin GPI file to use inside Garmin devices*
- File loaded into Basecamp, Symbols know to Garmin will display*
** * Disclamer: before somebody responses "wait until after the BETA.." : this is a hobby project just for the fun of doing.*
