  4. Approximately how long should it take to synchronize all routes?
15 Posts 6 Posters 348 Views 4 Watching
  • Brett Bartick
    Brett Bartick
    Brett Bartick
    It's been hours and the counter hasn't changed. Seems like a bug to me. Is there a route limit? I'm not even sure that route count is accurate. But I will say that I usually create a route-track for each route. So, I'm guessing that counts as two routes?
    For all those on a ride, I salute you!
    2011 FLHTCU
    1993 FLSTF
    2014 Aspen Sentry
    2001 Bushtec Turbo-II
    • Brett Bartick Brett Bartick
      @Brett-Bartick Try turning your phone off completely and then try syncing again.
      Brett Bartick 1 Reply Last reply
        Brett Bartick
        Brett Bartick
        Brett Bartick
        Didn't work. Still stuck at 2168 remaining.
        Maybe this issue/bug is similar to a route search, that only goes 3 levels deep. 😠
        2011 FLHTCU
        1993 FLSTF
        2014 Aspen Sentry
          @Brett-Bartick, no I don't think so, I also have more levels than three. Actually I needed to do a storage deletion on the V6 beta app, and it struck me how much faster syncing works than in the (for me by now) "old" app. So improvement is on its way 😉
          • StanisÅ‚aw
            Perhaps an additional switch to synchronise routes more recent than X days/months/etc. since the last edit would be a good solution. I don't think there's any reason to have very old routes on my phone. When I plan to use an old folder, I could synchronise it manually.
            Staszek
            • StanisÅ‚aw StanisÅ‚aw
              @Stanisław, You can still sync routes and folders manually, but I really would not recommend that. Syncing only takes some time at first try, if you have many routes. After that it just keeps everything equal blindingly fast.
              • StanisÅ‚aw
                wrote last edited by Stanisław
                Of course but when someone has 3000 router in his library, could synchronise only 250 from last year and every new created later, without waiting hours for old routes synchro.
                Just an idea, not a problem for me.
                Staszek
                  @Stanisław, certainly not a bad idea! 😉 Who knows, maybe it will be picked up by the team.
                    Customer support was able to assist.
                    As of version 6 one route cannot block the entire sync.
                    • Brett Bartick
                      Brett Bartick
                      Brett Bartick
                      Yes, customer support is working on this! A fix was implemented, but the sync now gets stuck at 1083 remaining. I've uploaded new logs to customer support to further investigate.
                      2011 FLHTCU
                      1993 FLSTF
                      2014 Aspen Sentry
                      • Brett Bartick
                        Brett Bartick
                        Brett Bartick
                        wrote last edited by Brett Bartick
                        The issue has been resolved successfully and quickly! Synchronization of all my routes (2000+) finishes without any problems.
                        2011 FLHTCU
                        1993 FLSTF
                        2014 Aspen Sentry
                          Brett Bartick
                          Brett Bartick
                          • Download club route folders
                            Ã’scar
                            Ã’scar
                          • Passwords
                          • Live tracking problem on Android tablet
