  4. Approximately how long should it take to synchronize all routes?
15 Posts 6 Posters 1.2k Views 4 Watching
  • Brett Bartick
    Brett Bartick
    Brett Bartick
    I tried to "Sync all my routes". The process seems to be running for a few days. How can I check the progress?
    For all those on a ride, I salute you!
    2011 FLHTCU
    1993 FLSTF
    2014 Aspen Sentry
    2001 Bushtec Turbo-II
    • MotoCon
      I'd say: here?
      That's a lot of routes you have though...
      BMcG 1 Reply Last reply
        I'd say: here?
        @MotoCon you call that a lot 😂 😂 😂
        @brett-bartick I have come across this too, some days the sync can be quite rapid, the route sync counter literally flies through, other times it can be almost glacial, like 1 route sync per second
        I have never worked out a reason why & just put it down the web pipes congested (servers being busy)
        • Brett Bartick
          Brett Bartick
          Brett Bartick
          It's been hours and the counter hasn't changed. Seems like a bug to me. Is there a route limit? I'm not even sure that route count is accurate. But I will say that I usually create a route-track for each route. So, I'm guessing that counts as two routes?
          2011 FLHTCU
          1993 FLSTF
          2014 Aspen Sentry
          • Brett Bartick Brett Bartick
            @Brett-Bartick Try turning your phone off completely and then try syncing again.
            Brett Bartick 1 Reply Last reply
              Brett Bartick
              Brett Bartick
              Brett Bartick
              Didn't work. Still stuck at 2168 remaining.
              Maybe this issue/bug is similar to a route search, that only goes 3 levels deep. 😠
              2011 FLHTCU
              1993 FLSTF
              2014 Aspen Sentry
                @Brett-Bartick, no I don't think so, I also have more levels than three. Actually I needed to do a storage deletion on the V6 beta app, and it struck me how much faster syncing works than in the (for me by now) "old" app. So improvement is on its way 😉
                • Stanisław
                  Perhaps an additional switch to synchronise routes more recent than X days/months/etc. since the last edit would be a good solution. I don't think there's any reason to have very old routes on my phone. When I plan to use an old folder, I could synchronise it manually.
                  Staszek
                  • Stanisław Stanisław
                    @Stanisław, You can still sync routes and folders manually, but I really would not recommend that. Syncing only takes some time at first try, if you have many routes. After that it just keeps everything equal blindingly fast.
                    • Stanisław
                      wrote last edited by Stanisław
                      Of course but when someone has 3000 router in his library, could synchronise only 250 from last year and every new created later, without waiting hours for old routes synchro.
                      Just an idea, not a problem for me.
                      Staszek
                        @Stanisław, certainly not a bad idea! 😉 Who knows, maybe it will be picked up by the team.
                          Customer support was able to assist.
                          As of version 6 one route cannot block the entire sync.
                          • Brett Bartick
                            Brett Bartick
                            Brett Bartick
                            Yes, customer support is working on this! A fix was implemented, but the sync now gets stuck at 1083 remaining. I've uploaded new logs to customer support to further investigate.
                            2011 FLHTCU
                            1993 FLSTF
                            2014 Aspen Sentry
                            • Brett Bartick
                              Brett Bartick
                              Brett Bartick
                              wrote last edited by Brett Bartick
                              The issue has been resolved successfully and quickly! Synchronization of all my routes (2000+) finishes without any problems.
                              2011 FLHTCU
                              1993 FLSTF
                              2014 Aspen Sentry
                                Brett Bartick
                                Brett Bartick
                                  guenniguenzelsen
                                  guenniguenzelsen
                                  TomOnTour
                                  TomOnTour
                                • vrienden toevoegen
                                • [TIP] Oplossing voor wegvallende verbinding (Android Auto / CarPlay) & dubbele lijnen in MyRoute-app op Carpuride
                                • Nieuwe route delen met oude versie rijden
                                • Are all HERE maps dark-themed?
