  4. Roads not appearing in Navigation app
5 Posts 4 Posters 218 Views 3 Watching
  • Matt Anderson 0
    Matt Anderson 0
    Matt Anderson 0
    Hi all, I am a user from the United States. I am using this to plan and make bus routes for the school I work at. I use the app to help me navigate the 16 different bus routes I must drive when a driver is sick. On several routes I have created the navigation app is not updated for the area I live in and does not show a road that is connected in real life. It redirects me around in the navigation app and It gets kinda of confusing. I have used this app to create the bus stops as well. I am looking for some other help as...
    Is there a better device to use then my Iphone for the app?
    Is there a way to make suggestions on updating the roads in my area?
    I am a paying subscriber as I see the benefit of this app for my job. I appreciate the work that has gone into the app. I also understand that this app may be better suited for other regions around the world vs where I live. I just would like to help improve my area. Any help would be appreciated.
    Nick Carthew Brian McG 2 Replies Last reply
    • Matt Anderson 0 Matt Anderson 0
      @Matt-Anderson-0 HERE map errors or missing roads can be reported using this website: https://mapfeedback.here.com/#/report
        Hi @Matt-Anderson-0
        if roads are missing or incorrect in your area it could be a long time before Here actually get around to updating or correcting the errors (the maps used by MRA are based on maps by the mapping company Here)
        the quickest way to get any errors or omissions fixed is to edit / fix / add the data to the Here map yourself
        if you go to Here maps editor & create an account you can edit the map
        it may take some time for any changes you make to be approved by Here & then another length of time before they propagate to the underlying map used by MRA i.e. this wont happen fast especially if it is a big change / update
        but it will happen faster than if you wait for someone else or Here to get around to doing the updates
        Matt Anderson 0 1 Reply Last reply
        • Brian McG Brian McG
          Hi @Matt-Anderson-0
          Matt Anderson 0
          Matt Anderson 0
          Matt Anderson 0
          @Brian-McG Thankyou for the response. The Here maps editor seems clunky, but i will try it out.
            @Matt-Anderson-0 Personally, I always send an email to this address and describe the problem... They always reply and try to help me.
            appsupport@here.com
            BMW R 1250 GS
            DMD-NOR7E 7"
            SPC Universal mount
            Motorola Edge 40 "offline"
            Sena SLR 3
            Sena 50 R
            Matt Anderson 0
            Matt Anderson 0
            • Lock route editing
              OGRIII
              OGRIII
            • Bug with Avatar on profile
