<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Roads not appearing in Navigation app]]></title><description><![CDATA[<p dir="auto">Hi all, I am a user from the United States. I am using this to plan and make bus routes for the school I work at. I use the app to help me navigate the 16 different bus routes I must drive when a driver is sick. On several routes I have created the navigation app is not updated for the area I live in and does not show a road that is connected in real life. It redirects me around in the navigation app and It gets kinda of confusing. I have used this app to create the bus stops as well. I am looking for some other help as...</p>
<p dir="auto">Is there a better device to use then my Iphone for the app?<br />
Is there a way to make suggestions on updating the roads in my area?</p>
<p dir="auto">I am a paying subscriber as I see the benefit of this app for my job. I appreciate the work that has gone into the app. I also understand that this app may be better suited for other regions around the world vs where I live. I just would like to help improve my area. Any help would be appreciated.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11866/roads-not-appearing-in-navigation-app</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 20:20:30 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11866.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Oct 2026 13:07:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Roads not appearing in Navigation app on Fri, 16 Oct 2026 18:40:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/matt-anderson-0" aria-label="Profile: Matt-Anderson-0">@<bdi>Matt-Anderson-0</bdi></a><br />
if roads are missing or incorrect in your area it could be a long time before Here actually get around to updating or correcting the errors (the maps used by MRA are based on maps by the mapping company Here)</p>
<p dir="auto">the quickest way to get any errors or omissions fixed is to edit / fix / add the data to the Here map yourself<br />
if you go to <a href="https://mapcreator.here.com/" rel="nofollow ugc">Here maps editor</a> &amp; create an account you can edit the map</p>
<p dir="auto">it may take some time for any changes you make to be approved by Here &amp; then another length of time before they propagate to the underlying map used by MRA i.e. this wont happen fast especially if it is a big change / update</p>
<p dir="auto">but it will happen faster than if you wait for someone else or Here to get around to doing the updates</p>
]]></description><link>https://forum.myrouteapp.com/post/85337</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/85337</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Fri, 16 Oct 2026 18:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to Roads not appearing in Navigation app on Fri, 16 Oct 2026 15:58:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matt-anderson-0" aria-label="Profile: Matt-Anderson-0">@<bdi>Matt-Anderson-0</bdi></a> HERE map errors or missing roads can be reported using this website: <a href="https://mapfeedback.here.com/#/report" rel="nofollow ugc">https://mapfeedback.here.com/#/report</a></p>
]]></description><link>https://forum.myrouteapp.com/post/85323</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/85323</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Fri, 16 Oct 2026 15:58:08 GMT</pubDate></item></channel></rss>
