Tracklog correction
I have a tracklog of a ride I have done. Unfortunately the first part of this tour is missing. Is there a way to edit an existing tracklog in order to get a correct tracklog of my tour?
The part where you see a straight line was not tracked properly. This is the part I would like to edit.
@Christian-Feurstein have you checked the track Log files
If its not there you can't get it back -
What exactly do you mean by checking tracklog files? After the ride I safed the tracklog and it was successfully uploaded. When looking into the stored tracklogs I found the showed tracklog with the first part missing. Where else do I find tracklog files?
This indeed cannot be corrected unfortunately.
There is a possibility outside MRA. With a GPX editor, a .gpx file with the missing part and some manual work. Is it worth doing?
@Christian-Feurstein next Idea to edit your tracklog:
- open it by MRA Routeplanner
- select in Menue: use it as route
- delete unnecessary route points (or move some)
- save as gpx track
- upload saved gpx file again in your folder Tracklogs as track
By this, you don't need an external gpx tool
- save as gpx track
- save as gpx track
What about the missing part?
- save as gpx track
@Guzzist
Thanks … I will try this once I am back at home!
