  4. Tracklog correction
Tracklog correction
7 Posts 5 Posters 129 Views 4 Watching
  • Christian Feurstein Offline
    Christian Feurstein
    wrote last edited by Christian Feurstein
    I have a tracklog of a ride I have done. Unfortunately the first part of this tour is missing. Is there a way to edit an existing tracklog in order to get a correct tracklog of my tour?
    The part where you see a straight line was not tracked properly. This is the part I would like to edit.
    • Christian Feurstein Christian Feurstein
      Marinus van Deudekom Offline
      @Christian-Feurstein have you checked the track Log files
      If its not there you can't get it back
        Christian Feurstein
        What exactly do you mean by checking tracklog files? After the ride I safed the tracklog and it was successfully uploaded. When looking into the stored tracklogs I found the showed tracklog with the first part missing. Where else do I find tracklog files?
        Guzzist 1 Reply Last reply
        • Corjan Meijerink Offline
          This indeed cannot be corrected unfortunately.
          • Jörgen Online
            Jörgen Online
            There is a possibility outside MRA. With a GPX editor, a .gpx file with the missing part and some manual work. Is it worth doing?
              Guzzist Online
              Guzzist Online
              @Christian-Feurstein next Idea to edit your tracklog:
              • open it by MRA Routeplanner
              • select in Menue: use it as route
              • delete unnecessary route points (or move some)
              • save as gpx track
              • upload saved gpx file again in your folder Tracklogs as track
                By this, you don't need an external gpx tool 😉
              Jörgen 1 Reply Last reply
              • Guzzist Guzzist
                • save as gpx track
                Jörgen Online
                Jörgen Online
                @Guzzist sagte:
                • save as gpx track
                What about the missing part?
                Christian Feurstein
                Christian Feurstein
                • Tracklog correction
                • Google maps and Streetview
                • Wegomleiding
