  4. Tracklog correction
Tracklog correction
9 Posts 5 Posters 839 Views 4 Watching
  • Christian Feurstein
    Christian Feurstein
    Christian Feurstein
    wrote on last edited by Christian Feurstein
    I have a tracklog of a ride I have done. Unfortunately the first part of this tour is missing. Is there a way to edit an existing tracklog in order to get a correct tracklog of my tour?
    The part where you see a straight line was not tracked properly. This is the part I would like to edit.
    • Christian Feurstein Christian Feurstein
      @Christian-Feurstein have you checked the track Log files
      If its not there you can't get it back
        Christian Feurstein
        Christian Feurstein
        What exactly do you mean by checking tracklog files? After the ride I safed the tracklog and it was successfully uploaded. When looking into the stored tracklogs I found the showed tracklog with the first part missing. Where else do I find tracklog files?
        Guzzist 1 Reply Last reply
          This indeed cannot be corrected unfortunately.
            There is a possibility outside MRA. With a GPX editor, a .gpx file with the missing part and some manual work. Is it worth doing?
              @Christian-Feurstein next Idea to edit your tracklog:
              • open it by MRA Routeplanner
              • select in Menue: use it as route
              • delete unnecessary route points (or move some)
              • save as gpx track
              • upload saved gpx file again in your folder Tracklogs as track
                By this, you don't need an external gpx tool 😉
              Jörgen Christian Feurstein 2 Replies Last reply
              • Guzzist Guzzist
                • save as gpx track
                @Guzzist sagte:
                • save as gpx track
                What about the missing part?
                • Guzzist Guzzist
                  • save as gpx track
                  Christian Feurstein
                  Christian Feurstein
                  Christian Feurstein
                  @Guzzist
                  Thanks … I will try this once I am back at home! 👍🏻
                    @Guzzist sagte:
                    • save as gpx track
                    @Jörgen said:
                    @Guzzist sagte:
                    • save as gpx track
                    ...that's the weak point: you need to be able to remember the route you’ve taken. Then, once you’ve turned the track into a route, you can add the relevant waypoints. And then, as mentioned, save it as a track again.
                    Christian Feurstein
                    Christian Feurstein
                    • Lock route editing
                      OGRIII
                      OGRIII
                    • Bug with Avatar on profile
