  4. No navigation instructions
8 Posts 4 Posters 548 Views 2 Watching
  • Hans-Udo Erdmenger Offline
    Hans-Udo Erdmenger
    wrote last edited by Hans-Udo Erdmenger
    Screenshot_20260823-133150.png Yesterday, I followed a route I had planned on my PC using MyRouteApp. While driving (using the route as a track), I received no new navigation instructions; the display remained stuck on the initial instruction. After 10 minutes, I stopped and restarted the navigation. I then received a new instruction, but that one also remained fixed on the screen. Later, I closed and restarted the entire app, but that didn't help either; it continued to show only the first instruction. Throughout this, the arrow moved normally along the route.
    After about two hours—three kilometers before my first waypoint—the system recovered, and everything returned to normal.![Screenshot_20260823-133150.png](/assets/uploads/files/17876582Screenshot_20260823-140445.png Screenshot_20260823-140659.png Screenshot_20260825-133923.png Screenshot_20260825-133953.png 75194-screenshot_20260823-133150-resized.png)
    Brian McG 1 Reply Last reply
    • superg Offline
      superg Offline
      It's look like ( the location arrow isn't pointing the good direction) there is no good GPS-signal.
      • Hans-Udo Erdmenger Hans-Udo Erdmenger
        Brian McG Offline
        Brian McG Offline
        @Hans-Udo-Erdmenger it almost sounds as if the system is driving this route in the opposite direction - "after 2 hours - 3km before my first waypoint" !
        & the distance shown to point 2 seems to have increased from 82km to 139km
        normally when I ride a route the distance to the next points comes down
          Hans-Udo Erdmenger
          @superg but the arrow on the track shows every time correctly the point where i was,
          @brian-mcg MRA increased the distance after I closed and restard the app.
          • Travellexxie Offline
            I am with Brian, you probably missed the first waypoint and MRA is sending you back, but that is the opposite direction. Therefore you see the arrow (that is your actual position coming from GPS) and has nothing to do with the driving direction.
              Hans-Udo Erdmenger
              @travellexxie I switched of automatic recalculation and switched on Automatically skip waypoints
                Nevertheless the app will always send you back when it is a viapoint (3 times when it is a shapingpoint) and you didn't "touch" it. In these cases you have to manually skip the waypoint.
                  Hans-Udo Erdmenger
                  I could not skip any waypoint, because the fault was between point 1 and 2.
                  Hans-Udo Erdmenger
                  Hans-Udo Erdmenger
                  • Welke instelling
                    Thomas Schäfer
                    Thomas Schäfer
                  • opslaan naar plantomtom
                    chris 18
                    chris 18
                  • Seizoen sluitingen wegen
                    PAT62
                    PAT62
                  • App loopt vast
                  • I can't see Road Closures
                  • Rejoining routes
