  2. Export assistance
  3. [Export] Garmin
  4. GPX Versions 1.1 vs 1.2 for Garmin Visually Explained
gpx 1.1gpx 1.2garmin xt
191 Posts 21 Posters 52.0k Views 4 Watching
  • Simon James Hancock Simon James Hancock
    I am trying to avoid using tread. I do al my planning in MRA and save to the garmin sd card.
    Steve Jarrell
    Steve Jarrell
    Steve Jarrell
    #100
    @Simon-James-Hancock I don't like using Tread either. I use a USB C to C cable directly from my Macbook Pro to my XT3 and use the free OpenMTP app to manually place my .gpx files in the /gpx folder. It's VERY fast and works 100% of the time.
    If I do have the Tread app connected to my XT3, Tread (and the Explore website) will automatically synch with collections, routes and tracks that I manually put on the Garmin.
    (Geek overload section follows) 🙂
    Here's a screenshot of what the OpenMTP app looks like on my Macbook (this would look basically the same if I was using File Explorer on a PC) when I've copied my .gpx files into the \gpx folder before the XT3 has imported them into its internal memory.
    The interesting thing that I've discovered is once the XT3 imports the .gpx files, it deletes the Track section from the file but leaves the route information (which in the 1.2 format contains a copy of the track) in the file and does not delete the file. The result of this is that even if you delete the route in the Garmin's internal memory a copy of it is still in the \gpx folder, and it can be imported again and again.
    If you've manually uploaded a gpx file into the \gpx folder it's up to you to delete it manually which is fine with me. Tread skips the \gpx folder and loads the gpx information directly into the devices internal memory.
    Steve Jarrell
    Western North Carolina US
    2025 BMW R1300GS
    2025 Can-Am Spyder
    DMD T865-X 8" Tablet
    Garmin XT3
    • Steve Jarrell Steve Jarrell
      @John-S-Parry I figured that the recalculation was going to happen and screw up the route. I agree completely with your conclusions including that restarting the route and selecting the closest point as the starting point would have probably put you back on your intended route.
      The Garmin has a LOT of gps coordinates in the track that's embedded in the route section of the 1.2 gpx file so it should be able to take you to the closest coordinate to where you are without recalculating the route.
      If you test it let us know, and I'll do the same. Thanks a lot for the update!
      @Steve-Jarrell I got out again today to run another test of "Up Ahead", but this time without adding/inserting a via stop into the 1.2 route.
      For testing, I created a new 1.2 route to simulate a real situation. When I was few miles from my test deviation, I did the "Up Ahead" thing, selecting the via point to route to. This time, I selected "create a new route" instead of modifying my 1.2 route. I pressed "Go", and my new route started guiding me. I got to the new destination without issue. While stopped, I brought my 1.2 route back up, and it immediately presented the starting point radio box. I selected 'Closest Enry Point", and off I went. Long story short, the remaining route continued exactly as originally planned. Success!
      I love it! No skipping waypoints or other stuff you have to deal with on the Next app. I'm now confident I can use 1.2 for just about any situation.
      • John S Parry John S Parry
        Steve Jarrell
        Steve Jarrell
        Steve Jarrell
        #102
        @John-S-Parry Awesome!
        That makes logical sense (that's not always the case with Garmin) 🙂 as the 1.2 gpx route has a LOT of gps coordinate pairs in it so when you selected "Nearest Point" it obviously guided you back to one of those points then you were on your way. That's the way that I was hoping that it worked.
        Thanks very much for the update!
        Steve Jarrell
        2025 BMW R1300GS
        2025 Can-Am Spyder
        Garmin XT3
        • Carl Lee
          Carl Lee
          Carl Lee
          @steve-jarrell that was a huge typo on my part. It was meant to read “and even if you are not using Tread”. I must have been tired. I’m all Zumo’d out.
          • Carl Lee Carl Lee
            Steve Jarrell
            Steve Jarrell
            Steve Jarrell
            @Carl-Lee Been there. Done that. Have the t-shirt! 🙂
            Steve Jarrell
            2025 BMW R1300GS
            2025 Can-Am Spyder
            Garmin XT3
            • Carl Lee Carl Lee
              I'd like to add something about recalculation. I haven't played with 'Up Ahead' places by inserting them into my route but on a normal deviation from a 1.2 route with recalculation left on, I've found there is a recalculation but it logically puts you back on your intended route - maybe with a u-turn or merging with it a little further along.
              @simon-james-hancock, which Zumo do you have? On the XT2, you can change the colour in Tread or the Zumo but the width is done on the Zumo. And if you are using Tread, the track must be put in a collection that is visible. I've found red on the widest to be very visible on the XT2. If you don't see the track underneath when zoomed in, just zoom out a little and you'll see it. I wouldn't want it any wider as otherwise it would obscure junctions etc.
              @Carl-Lee said:
              " I'd like to add something about recalculation. I haven't played with 'Up Ahead' places by inserting them into my route but on a normal deviation from a 1.2 route with recalculation left on, I've found there is a recalculation but it logically puts you back on your intended route - maybe with a u-turn or merging with it a little further along."
              This got me thinking about recalculation to get the Zumo to return you to the route. So I had to go out and check.😊
              You're correct that going off route, with recalculation left on, will simply attempt to return you to the route. It does not recalculate the whole route and trash your custom shaping up ahead. I performed conscious off-route deviations at least three separate times, and they all did nothing other than try to return me to the route. A few of the Zumo decisions on returning me were head scratchers, but they worked, and the route continued as normal.
              The recalculations that are a NO-NO are actions that modify the route itself. As discussed, that can be through using "Up Ahead" and inserting a new via point as the next stop. Using Search to find a POI and inserting that via point as the next stop is equally disastrous. In short, don't do anything that modifies your route and triggers a recalculation.
              From my perspective, using 1.2 GPX files in the Zumo works very well if you understand the behavior.
                Steve Jarrell
                Steve Jarrell
                Steve Jarrell
                @John-S-Parry "In short, don't do anything that modifies your route and triggers a recalculation."
                I think that sums it up perfectly!
                I leave auto-recalculation turned off just from habit using so many different versions of the Garmin, and I'd rather just get back on the route by myself, but off-route re-calculation does not seem to trigger the dreaded "ok, you changed the route manually so that gives me (the Garmin) permission to do whatever I want to to your route". 🙂
                Steve Jarrell
                2025 BMW R1300GS
                2025 Can-Am Spyder
                Garmin XT3
                • Carl Lee
                  Carl Lee
                  Carl Lee
                  wrote on last edited by Carl Lee
                  #107
                  Still some more testing to be done I think. I’m wondering if “shaping” the route on the Zumo just by adding some more shaping points (not vias) will damage it. In reality, this is something I would rarely, if ever, do but it would be nice to know.
                  When I get chance……
                  And anyway, even leaving auto recalculation off, if you’re struggling to get back on the route (it happens!), stopping it and restarting with CEP is a fine and still won’t destroy the route.
                  • Carl Lee Carl Lee
                    When I get chance……
                    Steve Jarrell
                    Steve Jarrell
                    Steve Jarrell
                    @Carl-Lee Yep, you're right. Restarting the route from any point is FAR better than doing ANYTHING that signals the Garmin that it's ok to change your route as it sees fit.
                    As far as adding the shaping points goes I really don't know. I've never done that as I've never had the need to do so. For that matter I've never created a route directly on the Garmin either, so for me there are still a lot of unturned stones! 🙂
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                      @Steve-Jarrell Yes, it seems with a high degree of confidence, that 1.2 off-route recalculation does not seem to trigger a complete recalculation of the route. It's simply a re-calculation to get you back to the route. I don't think there is an overt amount of intelligence within the Zumo. In each case where I intentionally went off-route to trigger auto recalculation, it tried to turn me around back to the off-route spot for route re-entry. Even when there was a shorter re-entry point a little further up. In a way it makes sense, because it wants you hit all points on the route. But it's not always optimal if all you want is to get back to a point on the route as quickly as possible.
                      To the last observations made by @carl-lee, I don't know for sure if adding shaping points on the Zumo will destroy the route. But my best guess is that it will. I think that playing with the track sections of a 1.2 route, with adding either Shaping points or Vias, will communicate to the Zumo that all bets are off and trigger a total route recalculation.
                      Why do I say this? It's not 100% apples-to-apples, but when I export the track of a MRA route as a GPX and then import it into Garmin Basecamp, everything is fine after converting the Track to a Route. If at that point I try to make any modifications, either Shaping or Via, I get a BC warning message to the effect that a total recalculation will take place. I'm guessing this logic also applies to 1.2 routes on the Zumo. An example of Garmin being Garmin. 😊 It might be an interesting experiment to conduct, but someone else will have to pick up that torch.
                      • Mzokk
                        Adding shaping points to the route on the Zumo will likely destroy the route as the complete route is recalculated to include the applied shaping point. When you convert a track to a route in Basecamp it gives a start and finish and includes any Via points. But on the XT at least if you go route and haven't switched off automatic recalculation it will recalculate the route on the zumo according to the preferences set. There is a way round this on Basecamp to force a track to create a load of shaping points but its not really relevant to an MRA discussion.
                        • Mzokk Mzokk
                          #111
                          @Mzokk Thanks for the confirmation. I'm a simple man who doesn't want to get bogged down in the nuances of possible exceptions to what happens most of the time. In my short period of testing and use of 1.2 GPX routes, my firm conclusion is not to make any modifications that would trigger a route recalculation. Off-route recalculation for re-entry is OK, because the base route itself is not modified. My first instinct will still be to reenter a route under my own control, but the option for the Zumo to do that for you is clearly there.
                          Everybody has their own approach to route planning/creation/execution. At a high level, my separation of duties is that all route modifications happen at the MRA Routeplanner level. If I want to make any Shaping/Via point changes, I go back to Routeplanner, perform the updates, and then re-copy the route back to the Zumo. In other words, Routeplanner is the repository for managing my routes. I have my own folder system for keeping everything sorted out. I view the Zumo as the execution layer. Similar in concept to the old IT Client/Server model. It's just one way of doing things, but it's a simple separation of duties and it works for me.
                          As a side note, in being active on this forum, it seems like many members view routes as a "suggestion" that should be flexible to change through repeated skipping of waypoints. That seems to me where a lot of people get tripped up. I guess different views on things are what makes the world go around.
                          • smfollen 0
                            smfollen 0
                            smfollen 0
                            I'm new to MRA but I've been working to understand gpx and zumo for a long time. I think I can offer a bit of clarification here.
                            From a zumo perspective, the key difference between MRA's 1.1 and 1.2 is not that shaping points are eliminated, but that route point extensions are included. They are essentially track points, just formatted and handled differently.
                            If a route is transferred into the zumo without route point extensions (e.g. MRA's gpx 1.1), it will be calculated based on all available route points, both via and shaping. If the route does include route point extensions (e.g. MRA's gpx 1.2), it will not be recalculated unless the route is subsequently changed.
                            If a route is fully recalculated by the zumo, the route point extensions are discarded, the route is calculated based on all available route points, both via and shaping. New route point extensions will be generated. Route point extensions are the result of route calculation, never an input to the calculation.
                            When using CEP, or going off-route with recalculation allowed, the zumo will indicate that it is calculating, but is is not recalculating the entire route. It is only calculating a small route segment. Route point extensions are preserved.
                            Adding or removing a route point, via or shaping, will result in a full route recalculation, discarding all previous route point extensions. Since MRA's 1.2 discards shaping points, only the via points are available to recalculate the route.
                            This implies that it would be better to import a route which includes via, shaping, and route point extensions.
                            I should also note that recent firmware version 6.60 for the zumo XT2 improved off-route recalculation behavior.
                            • smfollen 0 smfollen 0
                              Steve Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              #113
                              @smfollen-0 "From a zumo perspective, the key difference between MRA's 1.1 and 1.2 is not that shaping points are eliminated, but that route point extensions are included. They are essentially track points, just formatted and handled differently."
                              Exactly! For the person who doesn't clearly understand this yet, this key difference is VERY important when the Garmin calculates the route. I'll illustrate here what happens during a 1.1 vs. 1.1 route import.
                              Let's take a route created with created in MRA that includes 4 via points (starting via point + ending via point + 2 more) and 6 shaping points for a total of 10 total reference points as an example:
                              In simple terms, a 1.1 route in the .gpx file looks like this:
                              starting via point 1 -> shaping point 1 -> shaping point 2 -> via point 2 -> shaping point 3 -> shaping point 4 -> via point 3 -> shaping point 5 -> shaping point 6 -> ending via point 4.
                              When this 1.1 route is imported into the Garmin it will calculates its own route using its own logic between each of these 10 shaping and via points based on its settings (fastest, shortest, etc). Many times that route doesn't go exactly where you planned or how it looked in MRA, and it does not match the track.
                              On the other hand, a 1.2 route in the .gpx file looks like this
                              (For simplicity's sake I'm going to refer to "route extensions" as "track points" as both of them are simply latitude/longitude pairs that are like breadcrumbs that precisely mark the desired path between two points.)
                              starting via point 1 -> track points -> via point 2 -> track points -> via point 3 -> track points -> ending via point 4.
                              When the route is imported there are no shaping points in the 1.2 .gpx format as you pointed out. Instead, the 1.2 route includes a large number (for a normal route many hundreds or even thousands) of track points that force the Garmin to calculate the route EXACTLY as you had planned and EXACTLY the same as your track file.
                              Good discussion. Thanks for the input!
                              Steve Jarrell
                              2025 BMW R1300GS
                              2025 Can-Am Spyder
                              Garmin XT3
                              smfollen 0 1 Reply Last reply
                                smfollen 0
                                smfollen 0
                                smfollen 0
                                @Steve-Jarrell said:
                                Instead, the 1.2 route includes a large number (for a normal route many hundreds or even thousands) of track points that force the Garmin to calculate the route EXACTLY as you had planned ...
                                Actually, for 1.2 the Garmin does NOT calculate the route (on import and for [some] off-route or Closest Entry Point cases). It just uses what was imported without change, which is why it matches the original.
                                In cases where it does recalculate the 1.2 route, it would use only starting via point 1 -> via point 2 -> via point 3 ending via point 4. This is why, when a full route calculation occurs on the zumo, a 1.1 route with both via and shaping points would produce a result closer to the original than a 1.2 route.
                                Which is why
                                smfollen-0 said:
                                ... it would be better to import a route which includes via, shaping, and route point extensions.
                                • Carl Lee
                                  Carl Lee
                                  Carl Lee
                                  #115
                                  My input here is to agree with @steve-jarrell in that a quick revision of the route in MRA is probably the best way here (easy with Tread syncing). I’ve had some less than agreeable results adding shaping points to a GPX1.1 test route on the Zumo trying to revise it. I gave up on the idea, especially as I’ve never needed to do it in anger.
                                  We’re still surmising what might happen here without a full test. In truth, I’ll probably never need to do it but it’ll be nice to know.
                                  • Carl Lee Carl Lee
                                    smfollen 0
                                    smfollen 0
                                    smfollen 0
                                    I agree entirely. I was only trying to shed a little light on what the zumo is, and isn't, doing.
                                    I'm new to MRA, but so far I'm impressed.
                                      Which is why
                                      Steve Jarrell
                                      Steve Jarrell
                                      Steve Jarrell
                                      @smfollen-0 smfollen-0 said:
                                      "... it would be better to import a route which includes via, shaping, and route point extensions."
                                      I don't believe that's possible with our currently available .gpx file export options.
                                      There simply isn't a .gpx format that includes via, shaping and route extensions (track points) all in the route section of the same .gpx file. They are mutually exclusive
                                      The 1.1 .gpx format includes VIA and SHAPING POINTS embedded in the route section of the .gpx file. It does NOT include "route extensions" (track points) in the route section.
                                      The 1.2 gpx format includes VIA and TRACK COORDINATES (route extensions) embedded in the route section It does NOT include shaping points in the route section.
                                      Neither the 1.1 nor the 1.2 .gpx format contain BOTH shaping points AND track points (route extensions) in the route section of the .gpx file. If I'm wrong, I'll gladly admit it.
                                      We are all here to learn, and I'm no exception!! 🙂
                                      Steve Jarrell
                                      2025 BMW R1300GS
                                      2025 Can-Am Spyder
                                      Garmin XT3
                                      • Mzokk
                                        When I use my Garmin devices for navigation for navigation I tend to use GPX1.1 (plus a track of the route) because for me it's more flexible, as I often lead groups and want the option to use route recalculation and to be able to manually skip optional route loops which may or may not contain via points (when time becomes tight). For example, routes round Lochs, Loughs, Lakes or up and down valleys. If using my XT, or my Zumo 390/340 on the other bike, skipping a via point will force a route recalculation and destroy the rest of the route. If you have shaping points then the route is only altered to the next shaping point and the rest of the route is maintained.
                                        This means that quite a few shaping points are required to pin the route to the intended roads. For the XT this is more important as its "Faster Time" routing algorithm now equals "faster roads" whereas the older Zumo 390/340 will route on any road that it determines is producing a "Faster Time" between points. I think this change has been effected as Garmin just use car navigation device firmware and software in their motorcycle units these days. To ensure that routes are pinned for use on my (Now Backup) XT these days I often use the MRA expand function to increase the number of shaping points on a route before I export it to the Zumo XT.
                                        For me the easiest way to avoid all the faff with Garmin units is to use MRA for navigation on my Africa Twin screen then the routes are WYSIWYG. Bottom line is there are no right or wrong answers just find a strategy that gets you where you want to be. This was true even when we used maps some folk marked a line on the map and kept it in a clear pocket on the tank. I made a "tulip road book" with road numbers left and right turns and rough distances in between.......the map only came out when I got lost 🙂
                                        • Mzokk Mzokk
                                          Steve Jarrell
                                          Steve Jarrell
                                          Steve Jarrell
                                          @Mzokk Excellent points. In an ideal world everyone on a group ride would have the exact same GPS with the current maps and most current sw version. Since that's never going to be the case the lowest common denominator is the track file and that's what I see being distributed most often for these rides.
                                          If you're leading a ride I can see where your 1.1 gpx file route combined with the track file would be a better option than a 1.2 file. I hadn't thought of that before.
                                          Thanks!!
                                          Steve Jarrell
                                          2025 BMW R1300GS
                                          2025 Can-Am Spyder
                                          Garmin XT3
                                          Mzokk 1 Reply Last reply
                                          • 4
                                          • 5
                                          • 6
                                          • 7
                                          • 8
                                          • 9
                                          • 10
                                          Will Brooks
                                          Will Brooks
                                          Carl Lee
                                          Carl Lee
                                          Steve Jarrell
                                          Steve Jarrell
                                          Reinhard-32
                                          Reinhard-32
                                          Simon James Hancock
                                          Simon James Hancock
                                          smfollen 0
                                          smfollen 0
                                          Phil Ellis
                                          Phil Ellis
                                          Jim Foster
                                          Jim Foster
                                          Sam Ellis
                                          Sam Ellis
                                          Papasmurf2
                                          Papasmurf2
                                          OkayJim
                                          OkayJim
                                            martin-phogel.de
                                            martin-phogel.de
                                            12.0k
                                          • Issues on one-way streets when reversing routes
                                          • Route line is not easy to follow on map
                                          • F004 MRA Navigation Error
                                          • Probleem met eigen Stay
                                            Albert van den Elsen
                                          • Reclame van Navigation Next blokkeert de navigatie.
