  2. Export assistance
  3. [Export] Garmin
  4. GPX Versions 1.1 vs 1.2 for Garmin Visually Explained
gpx 1.1gpx 1.2garmin xt
194 Posts 22 Posters 63.0k Views 5 Watching
  • Steve Jarrell Steve Jarrell
    @John-S-Parry I agree John.
    If you don't include via points between your starting and ending via points and then skip them while navigating a route, it seems that you can rejoin your planned route manually if you have auto recalculation turned off with the 1.2 format. That's fine and easy to manage for me
    That makes sense as basically (with my simplistic thought process) as a 1.2 route with only a beginning and ending via point is basically a track that's been converted to a route.
    When you introduce an intermediate via point in the route and then skip it, you give the Garmin the permission to totally ignore your planned route and do whatever it wants to do and recalculate the route as it sees fit! ๐Ÿ™‚
    For me personally if I just want a GPS to determine a route for me based on its on algorithms I'll just use Google Maps or Waze, but that's not why I use MRA! I want to determine exactly where I go when I'm riding!
    Garmin, LEAVE MY ******** ROUTE ALONE!!! I don't need your help!!! ๐Ÿ™‚
    @Steve-Jarrell I am curious about one scenario under 1.2......
    One of my favorite features in the Zumo is "Up Ahead". I've found it invaluable for locating gas stations and restaurants in areas I'm unfamiliar with. I was recently riding with a friend in the coastal Redwood forests along US-101 in far Northern California. Desolation doesn't describe how isolated that area is. We were heading south with no civilization is sight. And we were getting hungry. ๐Ÿ˜Š On the Zumo, I selected "Up Ahead", then the Restaurant category, and saw a small town a few miles west of the route that had a highly rated burger place. I selected it, and the Zumo gave me the option of adding the diversion to my route. Again, I selected it and the off/on diversion worked perfectly. I'm wondering if under the covers that was a full route recalculate, and if my 1.2 route would have been altered up further ahead in an undesirable way?
    • Carl Lee
      Carl Lee
      Carl Lee
      wrote on last edited by Carl Lee
      #69
      @simon-james-hancock, also learned the hard way is if you start your route with 'CEP' (closest entry point) and either your end point or some other part of the route is closer to you than the start point, you can ride a very short route! In which case, choose the 'Start'.
      If you wish to mark a petrol station or similar without creating a via point, create a POI of it in MRA. You can name it whatever you like and change the symbol. It will only show up as a flag and name on your Zumo though - these can be edited. There will be no distance or time shown to it but very handy nonetheless.
      I'll reaffirm what I said earlier re 'auto-recalculate' with GPX1.2. It can be left on if you wish to be guided back to your route. It does not (in my tests) recalculate you to the next via point.
      • Simon James Hancock
        Simon James Hancock
        Simon James Hancock
        Carl that is exactly what happened to me when my end point was closer to me when I set off than my start point, thanks.
        I will try the POI when creating the map in MRA.
        Maybe when selecting a petrol station in the Up Ahead menue it will not be neccessary to creat a POI.
        • Will Brooks
          Will Brooks
          Will Brooks
          I've found when creating routes especially circular ones with a start and finish point close together or an "out and back" route using some of the same roads that the best way is to plan my route and then split it into 2 routes using the MRA split function so I have an "OUTBOUND" route and a "RETURN" route. That way I can totally eliminate the issue of confusion when skipping or recalculating of the XT misrouting to a point that is on my return leg rather than my outbound leg.
            Simon James Hancock
            Simon James Hancock
            Brilliant!
            I have now created an out bound and inbound route.
            Later on I will give it a try.
            Thanks everyone for the patcience and time taken to answer my questions.
            Pardon the pun but things are taking shape.
            Mzokk 1 Reply Last reply
            • Simon James Hancock Simon James Hancock
              Brilliant!
              @Simon-James-Hancock It appears from reading through all of this that your XT and XT2 will behave slightly differently with GPX 1.2 files. The XT and older Garmin devices will recalculate according to their own parameters if you use GPX 1.2 and accidently recalculate the route. This behaviour will not be fixed by Garmin as the units are now discontinued. I've tested this in simulation mode and riding the bike with a GPX 1.2 route on the Garmin Zumo XT you cannot let the unit recalculate. This is fine as all that happens is that the unit goes quiet until you re join the magenta line. For the XT2/3 it appears that recent software updates from Garmin mean that if you deviate from a GPX1.2 route you can leave automatic recalculation on and the device will navigate back to the route.
              Simon James Hancock 1 Reply Last reply
                Carl Lee
                Carl Lee
                Carl Lee
                Via points have always been a nuisance if you don't visit them no matter what GPX format is used. I use them a lot on trek events where we have to visit multiple points but other than that use them very sparingly. Next time I get a chance, I'll build a 1.2 route with some extra via points and ride it. They'll be in places where the XT2 would find it a lot quicker to re-route in order to get to the next via point if skipped. I'm not sure when this will be but standby......
                • Carl Lee Carl Lee
                  Steve Jarrell
                  Steve Jarrell
                  Steve Jarrell
                  @Carl-Lee Very good to know. Thanks!!
                  Steve Jarrell
                  Western North Carolina US
                  2025 BMW R1300GS
                  2025 Can-Am Spyder
                  DMD T865-X 8" Tablet
                  Garmin XT3
                  • Carl Lee Carl Lee
                    Steve Jarrell
                    Steve Jarrell
                    Steve Jarrell
                    #76
                    @Carl-Lee As long as you don't mind the Garmin rerouting you to get from via point to via point it's not an issue, but if you're expecting to follow the route that you planned you may or may not do so! ๐Ÿ™‚
                    Steve Jarrell
                    2025 BMW R1300GS
                    2025 Can-Am Spyder
                    Garmin XT3
                    • John S Parry John S Parry
                      Steve Jarrell
                      Steve Jarrell
                      Steve Jarrell
                      #77
                      @John-S-Parry I'm not sure. That will be a good test. I will bet it does force a recalculate. However as has been pointed out here it very well may be device dependent (XT-XT2-XT3).
                      That's a beautiful part of the country. I flew into Seattle a few years ago and drove down the west coast mainly on the 101 to San Diego for a couple of weeks. The prettiest part of the drive was WA - OR - Northern CA by far.
                      Steve Jarrell
                      2025 BMW R1300GS
                      2025 Can-Am Spyder
                      Garmin XT3
                        @Steve-Jarrell Yes, the WA - OR - Northern CA sections of the west coast have incredible scenery. I always try to catch that area when there are known periods of good weather and clear skies. But from a pure riding perspective, Central California has some of the best backroad riding to be found anywhere. That's my backyard, and I try to take full advantage of it. ๐Ÿ˜Š
                        Back to the "Up Ahead" and what adding diversions does to a route -- I'll construct a test to see how much of the overall route is touched. Like you, I hate any recalculation because I never trust what might actually be altered. My routes have a given shape for a reason and changing them on the fly during execution goes against my intent. Using a feature like "Up Ahead" is a valid alteration (to me) given a specific circumstance, so I'll investigate that further.
                        Steve Jarrell 2 Replies Last reply
                        • Carl Lee
                          Carl Lee
                          Carl Lee
                          So long as you have your track visible, none of this is a major problem. And in any case, it's always quite easy to get back to your intended route by stopping it then restarting with CEP.
                          I spend some time planning the specific roads I want us to go down so also hate it being messed up. I'm really pleased with how 1.2 handles a normal deviation so finding out about skipped via points and "Up Ahead" deviations will be interesting.
                            Steve Jarrell
                            Steve Jarrell
                            Steve Jarrell
                            @John-S-Parry Yes, I have been rerouted onto some.... well let's say "interesting" roads that I didn't plan on being on in the past!
                            Steve Jarrell
                            2025 BMW R1300GS
                            2025 Can-Am Spyder
                            Garmin XT3
                            • Carl Lee Carl Lee
                              Steve Jarrell
                              Steve Jarrell
                              Steve Jarrell
                              @Carl-Lee For some reason my XT3 is no longer showing my track with my route even though I've done it MANY times in the past. I'm still trying to figure out what's going on. You're right though... that's the very best way to know that you're being routed the way that you intended to be!
                              Steve Jarrell
                              2025 BMW R1300GS
                              2025 Can-Am Spyder
                              Garmin XT3
                              • Carl Lee
                                Carl Lee
                                Carl Lee
                                @steve-jarrell maybe as you are tied in to collections with Explore? This is how I am too and itโ€™s a case of making the collection visible. A little more to it than that but I wonโ€™t blather on in case thatโ€™s not your issue.
                                  Steve Jarrell
                                  Steve Jarrell
                                  Steve Jarrell
                                  @John-S-Parry Good deal. Let us know what you find.
                                  The best test would be just a starting via point and an ending via point with a lot of shaping points in between that are neither the fastest or shortest paths to the ending via point. I'll try it if I get a chance. It's very likely that the older Garmin units will act differently than the new ons.
                                  Steve Jarrell
                                  2025 BMW R1300GS
                                  2025 Can-Am Spyder
                                  Garmin XT3
                                  John S Parry 2 Replies Last reply
                                    @Steve-Jarrell Good approach. I was thinking along the same lines. I'll mix up the roads enough to trigger a different re-calculated route path if that's what it wants to do.
                                    • Carl Lee Carl Lee
                                      Steve Jarrell
                                      Steve Jarrell
                                      Steve Jarrell
                                      #85
                                      @Carl-Lee No, I don't use Explore at all (I have another thread about the hoops that I had to go through to remove it when I did activate it) but I do use collections in the XT3.
                                      You did put me on the right track though! Since I think this issue is unique to the XT3 I've created another thread to explain what's happening and a good work around as it's not documented at all in the user's manual.
                                      Thanks!
                                      p.s. When I said before that I've shown the track with the route many times I have..... but that's been with previous version of the Garmin units up to and including the XT.
                                      Steve Jarrell
                                      2025 BMW R1300GS
                                      2025 Can-Am Spyder
                                      Garmin XT3
                                      • Mzokk Mzokk
                                        Simon James Hancock
                                        Simon James Hancock
                                        Simon James Hancock
                                        @Mzokk That is exactly what happened this afternoon in my test.
                                        I purposly stopped along the route and turned both units off and then back on again.
                                        The xt2 picked up the route again and the xt whent dorment untill much further down the route.
                                          Simon James Hancock
                                          Simon James Hancock
                                          wrote on last edited by Simon James Hancock
                                          #87
                                          Going off topic a bit.
                                          If just using the MRA app on the phone, What is the best map to create the route and which format is the best to save the route for the MRA app?
                                          How does the standalone MRA app deal with these situations?
                                          I am asking this as my bike has carplay so therefore I also have the option of using the MRA app.
                                          • 4
                                          • 5
                                          • 6
                                          • 9
                                          • 10
                                          smfollen 0
                                          smfollen 0
                                          Andy Beviere
                                          Andy Beviere
                                          Steve Jarrell
                                          Steve Jarrell
                                          Reinhard-32
                                          Reinhard-32
                                          Will Brooks
                                          Will Brooks
                                          Carl Lee
                                          Carl Lee
                                          Simon James Hancock
                                          Simon James Hancock
                                          Phil Ellis
                                          Phil Ellis
                                          Jim Foster
                                          Jim Foster
                                          Sam Ellis
                                          Sam Ellis
                                          Papasmurf2
                                          Papasmurf2
                                          OkayJim
                                          OkayJim
                                          • Heatmap menu: Display traveled routes
                                          • 'Geen adres bekend'
                                            PA. Vis 0
                                            PA. Vis 0
                                          • Feature request: support voor kaartview op kleinere schermen
                                            Ruud Bijkerk
                                            Ruud Bijkerk
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                          • Rondrit voert over een afgesloten weg
                                          • iPad - zooming out
                                            Big Al 1
                                            Big Al 1
