Can I Merge Multiple GPX Files into One Route?
I was wondering if it's possible to combine multiple routes (GPX files) that I've either created myself or received from others into a single route covering several days.
If this is possible, how do I do it?
Thanks in advance!
You can if you import the GPX files into the Route Planner as separate routes. Then open the initial (Day1) Route, Go to the left panel, click on 3 lines and select Routes option.
From there click Add, select the route you want to display (Day2) and it will display as a line on the same screen (you can change the color of it clicking in the little colored box in the route name) and then click on the "+" sign in the Day2 route name, That's how you Merge Routes. -
Thanks in advance!
@Tommy-Kragseth-Hansen as @lenny-o say yes it is possible
the method is described in the user support documentation
With your input, this post could be even better đ
