  2. Routes & Tracks
  3. Can I Merge Multiple GPX Files into One Route?
3 Posts 3 Posters 571 Views 2 Watching
  • Tommy Kragseth Hansen
    I was wondering if it's possible to combine multiple routes (GPX files) that I've either created myself or received from others into a single route covering several days.
    If this is possible, how do I do it?
    Thanks in advance!
    BMcG 1 Reply Last reply
    • LennyO
      You can if you import the GPX files into the Route Planner as separate routes. Then open the initial (Day1) Route, Go to the left panel, click on 3 lines and select Routes option.
      From there click Add, select the route you want to display (Day2) and it will display as a line on the same screen (you can change the color of it clicking in the little colored box in the route name) and then click on the "+" sign in the Day2 route name, That's how you Merge Routes.
      • Tommy Kragseth Hansen Tommy Kragseth Hansen
        Thanks in advance!
        @Tommy-Kragseth-Hansen as @lenny-o say yes it is possible
        the method is described in the user support documentation
          TomOnTour
          TomOnTour
        • Newsletter optimisation
        • route aanklikken in overzichtskaart
        • Trekking tool: sun/shade
        • How can I change colours in the route overview?
          Kudee
          Kudee
        • Skip feature in the MRA Classic
          TomOnTour
          TomOnTour
