<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I Merge Multiple GPX Files into One Route?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I was wondering if it's possible to combine multiple routes (GPX files) that I've either created myself or received from others into a single route covering several days.</p>
<p dir="auto">If this is possible, how do I do it?</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forum.myrouteapp.com/topic/11273/can-i-merge-multiple-gpx-files-into-one-route</link><generator>RSS for Node</generator><lastBuildDate>Wed, 01 Jul 2026 13:34:38 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11273.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 Jun 2026 21:15:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I Merge Multiple GPX Files into One Route? on Wed, 01 Jul 2026 01:24:48 GMT]]></title><description><![CDATA[<p dir="auto">You can if you import the GPX files into the Route Planner as separate routes. Then open the initial (Day1) Route, Go to the left panel, click on 3 lines and select Routes option.<br />
From there click Add, select the route you want to display (Day2) and it will display as a line on the same screen (you can change the color of it clicking in the little colored box in the route name) and then click on the "+" sign in the Day2 route name, That's how you Merge Routes.</p>
]]></description><link>https://forum.myrouteapp.com/post/80367</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80367</guid><dc:creator><![CDATA[Lenny O]]></dc:creator><pubDate>Wed, 01 Jul 2026 01:24:48 GMT</pubDate></item></channel></rss>
