  3. [App] Announcements
  4. New update 5.2 - Avoid roadblocks, persistent map items, POI management and share
61 Posts 32 Posters 13.8k Views 13 Watching
  • CD130 CD130
    Fantastic update, and impressively fast after the 5.1 release! Will the POI management features be coming to the online route planner soon as well?
    @CD130, for now the web-POI-features are completely independent from the app-POI-features. It is wise to disable all permanently enabled web-POI-categories, and start using the app for that. Enabled categories in the web-planner will still show on the map, but cannot be disabled from the app (they will simply not show as enabled in the app, but still be visible by the setting in the web).
      @corjan-meijerink :
      I have seen and tested all the functions briefly, I am overwhelmed by it, I have to shake myself, so much at once. Thank you for these new features. Best regards 👋
      Ich habe alle Funktionen kurz gesehen und getestet, ich bin davon überwältigt, ich muss mich schütteln, so viel auf einmal. Vielen Dank für diese neuen Funktionen. Mit freundlichen Grüßen 👋
      • D Griffin
        D Griffin
        D Griffin
        keep working with HERE and get that icon to stop spinning at stops....Enjoy they vacation
          Hi everyone! 👋
          I'm off on a trip to the UK in 20 hours 🙂 And I'll be away for 2 weeks.
          Please don't expect any responses from me personally. If I do respond, my wife won't be amused.
          That said, I've been working my ass off to provide a very big update!
          Because of my holiday, this is a public announcement but we still need to do Beta testing.
          To all beta testers: please provide feedback as always (in the closed group) but if it's all minor feedback we won't delay public release. If critical issues are found preventing a public release, we will announce that the public update is delayed 😉
          Timeline
          • Beta testing ASAP
          • Public release aimed for June 18th (give or take approval times)
          Now on to the fun stuff! 🎉
          Avoid roadblocks
          A much requested feature! Thanks for the elaborate discussion I had on the forum with some users. Especially a personal thank you to @Axel-Härtl for bringing it up. The topics can be found here and here.
          While navigating a route, you can choose to avoid a part of the route. This has 3 flavors:
          • By waypoint
          • By distance
          • Manually adding
          When selecting by waypoint to choose the waypoint till where we need to avoid.
          The app will continue navigating towards the waypoint after that and creates a diversion for every part before that.
          Distance will be the most sensible one. Just quickly click one of the preset distances and that will be avoided. You can also select a custom distance. Obviously we try to take any skipped waypoints into account. This is a scenario where viapoints can be ignored.
          The above two always create a diversion from your current location.
          If you manually add an an avoidance you tap the route anywhere and choose if that's the beginning or end. When it's the end, you're done. Otherwise tap again to indicate the end.
          There is a distance restriction on how long the avoidance can be but that won't be a realistic use case anyway.
          Persistent map items (favorites)
          Why aren't we showing you where your favorites are all the time?
          Now you can do so!
          Simply enable the setting and your favorites are displayed all the time! 🎉 Even while navigating.
          Persistent map items (routes)
          We always stimulate users to sync all their routes. Then everything happens automatically 😏
          If you have all your routes available offline, you can now show them permanently on the map!
          Note: this feature only works for routes that are offline available. So not for unsynced routes and not for any tracklog
          Easily add all routes in a folder to your map. We will show which routes are displayed.
          You will then see them and are able to change the color for each route.
          From the menu you can remove them, open the route, remove them all or temporarily hide them all.
          The options are endless 💥
          The menu to manage your displayed routes can be found from the routes page or using the map styles. Obviously you can also add a single route to be displayed.
          This feature is very convenient for multi day trips and now mitigates one of the reasons that Garmin / TomTom users still used their navigation device.
          POI management
          Yes! Finally ❤
          Open and view your POI's directly in the app.
          Easily add any search result as POI.
          Create new groups and edit existing ones.
          And obviously you can always show these POI's on the map. Because why not 😏
          Not much more to say! Just play around yourself.
          Social media share / image generator
          A deep desired feature I had myself 😃
          Every single time I completed a tracklog, I hated the fact that I could not share it properly.
          When you now save a tracklog, we automatically show this new interface where you can create an image. For all your existing routes / tracklogs, just tap the "more options" (icon top right) and away you go.
          Note: this can only be done for your own routes / tracklogs.
          Choose one of three beautiful layouts.
          Pick, shuffle or randomize your images. You can even more / zoom the images itself.
          Change the map background.
          Share away 🎉
          CarPlay / Android Auto current street
          Yes, we now also show the current street name (when enabled) in CarPlay and Android Auto. We try to do this on as much resolutions as possible.
          Change avoid options while navigating
          When you are navigating, you can now change the avoid options on the fly.
          If you decide highway is allowed / disallowed, just change it immediately without needing to restart everything.
          Note: this cannot be done from CarPlay / Android Auto, left that out due to limited time
          Android altitude
          Now shows the correct value relative to sealevel.
          Minorities
          I'm looking forward too much to my vacation that I cannot really bother writing this part. We fixed some small identified issues in the 5.1 release. Added some logging to find more complex issues that still exist but generally we are extremely happy with how 5.1 performs!
          What's next
          I honestly don't know for now. I'll clear my head in the coming two weeks and think of more nice stuff ❤
          Cheers,
          Corjan
          @Corjan-Meijerink Enjoy your holiday, Corjan! ☀️😎
          • LE DIZES Freddy LE DIZES Freddy referenced this topic on
            I hope I checked all new features at home in simulation; there are so many. You've really done a great job there Corjan, the app is getting better and better. The list of features is unbelievable.
            The feature I've been waiting for is now live (just like the one on the TomTom Rider).
            I will now test everything on the road the coming days.
              Update is now live on all platforms, enjoy 🙂
              Peter Zehentreiter 2 Replies Last reply
                @Corjan-Meijerink I will be on Tour starting next week an Thursday... hopefully it will be available in time in the Google Play store
                BMW R 1250 GS
                DMD-NOR7E 7"
                SPC Universal mount
                Motorola Edge 40 "offline"
                Sena SLR 3
                Sena 50 R
                  @Corjan-Meijerink Just realized...it is already updated 👍😃🙏
                  BMW R 1250 GS
                  DMD-NOR7E 7"
                  SPC Universal mount
                  Sena SLR 3
                  Sena 50 R
                  • Cookie On Tour
                    Cookie On Tour
                    Cookie On Tour
                    wrote on last edited by Cookie On Tour
                    Have a wonderful break!
                    One thing, on Car Play/Android Auto - pressing the gas station button that shows the nearest gas station should add the station to the route on the fly as a waypoint.
                    Joerg
                    (Cookie-On-Tour.de)
                      • Peter Zehentreiter
                        Already checked and tried most of the new features.
                        Just brilliant👏
                        BMW R 1250 GS
                        DMD-NOR7E 7"
                        SPC Universal mount
                        Sena SLR 3
                        Sena 50 R
                        • Rae Sewell
                          Rae Sewell
                          Rae Sewell
                          When will it be available in Play store in the UK?
                          • LennyO
                            When is it actually going to be pushed onto devices?
                            • Rae Sewell
                              Rae Sewell
                              Rae Sewell
                              I'll rephrase when will the update be available in the Play Store, no update available yet in the UK
                              • Rae Sewell
                                Rae Sewell
                                Rae Sewell
                                I had to uninstall and re-install to get the latest version.
                                  #25
                                  Voor zover ik nu na kan gaan werkt het allemaal prima. Ik ben nu op vakantie in Noorwegen. Gisteren al een mooie rit gemaakt met de laatste versie. Maar ik schat in dat de Beta versie die ik al een paar dagen heb overeenkomstig is (behalve het versienummer). En het gaat gewoon prima.
                                  Corjan en team, hartelijk dank.
                                  @corjan-meijerink Hoe was je vakantie
                                  As far as I can tell, everything is working great. I’m currently on vacation in Norway. I already took a nice drive yesterday using the latest version. But I’m guessing that the beta version I’ve had for a few days is the same (except for the version number). And it’s working just fine.
                                  Corjan and team, thank you very much.
                                    Hi everyone! 👋
                                    Timeline
                                    • Beta testing ASAP
                                    Avoid roadblocks
                                    • By waypoint
                                    • By distance
                                    • Manually adding
                                    Now you can do so!
                                    POI management
                                    Yes! Finally ❤
                                    Share away 🎉
                                    Android altitude
                                    Minorities
                                    What's next
                                    Cheers,
                                    Corjan
                                    Jon Hye-Knudsen
                                    Jon Hye-Knudsen
                                    Jon Hye-Knudsen
                                    Absolutely great work!!!
                                    Truely useful features that I know I’ll need many many times. Personally I most needed the “change route prioritization” so I could switch highway on and off dynamically. The avoid feature to bypass a section…. Yes I’ve needed that and POI management is a really nice thing to be able to do and see them permanently on the map.
                                    I hope you have the best trip and get some serious rest away from the keyboard.
                                    Corrado Miniati 0 1 Reply Last reply
                                    • Cookie On Tour Cookie On Tour
                                      That's how it works in the app, but not on AA/CP, since there it is no button (prohibited) but just an info tile. The intended gas station will be the first suggestion when you go into the menu to add a gasstation.
                                      Cookie On Tour 1 Reply Last reply
                                      • Fridjof
                                        Fridjof
                                        Fridjof
                                        Works fine so far, we got the update yesterday during our vacation tour, hope all stay well,
                                        Thanks for the great update with the big and usefull improvements
                                        • BertM
                                          wrote on last edited by BertM
                                          #29
                                          Great work!👍
                                          One question: in one of the screenshots the color of the displayed routes can be changed.
                                          I cannot find that option in the menu
                                          Nick Carthew Peter Zehentreiter 2 Replies Last reply
                                          • 4
                                          Cookie On Tour
                                          Cookie On Tour
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          Edwin_M
                                          Edwin_M
                                          Garry Davis
                                          Garry Davis
                                          Axel Härtl
                                          Axel Härtl
                                          KeesV
                                          KeesV
                                          Sigurður Pétursson 0
                                          Jon Hye-Knudsen
                                          Jon Hye-Knudsen
                                          Rae Sewell
                                          Rae Sewell
                                            Marcel Versluis
                                            Marcel Versluis
                                          • MRA Navigation Next: Synchronisation by folder
                                            Parantapa
                                            Parantapa
                                            TomOnTour
                                            TomOnTour
                                          • Android Auto TFT
                                          • Route punt overslaan
                                          • Notche
                                            Adriaan Vonk
                                            Adriaan Vonk
