  4. V5.1.0 - 458 Same Point in Route Cycles to First Instance if Later Point Selected - CarPlay
11 Posts 2 Posters 123 Views 2 Watching
  • Dave J 0
    @Corjan-Meijerink I have been testing the version with a fairly simple route that requires going back to the same place after navigating to other points. I can select the later instance (second iteration of the point in the route) but when I check the route and the waypoints in CarPlay, the route will always be to the first iteration and not the second as selected.
    The same problem exists if I undertake the same process on the phone.
    Ducati Multistrada V4 Rally
    iPhone 15 Pro
    CHIGEE AIO-6 LTE
    • Dave J 0 Dave J 0
      @Dave-J-0 sorry, I have no clue what you are talking about 🙂
      If the behavior is the same in the app, please share screenshots
      • Dave J 0
        Sorry @Corjan-Meijerink Screenshot of the route with Points 2 and 4 being the same place. I quite often meet up with people at a place, we then do a circular route back to the same place before I head home.
        Quick Video
        The route
        iPhone 15 Pro
        CHIGEE AIO-6 LTE
          Wow! That one is interesting actually.
          I understand why it happens and will make sure it's fixed in the definitive 5.1 release.
          • Dave J 0
            Brill. Thank you. @Corjan-Meijerink
            iPhone 15 Pro
            CHIGEE AIO-6 LTE
              It is actually quite an annoying issue.
              Have you perhaps got the setting "Navigate routes as track" enabled?
              If yes, thanks for letting me know.
              If no, does the issue occur when you turned it off?
              Dave J 0 1 Reply Last reply
                @Corjan-Meijerink I do not have ‘navigate route as track’ enabled and neither was this setting turned off before this route was started. Generally, I navigate routes as routes.
                Sorry if this causes problems.
                iPhone 15 Pro
                CHIGEE AIO-6 LTE
                  Thanks for your reply. Could you then share the link to the route? 🙂
                    https://www.myrouteapp.com/en/social/route/13307319?mode=share
                    iPhone 15 Pro
                    CHIGEE AIO-6 LTE
                      I can confirm this issue won't be fixed in 5.1.
                      Handling waypoint with exact the same coordinates is actually more challenging than expected. Not something I thought would be the case beforehand.
                      Will investigate this later on. No other user ever reported the issue as it's almost impossible to manually place waypoints on exactly the same place.
                        @Corjan-Meijerink. Ok. Understand what you are saying but the exact position can be used if I save the point as a ‘Favorite’ like a Cafe. This Sunday, I am meeting a friend at a Cafe RV point from which we are doing a circular route from/to. Afterwards, we head are own way back home. Just thought I would give you a ‘use case’.
                        As an aside, the latest version 5.1.0-462 has just dropped an I really like the changes. The inclusion of compass with elevation on CarPlay is brilliant. As always, top job and thank you.
                        Time for some testing.
                        iPhone 15 Pro
                        CHIGEE AIO-6 LTE
                        • Routenplaner on iPad
                        • New Zealand Routes
                          Bull Tahr
                          Bull Tahr
                          J2FK
                          J2FK
                        • MyRouteApp (WebPlanner) development Roadmap
                          Philipp Kühn
                          Philipp Kühn
                          6.1k
                          Tom Grzelinski
                          Tom Grzelinski
