  4. Some routes opening slow and some fast
16 Posts 6 Posters 1.7k Views 3 Watching
  • ConiKost Offline
    ConiKost Offline
    ConiKost
    wrote on last edited by ConiKost
    I have a couple of routes in MRA. All contains some Via point and more shaping points. Route length about 250-300km. IMHO nothing special.
    My issue is, that I noticed in MRA on smartphone (tried my DMD T665 and iPhone 17 Pro Max, so not hardware related), when opening a route from my account, some just load in a few seconds while others can load 15-20 seconds on every opening.
    Why is that?
    Shiny!
    • Marinus van Deudekom Do not disturb
      You state different routes, do they all start from the same point. That could a diference
      • ConiKost Offline
        ConiKost Offline
        ConiKost
        Yes, the start all from the same point basically, but differ a little bit. Still, I don't see any common between them.
        Shiny!
        nomko 1 Reply Last reply
        • ConiKost ConiKost
          nomko Offline
          nomko Offline
          Banned
          @ConiKost said in Some routes opening slow and some fast:
          Diifers as in..... longer route? More waypoints/viapoints/shaping points? More POI's? Different map to be loaded?
          It could also be a bad recipient between your phone and the nearest transmission tower(s).
          Please provide more clarity.
          ConiKost 1 Reply Last reply
          • nomko nomko
            ConiKost Offline
            ConiKost Offline
            ConiKost
            @Nomko-Nomden said in Some routes opening slow and some fast:
            Lets take those two routes as example.
            Route1: 272,68km, 5 Via points (including start and end), 91 shaping points.
            -> Loads about 2-3 seconds when opening in app
            Image: clickme
            Route2: 250.57km, 5 Via points (including start and end), 35 shaping points.
            -> Loads about 15 seconds when opening in app
            Image: clickme
            Both routes go into the same direction.
            Surely not, since this happens on WiFi too. And WiFi speedtests are > 600mbps.
            Shiny!
            • ConiKost ConiKost
              Image: clickme
              Image: clickme
              Corjan Meijerink Online
              @ConiKost do you have the link to the route of image 2?
              I see POIs displayed, do you by any chance have a massive POI library selected to load / display on the map?
              • Hubert Thoring Offline
                @ConiKost
                What Corjan writes can be found here in the POI settings.
                If too much is selected, everything is always loaded and transferred, limited to 2000 POI ..
                  ConiKost Offline
                  ConiKost Offline
                  ConiKost
                  @Corjan-Meijerink said in Some routes opening slow and some fast:
                  See PN.
                  I have multiple POIs library uploaded, but only one is active on the route, which opens slow. The active one contains about ~80-120 POIs at max, that shouldn't be the cause?
                  Shiny!
                  • ConiKost ConiKost
                    See PN.
                    @ConiKost Sounds like something you can test yourself quite easily! 🙂
                    If you turn the POIs off, does it load quickly?
                    • ConiKost Offline
                      ConiKost Offline
                      ConiKost
                      @Corjan-Meijerink I did give a try and indeed it's faster. I this correct, that I need always to disable those POIs in web planer, as app does not seem to have an option for this per route? Or am I just blind and don't see it? Because that would be already very helpful, when you want to disable it.
                      Regarding the number, I had it wrong in mind. My POI category has ~270 points in it. Still I would not expect that much slow down? I mean, those are not relevant when loading the route initially? Maybe they could be just loaded later in the process?
                      Shiny!
                      • Corjan Meijerink Online
                        Thanks for confirming the POI's being a factor.
                        I will investigate this later but definitely not soon.
                        See this manual for showing / hiding certain POI groups for your entire profile / route: https://support.myrouteapp.com/en/support/solutions/articles/12000103938-manual-pois-
                          ConiKost Offline
                          ConiKost Offline
                          ConiKost
                          Thanks! 👍
                          I am confused. This is the procedere, how to do it website aka MRA webplanner, which I also did. I meant the Android/iOS navigation app. Or I am missunderstand here?
                          Shiny!
                            Switching on and off is only possible in the route lab, there is no function in the app
                            In the route lab:
                            • ConiKost Offline
                              ConiKost Offline
                              ConiKost
                              Thanks for confirming. That was my question, that I need to use the web planner and cannot use the app for that, to switch it on or off. So an option in app would be very handy 🙂
                              Shiny!
                              • ConiKost ConiKost
                                Nick Carthew Offline
                                There is an option in app. Tap Route lab from the mobile app to access the website.
                                  ConiKost Offline
                                  ConiKost Offline
                                  ConiKost
                                  @Nick-Carthew said in Some routes opening slow and some fast:
                                  Sure, but it's still the website, not a native app function 😉
                                  Shiny!
                                  ConiKost
                                  ConiKost
                                    Michele Skipper
                                    Michele Skipper
                                  • POI naming/text display
                                  • NC500 glitch
                                    Tenmill 0
                                    Tenmill 0
                                    Rezzonico Mauro
                                    Rezzonico Mauro
                                  • Tracklog correction
                                  • Android TTS question
