  4. Routes List Menu, Select Multiple Routes and ‘Save as’
12 Posts 6 Posters 2.1k Views 3 Watching
  • Big Al 1
    Big Al 1
    Big Al 1
    From the “Routes” list, ‘select’ more than one route by ticking in the leftmost box. Click ‘Save as’ at the bottom of the screen and select the type (.GPX 1.1 etc). This results in a ‘Please Wait’ meassge followed closely by the rotating circle (busy)…..and that’s it. Seems like the program is in a loop.
    I suspect there is a hidden “File has been saved……..Export/Download” (see photo) dialogue in the background going unanswered on multiple selects . Works OK when only one file is selected.
    e621fb2d-7298-44e2-8030-6ca8b6000858-image.png 797f0dda-2ff0-4b07-a3b2-d57a1fb3033a-image.png 15e14bec-0df7-41ac-868b-903a87a0c98f-image.png 07e867e1-2913-4c42-a74e-2a7bccf982cc-image.png
    • Big Al 1 Big Al 1
      @Big-Al-1 I have never saved multiple files from my phone so I replicated your test. I get the option to save the 3 chosen files in a Zip folder to my Files folder.
      • Guzzist
        ...the behavior demands on used browser. If "system browser" in MyRoute-App is used - this indeed will not save multiple selected routes. Other browsers will act more or less similar an will in such cases simply create a zip file.
        • Guzzist
          • b0hd1
            It would be great to be able to back up all the paths. Whether one by one, several at once, by folder, or even the entire directory. In my case, we have over 2500 paths, and it's impossible to back them up 10 at a time, which is the current limit.
            • https://t.me/MRa_by_b0hd1
            • YouTube: @demco17
            • Big Al 1
              Big Al 1
              Big Al 1
              Guzzist -I don’t understand ‘system browser’. I used Apple products, IPhone 14 and IPad. The multiple save doesn’t work. Tried my bike phone, a Google Pixel 8a and same again, doesn’t work. I don’t get any dialogues to choose where I save the files. I invoke MyRoute Web from the app and I only use the web route planner.
              So to sum it all up…..the multiple route save doesn’t work on my mobile hardware.
              Obviously, I can individually save the routes, but I typically split my rides into days, resulting in a lot of individual files. And the app obviously thinks it can be done or else there wouldn’t be a ‘save as’ option at the foot of the screen.
              • Big Al 1 Big Al 1
                @Big-Al-1 said in Routes List Menu, Select Multiple Routes and ‘Save as’:
                Try invoking the planner from your internet browser instead of from your app.
                Chrome, Firefox, Safari, whatever.
                  @Con-Hennekens said in Routes List Menu, Select Multiple Routes and ‘Save as’:
                  You’ve nailed it @Con-Hennekens, I get the same results as @Big-Al-1 when I use Route lab from the mobile app. In my original test I accessed my route library via the Safari browser on my iPhone.
                  • Aiello antonino
                    With iPad Air 4 and Safari browser, I tried selecting 3 paths and everything works perfectly
                    • Big Al 1
                      Big Al 1
                      Big Al 1
                      OK - using just Safari and selecting multiple files, the web version creates a zip file in the Downloads folder, which when unzipped, creates a folder with the GPX files in there.
                      Using the app directly on an Apple device, and doing the ‘save as’ from the route itself, the system saves the file on the iPad in the MyRoute-App folder. So it seems we have 2 different types of operation here…and one doesn’t work. Is this Ok with you guys that at My-Route?
                      No great sweat for me and I’m sure there are bigger fish to fry on the development front. Nice if it were fixed in the rewrite version.
                      Guzzist 1 Reply Last reply
                      • Aiello antonino
                        Ok! Exporting multiple files from the app's browser doesn't work, but it does work with individual files.
                        • Big Al 1 Big Al 1
                          Using the app directly on an Apple device, and doing the ‘save as’ from the route itself, the system saves the file on the iPad in the MyRoute-App folder. So it seems we have 2 different types of operation here…and one doesn’t work...
                          ...as I mentioned 😉
                          Big Al 1
                          Big Al 1
                            2.2k
                            2.0k
                          • MyRoute-app wedding
                            10.4k
                          • Altitude numbers size
                            RainerT
                            RainerT
