  4. Map "spinning" when standing still
110 Posts 33 Posters 52.7k Views 10 Watching
    @LE-DIZES-Freddy said in Map "spinning" when standing still:
    I just tried version 5.02 and the problem with the map spinning while stopped is still there.
    Happy holidays to everyone!
    Are you one of the BETA testers?
    LE DIZES Freddy
    LE DIZES Freddy
    LE DIZES Freddy
    @Nick-Carthew oui
      @LE-DIZES-Freddy is that on Android itself or in Android Auto?
      A big part of my fix for the map spinning caused a major issue on some Android Auto devices leading to the position not updating al all 🙂
        LE DIZES Freddy
        LE DIZES Freddy
        LE DIZES Freddy
        @Corjan-Meijerink bonsoir Cojan
        sur Android , Crossacall Action X5 MRA 5.0.2-441
          I won't make any further changes regarding this issue for now.
          To resolve the true core of the issue - which I attempted - another solution needs to be designed. My fix resulted in major Android Auto issues.
          In short: some GPS information (regarding accuracy) is missing on certain devices causing the spinning. However some Android Auto devices never report this information as the GPS is often very cheap (no offence). So I simply cannot say something like "if accuracy is missing, ignore the position update" which in reality is exactly what we'd need to do. When I tested this with simulations the spinning was indeed completely gone while when driving everything still worked as designed. But because those Android Auto devices never report certain GPS metadata, this solution cannot be used.
          Now why do other apps possibly not show this issue? We completely rely on GPS data and their accuracy while other apps (especially native ones) might use extra device information from internal accelerometers etc.
          Erik Plaggenborg 1 Reply Last reply
            Erik Plaggenborg
            Erik Plaggenborg
            Erik Plaggenborg
            @Corjan-Meijerink I use two android devices to navigate with MRA. One a Samsung S25+ and the other is the T865 from ThorkRacing. Both devices are only having a spinning map at a stand still, not while driving.
            Don't know if this information is useful, i didn't read this in this topic so thought the problem was a spinning map while driving. This never happend to my devices only at a complete stand still.
            Garmin XT3
            Samsung S25+
            • Erik Plaggenborg Erik Plaggenborg
              Erik Plaggenborg
              Erik Plaggenborg
              Erik Plaggenborg
              Yesterday i drove a route A2B and the only time the "spinned" was at a complete stand still. The map turnend about 180 degrees, the minute i started moving the map turned in the correct position. This kept on happening everytime i stopped for a turn or trafficlight.
              Garmin XT3
              Samsung S25+
                #57
                @Erik-Plaggenborg when the 441 update was rekeased I did a test with the T865X and for me the map didn’t spin at a complete stop. Are you using the T865 or like me the T865X. As fas as I know the difference those twi is the better screen and more interval memory
                peha 1 Reply Last reply
                  peha
                  peha
                  peha
                  The thread (at least how I meant it) is about the spinning when at a standstill; for me, there is no problem while moving. Unfortunately, the difficulties also occur on my phone (Samsung S22 Ultra) alone, without any Android Auto device involved, and they keep occurring with 5.02 as well. It happens at practically every stop, and almost every time the map then turns 180 degrees (facing the direction from where I came), causing the navigation to recalculate. Something must have changed compared to earlier versions-be it the app, the phone, or hardware conditions-because I did not have the problem this massively in the past. It drastically reduces the usefulness of the app, and it is not good news that seemingly not much can be done to solve this. 🙁 I do, however, appreciate the attempts to fix it, and I am hopeful that a new solution can be found and designed over time. I like the app a lot; it's been my everyday navigation app (and especially now, with free drive, even more so)-I believe in the team's ability to eventually find a fix for the phenomenon. 🙂🚀
                  MotoCon LE DIZES Freddy 2 Replies Last reply
                    I’ll definitely spend some more time! 🙂
                    peha LE DIZES Freddy 2 Replies Last reply
                    • peha
                      peha
                      peha
                      wrote on last edited by peha
                      #60
                      Thank you - much appreciated!
                      If there's a way I could help somehow - maybe with logs, or as a beta tester, if more are needed -, I'd gladly, please just let me know.
                      • peha peha
                        @peha said in Map "spinning" when standing still:
                        That in itself already is a strange phenomenon, since at speeds under a certain level, no recalculation should be triggered at all (because it is considered a stand still).
                        • peha peha
                          LE DIZES Freddy
                          LE DIZES Freddy
                          LE DIZES Freddy
                          @peha For me, the problem already existed with previous versions.
                            @Con-Hennekens yesterday I noticed that in both Freedrive and A2B route when I came to a complete stop the position marker turend. Most of the time 90degrees Right. It did not recalculante. I’ve never s’en it before. I was out with just my phone
                              Same for me (with the latest update!)
                              Had no problem last time on my bike but yesterday as well on my phone as on the AA screen in my car!
                              • Nick Watts
                                Nick Watts
                                Nick Watts
                                +1 same issue - every time I stop (at traffic lights, etc.) the map spins 180 degrees as if I'm facing the other way. Once I'm underway again it spins back and the navigation continues correctly.
                                Samsung S24 Ultra, fully patched and up to date.
                                No such issues with Google Maps or other nav programs.
                                • Albert van den Elsen
                                  #66
                                  In my opinion this has nothing to do with MRA or other nav tooling.
                                  I found this article.
                                  Sorry but I cant test it, perhaps there is a solution for you in it.
                                  If you don't try, you'll never know. Fingers crossed. Good luck.
                                  The Samsung Galaxy S24 Ultra is a fantastic device, but precisely because it is so large and packed with sensors, it can sometimes be extra sensitive to magnetic interference.
                                  Here are some specific steps and tips for your S24 Ultra to stop that "spinning":
                                  1. Calibrating via the hidden menu
                                    You can test and reset your Samsung's sensors directly:
                                  Open the Phone app and dial: #0#
                                  Tap the Sensor tile.
                                  Look for Magnetic Sensor. You will see a small circle with a line (the compass).
                                  If the line is red and shows a "0", it is not calibrated.
                                  Move your phone in a figure-8 motion until the line turns blue and a "3" appears. This indicates it is perfectly calibrated.
                                  Tap the 'Back' button a few times to exit the menu.
                                  1. Check your case (MagSafe accessories?)
                                    The S24 Ultra is often used with cases that contain magnets (such as MagSafe-compatible rings or wallet flaps).
                                  The culprit: Magnets in your case directly interfere with your S24 Ultra’s magnetometer.
                                  Test it: Take your phone out of the case and see if the map in Google Maps stays still. If it works correctly without the case, you’ll know the magnets in the case are causing the interference.
                                  1. Google Maps "Live View" calibration
                                    Sometimes the magnetic field in a city (due to trams, pipes, or reinforced concrete) is too unstable for a compass.
                                  In Google Maps, tap the blue dot (your location).
                                  Choose the option Calibrate with Live View.
                                  Use your camera to scan the buildings and street signs around you. The S24 Ultra then uses image recognition to lock in your direction, which is much more stable than the compass.
                                  1. Specific S24 settings
                                    Ensure your phone's "assistance" features are enabled:
                                  Go to Settings > Location > Location Services.
                                  Make sure Google Location Accuracy is turned on.
                                  Also, turn on Wi-Fi scanning and Bluetooth scanning. This helps your phone determine your position based on nearby routers, which results in less "drift" than using GPS alone.
                                  Do you happen to have a case with a magnet or a card holder on the back of your S24 Ultra?
                                  iPhone 15,
                                  Garmin Zumo XT3
                                  Carpuride W702 Pro
                                  Sena 20S EVO headset
                                  Harley Davidson Road King M8
                                  • Vincent Curren
                                    Vincent Curren
                                    Vincent Curren
                                    I also have had the issue navigating with an older Kyocera E7110 on the phone screen without Android Auto. 180 degree turns, usually settling on the opposite way to the direction I was traveling. Functionally, it's mostly a problem for me on a roads I don't know just after I've made a turn and have to stop for traffic or a red light. Under those conditions, it's easy for me to get confused about whether I'm going in the right direction.
                                    • Christoph Wallwey
                                      Christoph Wallwey
                                      Christoph Wallwey
                                      Same issue here on my iPhone Air. Managed to work around it with an automation in the shortcuts app.
                                        peha
                                        peha
                                        peha
                                        @Corjan-Meijerink Is there anything on the horizon, regarding potential updates, if/when a fix or workaround might be found? It seems, since the last update the app waits longer (i.e., there's a delay of several seconds) before the map spinning starts, but it's still there, unfortunately, and not a good experience, as already described ad nauseum in this thread. 😉 I understand there's no such thing as a definite date or promise of any kind, but may I ask if the problem is being investigated further - is this being worked on still? Thanks! 🙂
                                          #70
                                          • 4
                                          • 5
                                          • 6
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          TomOnTour
                                          TomOnTour
                                          Paul Steinberg
                                          Paul Steinberg
                                          peha
                                          peha
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
