  4. Map "spinning" when standing still
110 Posts 33 Posters 50.7k Views 10 Watching
  • MotoCon
    Some phone have not only GPS but also a hardware compass. These are able to "see" in which direction they are held. Phones that don't have a compass, extrapolate direction from movement. That gets very inaccurate while standing still. Then there are apps that that rely on location services only (I don't know if direction is taken from compass if available), and there are apps that have different methods of approaching hardware. It all is a little more complicated then one might think...
    • Donovan Smith
      Donovan Smith
      Donovan Smith
      same with me on i phone. not touching phone or anything. It flips and then flips back. doesn't happen every time but sometimes even when riding
      • peha
        peha
        peha
        I don't doubt that it's complicated. I also didn't mean to "blame", should it have come across like this, stating that Google Maps doesn't show this phenomenon, but rather point out that it is possible to somehow avoid this problem (i.e., there's hope). I do, however, wonder why (for my setup at least) the severity/frequency of the spinning has increased to a level where it occurs at practically every stop. 🙁 Something must have changed.
          @Con-Hennekens said in Map "spinning" when standing still:
          It is true what you say but when you have multiple navigation apps on your phone and use all of them also. And only one app have issues. Than it is pretty obvious that this app is the one which needs to fix it.
          I know it not easy to fix this. As @Corjan-Meijerink wrote. There so many different phones and not all have these issues.
            @M.-Schrijver When version 5.0.2 is released you may see an improvement.
            • LE DIZES Freddy
              LE DIZES Freddy
              LE DIZES Freddy
              I just tried version 5.02 and the problem with the map spinning while stopped is still there.
              Happy holidays to everyone!
              Nick Carthew Corjan Meijerink 2 Replies Last reply
                @LE-DIZES-Freddy said in Map "spinning" when standing still:
                Are you one of the BETA testers?
                  LE DIZES Freddy
                  LE DIZES Freddy
                  LE DIZES Freddy
                  @Nick-Carthew oui
                    @LE-DIZES-Freddy is that on Android itself or in Android Auto?
                    A big part of my fix for the map spinning caused a major issue on some Android Auto devices leading to the position not updating al all 🙂
                      LE DIZES Freddy
                      LE DIZES Freddy
                      LE DIZES Freddy
                      @Corjan-Meijerink bonsoir Cojan
                      sur Android , Crossacall Action X5 MRA 5.0.2-441
                        I won't make any further changes regarding this issue for now.
                        To resolve the true core of the issue - which I attempted - another solution needs to be designed. My fix resulted in major Android Auto issues.
                        In short: some GPS information (regarding accuracy) is missing on certain devices causing the spinning. However some Android Auto devices never report this information as the GPS is often very cheap (no offence). So I simply cannot say something like "if accuracy is missing, ignore the position update" which in reality is exactly what we'd need to do. When I tested this with simulations the spinning was indeed completely gone while when driving everything still worked as designed. But because those Android Auto devices never report certain GPS metadata, this solution cannot be used.
                        Now why do other apps possibly not show this issue? We completely rely on GPS data and their accuracy while other apps (especially native ones) might use extra device information from internal accelerometers etc.
                        Erik Plaggenborg 1 Reply Last reply
                          Erik Plaggenborg
                          Erik Plaggenborg
                          Erik Plaggenborg
                          @Corjan-Meijerink I use two android devices to navigate with MRA. One a Samsung S25+ and the other is the T865 from ThorkRacing. Both devices are only having a spinning map at a stand still, not while driving.
                          Don't know if this information is useful, i didn't read this in this topic so thought the problem was a spinning map while driving. This never happend to my devices only at a complete stand still.
                          Garmin XT3
                          Samsung S25+
                          • Erik Plaggenborg Erik Plaggenborg
                            Erik Plaggenborg
                            Erik Plaggenborg
                            Erik Plaggenborg
                            Yesterday i drove a route A2B and the only time the "spinned" was at a complete stand still. The map turnend about 180 degrees, the minute i started moving the map turned in the correct position. This kept on happening everytime i stopped for a turn or trafficlight.
                            Garmin XT3
                            Samsung S25+
                              #57
                              @Erik-Plaggenborg when the 441 update was rekeased I did a test with the T865X and for me the map didn’t spin at a complete stop. Are you using the T865 or like me the T865X. As fas as I know the difference those twi is the better screen and more interval memory
                              peha 1 Reply Last reply
                                peha
                                peha
                                peha
                                The thread (at least how I meant it) is about the spinning when at a standstill; for me, there is no problem while moving. Unfortunately, the difficulties also occur on my phone (Samsung S22 Ultra) alone, without any Android Auto device involved, and they keep occurring with 5.02 as well. It happens at practically every stop, and almost every time the map then turns 180 degrees (facing the direction from where I came), causing the navigation to recalculate. Something must have changed compared to earlier versions-be it the app, the phone, or hardware conditions-because I did not have the problem this massively in the past. It drastically reduces the usefulness of the app, and it is not good news that seemingly not much can be done to solve this. 🙁 I do, however, appreciate the attempts to fix it, and I am hopeful that a new solution can be found and designed over time. I like the app a lot; it's been my everyday navigation app (and especially now, with free drive, even more so)-I believe in the team's ability to eventually find a fix for the phenomenon. 🙂🚀
                                MotoCon LE DIZES Freddy 2 Replies Last reply
                                  I’ll definitely spend some more time! 🙂
                                  peha LE DIZES Freddy 2 Replies Last reply
                                  • peha
                                    peha
                                    peha
                                    wrote on last edited by peha
                                    #60
                                    Thank you - much appreciated!
                                    If there's a way I could help somehow - maybe with logs, or as a beta tester, if more are needed -, I'd gladly, please just let me know.
                                    • peha peha
                                      @peha said in Map "spinning" when standing still:
                                      That in itself already is a strange phenomenon, since at speeds under a certain level, no recalculation should be triggered at all (because it is considered a stand still).
                                      • peha peha
                                        LE DIZES Freddy
                                        LE DIZES Freddy
                                        LE DIZES Freddy
                                        @peha For me, the problem already existed with previous versions.
                                          @Con-Hennekens yesterday I noticed that in both Freedrive and A2B route when I came to a complete stop the position marker turend. Most of the time 90degrees Right. It did not recalculante. I’ve never s’en it before. I was out with just my phone
                                          • 4
                                          • 5
                                          • 6
                                          peha
                                          peha
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          Albert van den Elsen
                                          TomOnTour
                                          TomOnTour
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Paul Steinberg
                                          Paul Steinberg
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.5k
                                          • One crash today
                                          • Download club route folders
                                            peha
                                            peha
                                            Mosimann
                                            Mosimann
                                          • Elektrisch rijden
                                            John mq
                                            John mq
