  4. Map "spinning" when standing still
110 Posts 33 Posters 50.7k Views 10 Watching
  • peha
    peha
    peha
    wrote on last edited by peha
    #37
    @Corjan-Meijerink Are more beta testers needed? I'd be willing to test a little, if it helps (my setup is noted in the footer: Android with two AA-devices).
      I did see it on my normal navigation phone on a few trips. Today i use my daily phone, which i only use in the car for navigation (not on my bike). On this phone i saw the behaviour also
      Both were running Android Auto.
      On the bike it spins more than once on the same spot (but not constant) mostly back and forth. In the car mostly it spins only once. Just as soon as i stopped.
      Let's what the new version brings
      • Albert van den Elsen
        This issue may simply be due to a weak GPS signal. I don’t think it’s related to MRA.
        iPhone 15,
        Garmin Zumo XT3
        Carpuride W702 Pro
        Sena 20S EVO headset
        Harley Davidson Road King M8
          @Albert-van-den-Elsen my Guess is that it's the combination of some type of phones, mostly Android based and some AA/CP devices. I havent seen the issue at all.
            Yeah, that’s the annoying thing of these issues. It’s definitely device related so some have it, others do not. GPS positioning and especially on Android devices is not always as accurate as you’d hope.
            • peha
              peha
              peha
              #42
              With my Samsung S22 Ultra, it is reproducibly a problem that occurs with MyRouteApp, but not with Google Maps: Sitting on my couch at home, phone laying on a table (i.e., not moving at all, not being touched), after I have opened MRA on the phone, the "view direction" (map orientation) changes several times for about 90 or 180 degrees, the movement pauses some seconds and then moves again. When it finally settles, it doesn't point in the actual direction the phone faces. Moving the phone after it has "settled", the map doesn't react any longer (map not moving). The compass needle symbol changes from "triangle shape" (map rotation follows phone) to a "strike-through compass needle" (?). No AA device involved at this point. This happens only with MRA, Google Maps doesn't show any problems, and another navigation app I had (but have uninstalled a few days ago), Magic Earth, didn't either show this problem. For me, it's clearly isolated with MRA, and while I may have seen an occasional map spin in earlier versions, it is now a constant problem (as soon as the device doesn't move) and, unfortunately, dramatically reduces the actual usefulness of the app for navigation. Phone is the same; the only thing that has changed is, there have been security/firmware updates by Samsung over the years.
                It is also MRA related. Why?
                At least on my phones, only MRA has this problem. Maybe Here is the cause. I don't know
                But just like i wrote in other topics. There are other GPS related things which only occur in MRA and not in other navigation apps
                • MotoCon
                  Some phone have not only GPS but also a hardware compass. These are able to "see" in which direction they are held. Phones that don't have a compass, extrapolate direction from movement. That gets very inaccurate while standing still. Then there are apps that that rely on location services only (I don't know if direction is taken from compass if available), and there are apps that have different methods of approaching hardware. It all is a little more complicated then one might think...
                  • Donovan Smith
                    Donovan Smith
                    Donovan Smith
                    same with me on i phone. not touching phone or anything. It flips and then flips back. doesn't happen every time but sometimes even when riding
                    • peha
                      peha
                      peha
                      I don't doubt that it's complicated. I also didn't mean to "blame", should it have come across like this, stating that Google Maps doesn't show this phenomenon, but rather point out that it is possible to somehow avoid this problem (i.e., there's hope). I do, however, wonder why (for my setup at least) the severity/frequency of the spinning has increased to a level where it occurs at practically every stop. 🙁 Something must have changed.
                        @Con-Hennekens said in Map "spinning" when standing still:
                        It is true what you say but when you have multiple navigation apps on your phone and use all of them also. And only one app have issues. Than it is pretty obvious that this app is the one which needs to fix it.
                        I know it not easy to fix this. As @Corjan-Meijerink wrote. There so many different phones and not all have these issues.
                          @M.-Schrijver When version 5.0.2 is released you may see an improvement.
                          • LE DIZES Freddy
                            LE DIZES Freddy
                            LE DIZES Freddy
                            I just tried version 5.02 and the problem with the map spinning while stopped is still there.
                            Happy holidays to everyone!
                            Nick Carthew Corjan Meijerink 2 Replies Last reply
                              @LE-DIZES-Freddy said in Map "spinning" when standing still:
                              Are you one of the BETA testers?
                                LE DIZES Freddy
                                LE DIZES Freddy
                                LE DIZES Freddy
                                @Nick-Carthew oui
                                  @LE-DIZES-Freddy is that on Android itself or in Android Auto?
                                  A big part of my fix for the map spinning caused a major issue on some Android Auto devices leading to the position not updating al all 🙂
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    LE DIZES Freddy
                                    @Corjan-Meijerink bonsoir Cojan
                                    sur Android , Crossacall Action X5 MRA 5.0.2-441
                                      I won't make any further changes regarding this issue for now.
                                      To resolve the true core of the issue - which I attempted - another solution needs to be designed. My fix resulted in major Android Auto issues.
                                      In short: some GPS information (regarding accuracy) is missing on certain devices causing the spinning. However some Android Auto devices never report this information as the GPS is often very cheap (no offence). So I simply cannot say something like "if accuracy is missing, ignore the position update" which in reality is exactly what we'd need to do. When I tested this with simulations the spinning was indeed completely gone while when driving everything still worked as designed. But because those Android Auto devices never report certain GPS metadata, this solution cannot be used.
                                      Now why do other apps possibly not show this issue? We completely rely on GPS data and their accuracy while other apps (especially native ones) might use extra device information from internal accelerometers etc.
                                      Erik Plaggenborg 1 Reply Last reply
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        Erik Plaggenborg
                                        @Corjan-Meijerink I use two android devices to navigate with MRA. One a Samsung S25+ and the other is the T865 from ThorkRacing. Both devices are only having a spinning map at a stand still, not while driving.
                                        Don't know if this information is useful, i didn't read this in this topic so thought the problem was a spinning map while driving. This never happend to my devices only at a complete stand still.
                                        Garmin XT3
                                        Samsung S25+
                                        • Erik Plaggenborg Erik Plaggenborg
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Yesterday i drove a route A2B and the only time the "spinned" was at a complete stand still. The map turnend about 180 degrees, the minute i started moving the map turned in the correct position. This kept on happening everytime i stopped for a turn or trafficlight.
                                          Garmin XT3
                                          Samsung S25+
                                          • 4
                                          • 5
                                          • 6
                                          peha
                                          peha
                                          LE DIZES Freddy
                                          LE DIZES Freddy
                                          TomOnTour
                                          TomOnTour
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Paul Steinberg
                                          Paul Steinberg
                                          Bill Harrison
                                          Bill Harrison
                                          Erik Plaggenborg
                                          Erik Plaggenborg
                                          Nick Watts
                                          Nick Watts
                                          Forest
                                          Forest
                                          Donovan Smith
                                          Donovan Smith
                                          • Audio cuttet via Bluetooth
                                            Haug
                                            Haug
                                            35.5k
                                          • One crash today
                                          • Download club route folders
                                            peha
                                            peha
                                            Mosimann
                                            Mosimann
                                          • Elektrisch rijden
                                            John mq
                                            John mq
