  4. New App - dissapointed
19 Posts 10 Posters 5.8k Views 4 Watching
  • RetiredWingMan
    I don't have any problems doing a search and planning an A to B route without any Internet on my phone. Are you sure you have the required maps downloaded? I did notice that you have to have offfline mode enabled and you can't do scenic routes.
    • Rob Kelley Rob Kelley
      Hi
      I don't take any pleasure in writing this — I was really looking forward to the new app being released, checking everyday, but it doesn't seem to have addressed any of the issues I and others have reported.
      It still can't plan a A > B route without a data connection.
      It 'still' doesn't use the offline maps for the display on this screen making it useless:
      And this new screen design, loads of white space but I have to scroll for more buttons:
      Sadly I've not seen anything that's made think 'oh, that's nice'.
      I'd like to use MRA for all my nav but it's impossible for these reasons, I have to use a different Nav app that actually uses it's offline maps when offline.
      @Rob-Kelley I have never had a problem with offline maps or navigation. You can clearly see No internet in the first screenshot and no Wi-Fi or Data icons in the second screenshot.
      Rob Kelley 1 Reply Last reply
        You definitely have not downloaded the offline maps if that is an issue.
        Satellite maps won’t be available offline ever because that would be gigabytes of data rather than a few megabytes for the same area. That said, never thought of that so indeed a user won’t get a notification of that. Great idea to add something in that line.
        Horizontal scrollable buttons are great as the most important ones are at the left and this scales well across all devices and widely used now in many apps.
        The white space depends on the amount of details for the search result. Indeed, when not much available, the white space is a bit much but never felt disturbing.
        Edit: scenic routes can never be calculated offline but will show a nice message if you attempt this
        • Rob Kelley
          Rob Kelley
          Rob Kelley
          I've been using MRA for some years and understand offline maps and I do have them downloaded, I've raised these issues before (on FB and here) and been told that it won't plot a simple route without a data connection and offline maps are not used for that part for the app so now I'm getting mixed messages.
          This is from my App (I'm now updating the minor version)
          GSA1250
          HD Street Glide
          HD Sport Glide
          XT500 x 2
            Rob Kelley
            Rob Kelley
            Rob Kelley
            @Nick-Carthew said in New App - dissapointed:
            Correct there's no wifi or data - that's why this is an issue around 'offline' mode, I can't test offline mode and be online at the same time.
            Here you say A > B routes cannot be calculated when offline but you say you've never had a problem offline, you can see where the confusion is coming from.
            GSA1250
            HD Street Glide
            HD Sport Glide
            XT500 x 2
              The update is released today so forgive the community not yet knowing everything 😉
              Edit: Answers from a while ago don’t have to be relevant for this 5.0 update
              Offline maps are now used throughout the entire application!
                Rob Kelley
                Rob Kelley
                Rob Kelley
                @Corjan-Meijerink said in New App - dissapointed:
                Thanks, the issue I had was the satellite imagery not being offline - which makes total sense, the roads etc are loading nicely so good to see.
                GSA1250
                HD Street Glide
                HD Sport Glide
                XT500 x 2
                  @Rob-Kelley cool! If that solved it, nice.
                  As said, we can add a notice (which is a great idea) when being offline but you enabled satellite maps 🙂
                    Rob Kelley
                    Rob Kelley
                    Rob Kelley
                    wrote on last edited by Rob Kelley
                    If my phone is offline, (no wifi or data) it won't calculate a simple route, if I put the app into Offline mode when the phone does have a data conenction then it can calculate the route.
                    If the app detects the phone is offline, it puts itself into Offline mode, it then can't calculate the route and says it needs to be Online as per my screen shots.
                    GSA1250
                    HD Street Glide
                    HD Sport Glide
                    XT500 x 2
                      @Rob-Kelley I’d recommend downloading the offline maps again or even reinstalling.
                      If the app cannot calculate a route in offline mode when you say you have all maps there are 2 scenarios:
                      • user did not download (correct / all) maps
                      • an internal issue with the offline maps
                      • stuart marritt
                        stuart marritt
                        stuart marritt
                        Have just tried in offline mode with all Internet turned off and it works flawlessly for me
                        • D Griffin
                          D Griffin
                          D Griffin
                          I run almost every ride with off line maps! I downloaded the new version, undated my off line maps and planned my test route which I take everyday. Had no problems at all.
                          • Paul Steinberg
                            Paul Steinberg
                            Paul Steinberg
                            @Rob-Kelley hey just a thought, check that your offline maps have a checkmark beside them. In v4 I found that sometimes the downloads are interrupted and offline navigation won’t work until the downloads are completed.
                            See this thread. https://forum.myrouteapp.com/topic/10116/suggestion-prompt-to-update-downloaded-maps.?_=1762835124036
                            2022 R1250GS
                            Google Pixel 10XL
                            Android Auto
                            Chigee AIO6
                            • Adrian Avram
                              Same happened for me with all the maps freshly downloaded ...
                              From my point of view, internet should be used only to download new maps and display traffic information, just like other apps are doing (the ones that use offline maps)
                              Adrian
                              • Paul Steinberg Paul Steinberg
                                @Paul-Steinberg said in New App - dissapointed:
                                True, and this has not changed in V5. I think you have hit the culprit with this. People sometimes are so convinced they have their maps offline, but forget to check it 😉 To be honest, the method of downloading maps could benefit from some TLC.
                                • infohagentb.nl
                                  infohagentb.nl
                                  infohagentb.nl
                                  It looks like when you enable offline navigation in the settjngs, route calculation is working. (phone in airplane mode).
                                  When I switch to online navigation no route calculated possible.
                                  Message something went wrong.
                                  • infohagentb.nl infohagentb.nl
                                    @infohagentb.nl, yes, but that is only logical isn't it? In online mode you get a message that online calculation is not possible, and the suggestion to go to offline mode, which is enabled by a confirmation... Seems completely logical to me.
                                      In the next update I've added a warning when you go offline and you are using satellite maps to inform you they cannot load properly
                                      stuart marritt
                                      stuart marritt
                                      Rob Kelley
                                      Rob Kelley
                                      infohagentb.nl
                                      infohagentb.nl
                                      D Griffin
                                      D Griffin
                                      Paul Steinberg
                                      Paul Steinberg
                                      • Statement on map spinning
                                        hawebo
                                        hawebo
                                        1.7k
                                        Bart 9a 0
                                        Bart 9a 0
                                      • Electric Car Travel Mode
