  4. Problem Routeplanner between 2 points
21 Posts 8 Posters 9.0k Views 3 Watching
  • DAVID PUEYO TORRES DAVID PUEYO TORRES
    Hi Nomko.
    I attach the link:
    https://www.myrouteapp.com/route/open/12077792
    If you can help me I would be very grateful.
    @DAVID-PUEYO-TORRES For others to be able to open the route, It has to be set to public.
      DAVID PUEYO TORRES
      DAVID PUEYO TORRES
      Sorry!
      https://www.myrouteapp.com/route/open/12312848
      • nomko
        Banned
        wrote on last edited by nomko
        This would be the problem.
        Between waypoints 1 and 2 there are no more waypoints. Best is to place some extra waypoints before/after the Cardenal Samoré pass so you pass the border at that point (yellow marked part of the route).
        Waypoint 2 is placed far beyond the Cardenal Samoré pass giving MRA the opportunity to come up with a route you don't like.
        As you can see in my screenshot(s) i placed a waypoint before and after the border at Cardenal Samoré. This forces MRA to pass the border at this location. You don't have to do it like this, but placing 1 waypoint before the border should do the trick. And also change the map from OpenStreetMap to HERE. That will fix this issue also.
          DAVID PUEYO TORRES
          DAVID PUEYO TORRES
          Thank you.
          I've done what you're telling me, but it still doesn't work. I don't understand.
          Check again please: https://www.myrouteapp.com/route/open/12312848
          Even though I pay a monthly fee, I don't have HERE.
          What's strange is that it's always been this way, and a few weeks ago, I didn't get this error.
          Thank you for your help!!
            DAVID PUEYO TORRES
            DAVID PUEYO TORRES
              DAVID PUEYO TORRES
              DAVID PUEYO TORRES
              As you can see, the app was correctly generating the route before.
              • nomko
                Banned
                Do you have the Silver membership? Of so, then i understand this situation even better. With the Silver membership you don't have the HERE map. This comes with the Gold membership.
                And why pay per month? You can also have a life-time membership. You only pay once and enjoy the rest of your life of MRA!
                You get the Gold membership that comes with all the options and features of the Silver membership shipped with a lot of extra options and features!
                • Alex reds
                  Alex reds
                  Alex reds
                  I actually tried it myself, just like Nomko said, and it works. With the OpenStreetMap map, even though you can see the road, it makes you take a huge detour, while with the Here map it follows the route you’d expect.
                  • Alex reds
                    Alex reds
                    Alex reds
                    wrote on last edited by Alex reds
                    map here
                    • Alex reds
                      Alex reds
                      Alex reds
                      Anyway, even if the planning shows that detour, once you reach point 4 you just continue on the road, and when you get to point 5 you’ll carry on toward point 6 without any effect on the rest of the route.
                      • Alex reds
                        Alex reds
                        Alex reds
                        Not sure about this one… can we actually pass through here?
                        • Rob Veerman
                          Transitable con cadenas=passable with snow chains (depending on the time of the year, I suppose).
                            DAVID PUEYO TORRES
                            DAVID PUEYO TORRES
                            @Nomko-Nomden
                            I pay for the silver membership (2,95€/month).
                            Until now, I've been able to do that route without any problems. I don't understand why it won't let me now.
                            Do you know if they've changed something in the subscription that's why it doesn't include that now?
                            Thank you very much!
                            BMcG 1 Reply Last reply
                            • Alex reds
                              Alex reds
                              Alex reds
                              I’m not sure if they’ve changed it, but as far as I can see, with the Silver plan you can’t use the Here map — only with the Gold plan or with the MRA Navigation app.
                              • nomko nomko
                                @Nomko-Nomden not completely true. With a silver abo you for have the Here map but you can't compaire the route with TT and OSM
                                  @Marinus-van-Deudekom said in Problem Routeplanner between 2 points:
                                  Not correct. A Silver subscription only gives you access to the planning map from OpenStreetMap.
                                    @Nomko-Nomden
                                    Hi @DAVID-PUEYO-TORRES I don't think it is anything to do with subscriptions
                                    To me the problem appears to be with the MRA version of the OpenStreetMap map data
                                    On MRA using OpenStreetMap to calculate the route the path refuses to pass through the border post
                                    On the OpenStreetMap website the routing passes through the border post with no problem
                                    The normal way of getting around routing issues like this is to use the "offroad / skip" function,
                                    it is very often used to enable routes over rivers / ferry crossings
                                    add two points (4 & 5 ) similar to what I have shown either side of the border crossing
                                    then click point 5 & select the "offroad / skip" icon to route straight between 4&5
                                    MRA has their own version of the OpenStreetMap data & it is not always the same as that on the OSM site
                                    Its possible that the MRA version is out of date or that the snapshot that MRA took had some bad edits for the border post
                                    • MotoCon
                                      Yes, please don't blame any licensing changes, since there are none. Like @Brian-McG explained, there is likely a difference in versions of the OSM map between the one MRA uses, and OSM has online.
                                      @Nick-Carthew said in Problem Routeplanner between 2 points:
                                      With the exception of having a Navigation License too.
                                      Alex reds
                                      Alex reds
                                      DAVID PUEYO TORRES
                                      DAVID PUEYO TORRES
                                      • Online map settings
                                        MartinW
                                        MartinW
                                      • Real-time traffic
                                        Òscar
                                        Òscar
                                        Andy Nicholson
                                        Andy Nicholson
                                      • HERE map not calibrated
                                        MartinW
                                        MartinW
                                      • Myrouteappstay
                                        Bé Jeuring
                                        Bé Jeuring
                                      • Navigatie met DMD tablet
                                      • Show on the maps's button
