  2. MRA Café
  3. Garmin Drive App on iOS crashes on opening (New update from yesterday)
43 Posts 11 Posters 25.3k Views 4 Watching
  • Steve Lynch Steve Lynch
    @Jimmy-Dorough
    For me when I reinstall Garmin Drive it creates a second instance of the Device in the Bluetooth settings.
    For me I have to “forget” both then it will pair again.
    Jimmy Dorough
    Jimmy Dorough
    Jimmy Dorough
    @Steve-Lynch same. Isn't that. Will troubleshoot later.
      @Catalina said in Garmin Drive App on iOS crashes on opening (New update from yesterday):
      Hi everybody! Im sorry to hear that there are problems with the Zumo XT and the connector. We just made a bug fix for the GPX 1.1 BETA file. Could you try export it again and let me know if the problem still occurs?
      Hi Catalina,
      I tried it earlier using the Beta GPX Export and the the Garmin Drive App immediately crashed.
      It continues to crash their after.
      Was the change applied only for when using the connector?
      I’m on an iPad Pro.
      Steve.
      Catalina
      Catalina
      Catalina
      @Steve-Lynch Hi Steve,
      I applied the change to the GPX 1.1 BETA file, which also applies to the connector.
      Do you have this problem with all the GPX files? or only with the GPX 1.1 BETA?
      • Catalina Catalina
        Albert van den Elsen
        #26
        @Catalina
        Hi Catalina,
        I don't think MRA Connector is the issue.
        That works perfect for me.
        But the problem is on my iPhone with MRA planner and the export to Garmin Drive.
        Same result from my site. Garmin Drive Immideately crashed.
        But I figured out Garmin Drive is the big issue.
        I made an export from Garmin Explorer to Garmin Drive with the same result.
        In this case MRA was not involved.
        • Catalina Catalina
          Steve Lynch
          Steve Lynch
          Steve Lynch
          #27
          I previously tried the MRA GPX 1.1 Track/POI that crashed the Garmin Drive App.
          I also also exported a GPX File from my Ordnance Survey Account that crashed the Drive app too.
          Both of these were before your change though.
          I will try them both again tomorrow..
          • Catalina
            Catalina
            Catalina
            Hi @Albert-van-den-Elsen and @Steve-Lynch,
            I'm glad to hear that the connector is not the problem. I am interested in Garmins response to you Albert. Please let me know what their explanation is! Maybe with their explanation, we can change some things in our gpx export to make it work for the Garmin Drive App. If any other problems do occur with the connector, let us know.
            Reinhard-32 Albert van den Elsen 2 Replies Last reply
            • Catalina Catalina
              Reinhard-32
              Reinhard-32
              Reinhard-32
              #29
              @Catalina
              In this thread we are talking about the Garmin Drive App. The „save as“ functionality from MRA works fine but when you send the desired GPX file via Drive app to you ZumoXT the app crashed immediately and doesn’t start again. You have to reinstall the app and the game starts again.
              I have already opened a ticket at the Garmin service. The problem is known and the developers are working on it.
              Kindly regards
              Reinhard
              Montana 700i and Mac
              Albert van den Elsen 1 Reply Last reply
                It is definitely a Garmin issue not iOS.
                I have an older iPad that I use when I go on Tour.
                I never allow anything to automatically update on this device, including iOS.
                I have just installed iOS 14.15.1 on this older iPAD.
                The Garmin Drive App on this is Version 4.13.32
                I can and just have transferred files using the MRA Beta GPX Export and the Garmin Drive app and I get the Track and the Trip Planner versions on the Garmin XT.
                No issues with the Garmin Drive App 4.13.32 and iOS 14.15.1
                No issues on my Samsung S10 5G Phone either but I never allow automatic updates on that device either.
                @Steve-Lynch
                Garmin knows what the problem is, and they will come with an update, they only don’t know when. Could take a couple off weeks
                  @Steve-Lynch
                  Steve Lynch
                  Steve Lynch
                  Steve Lynch
                  @Hans-van-de-Ven-MRA-Master
                  Thanks for the update Hans. 👍
                  And to all those who tested as well. 👍
                  • Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    Just had a software update on the Garmin XT.
                    Not sure if its relevant to this issue but will re-install the Drive App on my iPad Pro and test.
                    • Steve Lynch
                      Steve Lynch
                      Steve Lynch
                      The update on the Zumo XT was 6.20.
                      Re-installed the Garmin Drive App on iPad Pro
                      Resynced my data to the device.
                      Exported a BETA GPX file
                      As soon as I opened the route in the Garmin Drive App it crashed and continues to crash there after.
                      Obviously not a relevant update to the current issue.
                      • Reinhard-32 Reinhard-32
                        @Catalina
                        • Catalina Catalina
                          @Catalina
                          This is the respons from Garmin:
                          <Dutch>
                          Bedankt dat u contact heeft opgenomen met Garmin Support.
                          Helaas is dit een bekend probleem. We gaan dit oplossen met een update van de app.
                          Wanneer dit gebeurd weten we nog niet. Excuus voor het ongemak.
                          Translation.
                          Thanks for contacting us.
                          Sorry to tell but this is a known problem for us. We're gone fix this in a update.
                          When this is gone happen we don't know yet.
                          Excuses for this inconvenience.
                          • Jimmy Dorough
                            Jimmy Dorough
                            Jimmy Dorough
                            Garmin just released an update and it appears to have fixed the problem. Fingers crossed.
                            Reinhard-32 Rob Veerman 2 Replies Last reply
                            • Jimmy Dorough Jimmy Dorough
                              Reinhard-32
                              Reinhard-32
                              Reinhard-32
                              #37
                              @Jimmy-Dorough Can you please clarify what you mean.
                              The Garmin drive app at my IPhone is still version 4.15.02 and no update is available.
                              Kindly regards
                              Reinhard
                              Jimmy Dorough 1 Reply Last reply
                                @Jimmy-Dorough The problem is fixed. After the update a GPX could be sent via Garmin Drive to the XT by iPhone.
                                  Jimmy Dorough
                                  Jimmy Dorough
                                  Jimmy Dorough
                                  @Reinhard-32 4.15.03 is out. Sometimes it’s not available to everyone on the App Store at the same time.
                                    Reinhard-32
                                    Reinhard-32
                                    Reinhard-32
                                    #40
                                    @Jimmy-Dorough ok, thanks. So we have to wait for this update.
                                    Update: the new release 4.15.03 appears in the app store now. I updated the app and it works.🙂
                                    Kindly regards
                                    Reinhard
                                    • Steve Lynch
                                      Steve Lynch
                                      Steve Lynch
                                      #41
                                      Yes no Garmin Drive crashes.
                                      I still get the issue of the last shaping point to the chequered flag being a dotted straight line in the Trip Planner on the XT.
                                      The Track is perfect.
                                      Hans said this was an MRA issue in another thread.
                                      • Steve Lynch
                                        Steve Lynch
                                        Steve Lynch
                                        #42
                                        Hi All,
                                        It looks like the issue regarding the last Shaping point to the Chequered flag being a straight line is now resolved using the GPX 1.1 Beta export on my iPad Pro.
                                        I have made a route Public called Mendip TT that transfers to the Garmin XT Trip Planner perfectly now.
                                        I personally never use Via Points but I also added one in a copy of the Mendip TT file and this transfers to the Garmin XT Trip Planner perfectly as well.
                                        Mendip TT with Via Point is also public.
                                        Thank you Catalina. 👍
                                        • Western31
                                          Western31
                                          Western31
                                          I have updated to 4.15.02 and the app starts without problems.
                                          iPad Pro 14.5.1
                                          • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
                                          Martin White
                                          Martin White
                                          Reinhard-32
                                          Reinhard-32
                                          Albert Renting
                                          Albert Renting
                                          Steve Lynch
                                          Steve Lynch
                                          Jimmy Dorough
                                          Jimmy Dorough
                                          Western31
                                          Western31
                                          Catalina
                                          Catalina
                                          Kemille
                                          Kemille
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
