  2. MRA Café
  3. Garmin Drive App on iOS crashes on opening (New update from yesterday)
43 Posts 11 Posters 25.3k Views 4 Watching
  • Steve Lynch
    Steve Lynch
    Steve Lynch
    I did one final check this morning by exporting a GPX file from my UK Ordanance Survey Maps account.
    Opened in the Drive App and does exactly the same thing, crashes the Garmin Drive App and crashes on opening thereafter.
    Lets hope Garmin fix this soon.
    • Jimmy Dorough
      Jimmy Dorough
      Jimmy Dorough
      The more people that contact Garmin about the issue, the more likely they are to do something about it. Hint hint.
      • Jimmy Dorough Jimmy Dorough
        Reinhard-32
        Reinhard-32
        Reinhard-32
        @Jimmy-Dorough I have already opened a ticked at Garmin.
        Kindly regards
        Reinhard
        Montana 700i and Mac
        • Albert van den Elsen
          Same problem.
          I downloaded the latest Garmin Drive version 4.15.02 on my iPhone 12.
          I have the latest IOS version installed.
          So far so good. Everytime I open Garmin Drive everything go's well.
          But.......
          When I try to export a Route from MRA Planner (iPhone) to Garmin Drive the app (Garmin Drive) complete crashes and loses connection with m Garmin Zumo XT.
          I don't know what causes this problem. It might be the MRA export is doing it or its Garmin Drive itself of the combination with IOS 14.5.1.
          iPhone 15,
          Garmin Zumo XT3
          Carpuride W702 Pro
          Sena 20S EVO headset
          Harley Davidson Road King M8
            Same problem.
            But.......
            Reinhard-32
            Reinhard-32
            Reinhard-32
            @Albert-van-den-Elsen The problem is the Garmin drive app. The app was updated to 4.15.02 4 days ago.
            Kindly regards
            Reinhard
            • Catalina
              Catalina
              Catalina
              wrote on last edited by Catalina
              Hi everybody! Im sorry to hear that there are problems with the Zumo XT and the connector. We just made a bug fix for the GPX 1.1 BETA file. Could you try export it again and let me know if the problem still occurs?
              Jimmy Dorough Steve Lynch Albert van den Elsen 3 Replies Last reply
              • Steve Lynch
                Steve Lynch
                Steve Lynch
                It is definitely a Garmin issue not iOS.
                I have an older iPad that I use when I go on Tour.
                I never allow anything to automatically update on this device, including iOS.
                I have just installed iOS 14.15.1 on this older iPAD.
                The Garmin Drive App on this is Version 4.13.32
                I can and just have transferred files using the MRA Beta GPX Export and the Garmin Drive app and I get the Track and the Trip Planner versions on the Garmin XT.
                No issues with the Garmin Drive App 4.13.32 and iOS 14.15.1
                No issues on my Samsung S10 5G Phone either but I never allow automatic updates on that device either.
                • Catalina Catalina
                  Jimmy Dorough
                  Jimmy Dorough
                  Jimmy Dorough
                  @Catalina I’ll have to try again after work. I deleted Drive, reinstalled it, but was unable to pair it this time. Could be yet another issue with Drive.
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @Jimmy-Dorough
                    For me when I reinstall Garmin Drive it creates a second instance of the Device in the Bluetooth settings.
                    For me I have to “forget” both then it will pair again.
                    Jimmy Dorough 1 Reply Last reply
                    • Catalina Catalina
                      Steve Lynch
                      Steve Lynch
                      Steve Lynch
                      #23
                      @Catalina said in Garmin Drive App on iOS crashes on opening (New update from yesterday):
                      Hi Catalina,
                      I tried it earlier using the Beta GPX Export and the the Garmin Drive App immediately crashed.
                      It continues to crash their after.
                      Was the change applied only for when using the connector?
                      I’m on an iPad Pro.
                      Steve.
                      Catalina 1 Reply Last reply
                      • Steve Lynch Steve Lynch
                        @Jimmy-Dorough
                        Jimmy Dorough
                        Jimmy Dorough
                        Jimmy Dorough
                        @Steve-Lynch same. Isn't that. Will troubleshoot later.
                          Hi Catalina,
                          I’m on an iPad Pro.
                          Steve.
                          Catalina
                          Catalina
                          Catalina
                          @Steve-Lynch Hi Steve,
                          I applied the change to the GPX 1.1 BETA file, which also applies to the connector.
                          Do you have this problem with all the GPX files? or only with the GPX 1.1 BETA?
                          • Catalina Catalina
                            #26
                            @Catalina
                            Hi Catalina,
                            I don't think MRA Connector is the issue.
                            That works perfect for me.
                            But the problem is on my iPhone with MRA planner and the export to Garmin Drive.
                            Same result from my site. Garmin Drive Immideately crashed.
                            But I figured out Garmin Drive is the big issue.
                            I made an export from Garmin Explorer to Garmin Drive with the same result.
                            In this case MRA was not involved.
                            iPhone 15,
                            Garmin Zumo XT3
                            Carpuride W702 Pro
                            • Catalina Catalina
                              Steve Lynch
                              Steve Lynch
                              Steve Lynch
                              #27
                              I previously tried the MRA GPX 1.1 Track/POI that crashed the Garmin Drive App.
                              I also also exported a GPX File from my Ordnance Survey Account that crashed the Drive app too.
                              Both of these were before your change though.
                              I will try them both again tomorrow..
                              • Catalina
                                Catalina
                                Catalina
                                Hi @Albert-van-den-Elsen and @Steve-Lynch,
                                I'm glad to hear that the connector is not the problem. I am interested in Garmins response to you Albert. Please let me know what their explanation is! Maybe with their explanation, we can change some things in our gpx export to make it work for the Garmin Drive App. If any other problems do occur with the connector, let us know.
                                Reinhard-32 Albert van den Elsen 2 Replies Last reply
                                • Catalina Catalina
                                  Reinhard-32
                                  Reinhard-32
                                  Reinhard-32
                                  #29
                                  @Catalina
                                  In this thread we are talking about the Garmin Drive App. The „save as“ functionality from MRA works fine but when you send the desired GPX file via Drive app to you ZumoXT the app crashed immediately and doesn’t start again. You have to reinstall the app and the game starts again.
                                  I have already opened a ticket at the Garmin service. The problem is known and the developers are working on it.
                                  Kindly regards
                                  Reinhard
                                  Albert van den Elsen 1 Reply Last reply
                                    @Steve-Lynch
                                    Garmin knows what the problem is, and they will come with an update, they only don’t know when. Could take a couple off weeks
                                      @Steve-Lynch
                                      Steve Lynch
                                      Steve Lynch
                                      Steve Lynch
                                      @Hans-van-de-Ven-MRA-Master
                                      Thanks for the update Hans. 👍
                                      And to all those who tested as well. 👍
                                      • Steve Lynch
                                        Steve Lynch
                                        Steve Lynch
                                        Just had a software update on the Garmin XT.
                                        Not sure if its relevant to this issue but will re-install the Drive App on my iPad Pro and test.
                                        • Steve Lynch
                                          Steve Lynch
                                          Steve Lynch
                                          The update on the Zumo XT was 6.20.
                                          Re-installed the Garmin Drive App on iPad Pro
                                          Resynced my data to the device.
                                          Exported a BETA GPX file
                                          As soon as I opened the route in the Garmin Drive App it crashed and continues to crash there after.
                                          Obviously not a relevant update to the current issue.
                                          Martin White
                                          Martin White
                                          Reinhard-32
                                          Reinhard-32
                                          Albert Renting
                                          Albert Renting
                                          Steve Lynch
                                          Steve Lynch
                                          Jimmy Dorough
                                          Jimmy Dorough
                                          Western31
                                          Western31
                                          Catalina
                                          Catalina
                                          Kemille
                                          Kemille
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
