  4. Navigation Option Show "Original Route" Does Not Display Consistently
22 Posts 8 Posters 11.8k Views 6 Watching
    @Brian-McG, I see you are using offline-mode. I suspect you have "Navigate Routes as Tracks" enabled. Tracks work best in online mode, because tracks van only be calculated online. If offline, you get a less optimal track. If offline use is a must for you, you would better disable "Route as Track".
    @Con-Hennekens nope, not navigating tracks & option is always disabled
    I normally navigates routes as you can see from previous post picture - blue line with multiple waypoints
    The option to display the "original route" (track) is a great idea/feature, it just needs to work better (& be more visible/greater contrast on the garmin washed out style!)
    others seem to be seeing a similar issue so there has to be a cause/reason
      wrote on last edited by BMcG
      @Con-Hennekens These statement confused me
      but they did get me thinking -
      I always operate in offline mode, basically airplane mode because my phone, a rugged Blackview BV6200 does not contain a sim card. It is only ever connected to internet via wifi at home or hotels when touring.
      So firstly if "tracks can only be calculated online" how is the "original route" (track) being calculated when I am using mra for navigation offline & how is it producing the "original route" (track)s show in my previous posts?
      Secondly what does this mean "you get a less optimal track" & why?
      So after a bit of playing about I think I may have found something -
      If I edit a route in the web planner or via the app website route lab link - when I try to navigate this route offline the "original route" (track) displayed in the navigation will as you say not be ""optimal"
      In fact they can be far from it. In the second picture the right turn at the roundabout with the track disappearing off a couple of hundred metres before is the same roundabout shown in my first post which shows very small calculation errors, in this example the track error is huge.
      What I have found is that if I take a route that has been created on the web planner & then edit it within the app route planner I get a different & what appears to be optimal "original route" (track)
      Yes this is the same round about as in the above posts but with the "original route" (track) completley hidden because it is perfectly matched to the route/road
      So my questions are why did you think the "original route" (track) in offline mode would be "less optimal"?
      & why is it that when the route is edited in the app planner it appears to calculate the optimal "original route" (track)?
      my guess is that there is some tiny difference between the Here online map & the downloaded offline map -
      this small difference upsets/causes a glitch in the calculation of the "original route" (track) such that it uses less points (sometimes a lot less points) to calculate the "original route" (track)
      • Bouke Ent
        a track is not a orginal route. a track is a list off points in a sequeance. so track is not fixed with a map or road. with online calculation the server connects the points and looks if there is a road or path on the map and tries to follow that. offline is less able to do that and then you get straight lines between the points. because a track has many points it seem it is following the road. for old basecamp users it was the same. if calculation was not done or offroad you also got straight lines between points.
        the white line can be 2 things. if you ride a route it can be the original route and it will show if you do recalculation and route takes a new way but it will follow the road. other option it is a route based on track information and then it depends on the calculation off the server or offline in app.
          @Con-Hennekens just got back from an 8days tour in The Eifel. Since réception is por over there I user offline navigation all the t8me. I’ve noticed the the original route under my actual route was mostly bespied the route. Sometimes, mostly while driving hairpins it was way Off. Could using the offline mode be cousinage this
            The calculated route is infinitely detailed 🙂
            Routes stored by us have a certain resolution to not take up way too much space when syncing them. This results in the minor differences so to say.
            The original route is a nice indicator of how you planned it so I personally would not be too bothered by it showing these minor divergences (in resolution due to missing coordinates, not actual route).
            BMcG 1 Reply Last reply
              @Corjan-Meijerink sorry the divergences of the "original route" are sometimes not minor, they are major, hundreds of metres, plus the issue is the system is not consistent
              if the original route can fit to the road correctly after the route is edited in the app route planner,
              why does it not fit correctly when the last edit is done on the web planner?
              • BMcG BMcG
                @Brian-McG, are you saying that a web-planned route that shows these imperfections does NOT show those imperfections if it got last edited in the in-app planner? That would be interesting...
                  @Con-Hennekens yes that is what I am saying, it would be nice if someone could replicate 😜
                  I am seeing the error in offline navigation
                  the route is edited in web planner - then synced to the device
                  the device is taken offline (airplane mode or wifi/network off)
                  the route is opened & navigation started with original route displayed
                  sometimes the web planned route appears ok with small errors as @Corjan-Meijerink expects
                  other times it can have larger errors & occasionally very huge errors
                  if I edit the web planned route in the app planner it seems to fit perfectly
                  I can understand the idea of trying to save storage, reduce data & speed up transfer
                  if the errors were always small then I would say - not a problem
                  when the error is large the original track line can obscure whole junctions & makes it difficult to read the map
                  for me the problem is the original route is not displayed consistently
                  I don't think a long term solution is to re-edit every route every time it is transferred/synced to the app
                  oh & don't forget the lack of contrast with a white original track
                  on the default garmin style map with this bug you can see nothing of the roads
                  MotoCon JP d 2 Replies Last reply
                  • BMcG BMcG
                    @Brian-McG, This is a good find. Thanks for your elaborate explanation. I will try to replicate this behavior.
                      Sometimes the errors with the "original track" can be huge,
                      with the above route the "original route" is wrong by hundreds & hundreds of metres
                      what causes the wrong calculation of the "original route" in offline mode?
                      I have also noticed that with a route created in the web planner,
                      if the navigation is started with a network connection, the "original route" will fit perfectly to the road
                      the same as when the route is edited in the app planner, you get a perfect fit
                      I only seem to get the bad fit of the "original route" when I start the navigation in offline mode
                      • BMcG BMcG
                        @Brian-McG, Tried to replicate this some days ago, but did not succeed... Although I have seen these straight lines before too, I was not able to replicate it in any circumstance you described. I was surprised by that and don't understand why. Old routes, new routes, offline, online, changed in the webplanner, I could not get the straight lines to appear. I'll try again later, probably after the holiday season.
                        • Marinus van Deudekom
                          I've seen the same behavior during my 8 days trip in the Eiffel 2 weeks ago. It was clear to see it when driving hair pins.
                          I was driving offline
                          • Nick Carthew
                            I think the solution is to open the route when you have wi-fi, irrespective of whether you will navigate online or offline. I had this happen to me a few weeks back, so from that point I have always opened the route with wi-fi before navigating and I haven't had the problem since.
                            Marinus van Deudekom BMcG 2 Replies Last reply
                              @Nick-Carthew my problem was that the WiFi was Shi... To
                                @Nick-Carthew yes the problem only appears if you try to start to try navigating with the device offline i.e. with no internet, no wifi connection
                                the route must be last edited in the web planner
                                if you open/edit on the device with an internet/wifi/online connection, it will recalculate the "original route" & you won't see the problem
                                as far as I am concerned this is a definitive hard reproducible bug
                                I can replicate it on 3 different devices with 2 different accounts
                                now I know there are several work arounds, it is not so much of a big issue for me
                                just a pain having to go through extra steps to get things to work
                                but as this seems to be the norm for mra, things never quite work as expected ... hey ho
                                • BMcG BMcG
                                  @Brian-McG when the Devs find some time maybe they can fix it For me also low priority
                                  • BMcG BMcG referenced this topic on
                                  • BMcG BMcG
                                    JP d
                                    JP d
                                    JP d
                                    @Brian-McG said in Navigation Option Show "Original Route" Does Not Display Consistently:
                                    Brian you absolute LEGEND! you found a work around! I just tried it. WiFi and 4G off.
                                    Offline maps and the original route was all over the place, hit the pencil icon and BOOM it follows the exact route!!
                                    This is such a great hack, I had turned off (Show Original route) as it was doing more bad than good.
                                    The downside is being taken down a single track thinking I don't remember planning this only to realise it wasn't part of the original route.
                                    Now thanks to you I can avoid that! Thank you so much!!!
                                    Hopefully the MRA team will come up with a fix in the next update @Corjan-Meijerink more work your way mate cheers 🍻.
                                    JP d
                                    JP d
                                      Giancarlo e
                                      Giancarlo e
                                    • Startpunt wijzigen
                                      Ad V
                                      Ad V
                                      Ed van Klink
                                      Ed van Klink
                                    • Route exporteren uit beta
                                    • Vrienden toevoegen
