  4. Navigation Option Show "Original Route" Does Not Display Consistently
10 Posts 7 Posters 173 Views 3 Watching
  • Brian McGundefined Offline
    When I load some routes for navigation the display of the "original route" beneath the planned navigation route does not conform closely to the road, it appears to straight line between some unidentifiable points
    On other routes it fits very close to the road & can only be seen to deviate a small bit when the navigation app is zoomed in to its maximum setting
    All the routes are planned with MRA on the PC & then navigated offline with MRA Navigation.
    Some routes may then be edited in the app
    Could someone please explain why with some of my routes the display of the "original route" differs?
    & while on the subject of the "original route" could the colour be changed from white to a much more contrasting colour?
    on a bright sunny day with a washed out garmin map style selected the white "original route" is virtually impossible to see
    (yes I know there are other map styles but occasionally for whatever reason my style reverts to the washed out bland garmin default colouring"
      sometimes the offset from the road for the "original route" (track) can be large
      when this happens & zoomed in at a junction the "original route" (track) can sometimes overlay the entire junction so the exit roads from the junction are hidden/obscured by the overlay
      This imo is borderline dangerous as instead of concentrating on the dangers of navigating the junction I am busy trying to guess which exit road from the junction the navigation system is telling me I need to take
      • JP dundefined Offline
        JP d
        I had the same problem so I turned off (show original route) from settings.
        Which is a shame because it is very useful to have if you decide to go on a detour and then want to get back to the original route at the nearest point. And just as a confirmation that that is the original route you planned.
        I'm sure it worked fine last year and belive it was a change or update somewhere that started to cause this issue.
          Adrian Avramundefined Offline
          Had the same problem, turned off the app, deleted cache and restarted app and everything was fine.
          Adrian
          Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
            @Brian-McG, I see you are using offline-mode. I suspect you have "Navigate Routes as Tracks" enabled. Tracks work best in online mode, because tracks van only be calculated online. If offline, you get a less optimal track. If offline use is a must for you, you would better disable "Route as Track".
            Brian McGundefined Marinus van Deudekomundefined 3 Replies Last reply
              @Con-Hennekens nope, not navigating tracks & option is always disabled
              I normally navigates routes as you can see from previous post picture - blue line with multiple waypoints
              The option to display the "original route" (track) is a great idea/feature, it just needs to work better (& be more visible/greater contrast on the garmin washed out style!)
              others seem to be seeing a similar issue so there has to be a cause/reason
                @Con-Hennekens These statement confused me
                but they did get me thinking -
                I always operate in offline mode, basically airplane mode because my phone, a rugged Blackview BV6200 does not contain a sim card. It is only ever connected to internet via wifi at home or hotels when touring.
                So firstly if "tracks can only be calculated online" how is the "original route" (track) being calculated when I am using mra for navigation offline & how is it producing the "original route" (track)s show in my previous posts?
                Secondly what does this mean "you get a less optimal track" & why?
                So after a bit of playing about I think I may have found something -
                If I edit a route in the web planner or via the app website route lab link - when I try to navigate this route offline the "original route" (track) displayed in the navigation will as you say not be ""optimal"
                In fact they can be far from it. In the second picture the right turn at the roundabout with the track disappearing off a couple of hundred metres before is the same roundabout shown in my first post which shows very small calculation errors, in this example the track error is huge.
                What I have found is that if I take a route that has been created on the web planner & then edit it within the app route planner I get a different & what appears to be optimal "original route" (track)
                Yes this is the same round about as in the above posts but with the "original route" (track) completley hidden because it is perfectly matched to the route/road
                So my questions are why did you think the "original route" (track) in offline mode would be "less optimal"?
                & why is it that when the route is edited in the app planner it appears to calculate the optimal "original route" (track)?
                my guess is that there is some tiny difference between the Here online map & the downloaded offline map -
                this small difference upsets/causes a glitch in the calculation of the "original route" (track) such that it uses less points (sometimes a lot less points) to calculate the "original route" (track)
                • Bouke Entundefined Offline
                  wrote last edited by Bouke Ent
                  a track is not a orginal route. a track is a list off points in a sequeance. so track is not fixed with a map or road. with online calculation the server connects the points and looks if there is a road or path on the map and tries to follow that. offline is less able to do that and then you get straight lines between the points. because a track has many points it seem it is following the road. for old basecamp users it was the same. if calculation was not done or offroad you also got straight lines between points.
                  the white line can be 2 things. if you ride a route it can be the original route and it will show if you do recalculation and route takes a new way but it will follow the road. other option it is a route based on track information and then it depends on the calculation off the server or offline in app.
                    @Con-Hennekens just got back from an 8days tour in The Eifel. Since réception is por over there I user offline navigation all the t8me. I’ve noticed the the original route under my actual route was mostly bespied the route. Sometimes, mostly while driving hairpins it was way Off. Could using the offline mode be cousinage this
                    Samsung S20FE mounted on a Quadlock and using Android Auto in my car
                      wrote last edited by Corjan Meijerink
                      The calculated route is infinitely detailed 🙂
                      Routes stored by us have a certain resolution to not take up way too much space when syncing them. This results in the minor differences so to say.
                      The original route is a nice indicator of how you planned it so I personally would not be too bothered by it showing these minor divergences (in resolution due to missing coordinates, not actual route).
                      Bouke Entundefined
                      JP dundefined
                      JP d
                      • Navigation Option Show "Original Route" Does Not Display Consistently
                      • Nav screen menu isn't fully displayed
                      • Compass Rose
                      • Using OSM maps on the MRA app.
                        Rainer Treichelundefined
                        Rainer Treichel
                      • Problèmes d'affichage sur écran
                      • update 4.4.0
                      • Restore deleted map and content
                      • Delete photos
