  2. Routes & Tracks
  3. Sharing downloaded GPX - shows incomplete
12 Posts 6 Posters 3.5k Views 3 Watching
  • Hans van de Ven MR.MRA Offline
    Share the gpx 1.1 file
    Rakesh Rao 1 Reply Last reply
    • RainerT Offline
      RainerT Offline
      RainerT
      .gpx 1.2 is an proprietary format from MRA.
      So better use a compatible format. See post above.
      RT
        @Rakesh-Rao share the route here and we’ll have a look at it. Make sure it’s set to public
        Rakesh Rao Offline
        Rakesh Rao Offline
        Rakesh Rao
        @Marinus-van-Deudekom
        https://www.myrouteapp.com/en/social/route/11615172?mode=share
        MyRouteApp + Navigator (always latest version, Lifetime Gold)
        Garmin Zumo XT
        Riding 2024 Triumph Tiger 1200 RallyExplorer
          Rakesh Rao Offline
          Rakesh Rao Offline
          Rakesh Rao
          @Hans-van-de-Ven-MR.MRA
          Does 1.1 behave differently than 1.2?
          Garmin Zumo XT
            Yes, gpx 1.2 is a route-track with via points, so it does needs via points in the file.
            Gpx 1.1 is a route, track and poi’s
            • Guzzist Online
              Guzzist Online
              I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing!
              So, there must me another reason, why the file isn't created correctly.
                When i save the route as gpx 1.2 the gpx file look normal and complete
                • Marinus van Deudekom Do not disturb
                  I’ve looked at your route and saw a few things
                  There’s a lot of shapingpoints that are not ON the route this giving Garmin devices the possibilty to mess up your route.
                  You say that you’re trying to export a 1.2 gpx. That Will only work on a Garmin device. Does your friend have a Garmin. If yes for the 1.2 format the advise is to add a couple of viapoints extra
                  The export of the 1.2 didn’t show up wrong on my end
                  Last
                  I’ve noticed that you set the route to motorcycle a profile that has not a lot Off d’avantages in it so that’s why I only use the car profile.
                    Last
                    @Marinus-van-Deudekom, your observations are probably correct, but neither of them are relevant for the question.
                    @Guzzist said in Sharing downloaded GPX - shows incomplete:
                    I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing! So, there must me another reason, why the file isn't created correctly.
                    I agree
                    • Rakesh Rao Offline
                      Rakesh Rao Offline
                      Rakesh Rao
                      Bottom line is that I need to share 1.1 if sharing gpx file
                      Thank you all for your help.
                      Garmin Zumo XT
                      RainerT
                      RainerT
                      Rakesh Rao
                      Rakesh Rao
                        Sytze van der Laan
                        Sytze van der Laan
                      • Hi again...Please help
