Sharing downloaded GPX - shows incomplete
After creating a route on MRA, i download it (.gpx 1.2) and share it with a friend. When he opens then file, it shows as 'incomplete' - per the screenshot attached. Why does this happen. Sharing the same route via link from MRA opens up correctly on MRA used by another friend.
@Rakesh-Rao share the route here and we’ll have a look at it. Make sure it’s set to public
Share the gpx 1.1 file
Does 1.1 behave differently than 1.2?
Yes, gpx 1.2 is a route-track with via points, so it does needs via points in the file.
Gpx 1.1 is a route, track and poi’s -
I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing!
So, there must me another reason, why the file isn't created correctly. -
When i save the route as gpx 1.2 the gpx file look normal and complete
I’ve looked at your route and saw a few things
There’s a lot of shapingpoints that are not ON the route this giving Garmin devices the possibilty to mess up your route.
You say that you’re trying to export a 1.2 gpx. That Will only work on a Garmin device. Does your friend have a Garmin. If yes for the 1.2 format the advise is to add a couple of viapoints extra
The export of the 1.2 didn’t show up wrong on my end
Last
I’ve noticed that you set the route to motorcycle a profile that has not a lot Off d’avantages in it so that’s why I only use the car profile. -
Last
I’ve noticed that you set the route to motorcycle a profile that has not a lot Off d’avantages in it so that’s why I only use the car profile.@Marinus-van-Deudekom, your observations are probably correct, but neither of them are relevant for the question.
@Guzzist said in Sharing downloaded GPX - shows incomplete:
I 'm sure, gpx 1.1 nor gpx 1.2 is the reason for incomplete created file. As the screenshot shows: only the first line is in the file; rest is missing! So, there must me another reason, why the file isn't created correctly.
I agree
Bottom line is that I need to share 1.1 if sharing gpx file
Thank you all for your help.
