  4. Waypoint names.
Waypoint names.
14 Posts 7 Posters 2.9k Views 4 Watching
  • Exrm193undefined Offline
    Exrm193
    I create a route, and I rename some waypoints. Fuel, Cafe, etc etc.
    I download the route on iPhone as 1.1 .gpx.
    I transfer to Garmin Drive and Drive sends it to Zumo.
    When I open the route on Zumo, waypoint names have changed....sometimes to "Area"...sometimes just to the co-ordinates. They are in the correct place, just the wrong name.
    Is this a Garmin problem or My Route App problem??
    Thanks
    • Exrm193undefined Exrm193
      Thanks
      @Simon-q It's a XT thing.
      If you make those waypoints Viapoints (handshape) and then rename then the XT wil show the flagsign and as far as I remember also the correct name.
        Exrm193
        I've tried that, still no luck??
        • Mzokkundefined Offline
          Unless the XT recognises that the waypoint is on the road you get Area. Use the Here maps and be accurate. If you are using OSM the actual position of the road can be 50m out in the worst cases and often 10m
            Exrm193
            I use HERE but it makes no difference. The waypoint is always exactly where I need it.
            • Brian McGundefined Offline
              Hi @Simon-q
              The issue with waypoint names is as @Marinus van Deudekom says, it is a Garmin thing
              the XT specifically renames points in a seemingly completely random way, it even can change the location by small amounts each time you rename the point !
              I don't believe it is to do with the position of the points but more to do with the Garmin/Here database for the road names not matching or somehow conflicting with your name of the point.
              The Garmin tries helpfully to "correct" what it thinks is an error but is in fact deleting/corrupting hours of your work
              The only way round it I know of is to check the points after they are loaded to the Garmin & rename the ones that have changed back to the name you original chose.
              Transfering via Basecamp or such does not help, the names are changed as they are loaded onto the device
              Normally navigate "Routes as Tracks" in Offline mode with Offline Maps
              • Guzzistundefined Offline
                if you have used route algorithm HERE and your way points are really exactly on the roads, may try to use for export gpx 1.0
                • Al Cohenundefined Offline
                  Al Cohen
                  Sorry for the late addition... I have an older Garmin nuvi. I am researching whether to replace it with the newer Zumo XT2 and keep using my MyRoute-app generated routes, or switch to a rugged phone running the MRA app. I started the 2 week trial period for the app and did some testing today...
                  I liked that the app shows via and shape markers and their associated colors! However, what I did not like was that there were no waypoint names displayed, just the name of the next road to turn on. The route worked perfectly, but I often rename my waypoints to GAS, LUNCH, OVLK (scenic overlook), and other useful names.
                  I use HERE to create my routes and export them as gpx 1.1 format. I mostly use shape points and very few via points. My old nuvi displays my waypoint name as I approach it - does anyone know if the XT2 does that as well?
                  I've read up on many threads regarding RUT behavior; gpx 1.1 versus 1.2; Android Auto versus running the app directly on Android phone; etc. If I go the phone/app path, I don't need it to do other things - just display my MRA created route without screwing up my waypoints! However, I also want to see my customized waypoint names. Is there some setting I'm missing to make the MRA app do this? Any other feedback/suggestions? Thanks!
                  Brian McGundefined Nick Carthewundefined 2 Replies Last reply
                  • Al Cohenundefined Al Cohen
                    @Al-Cohen I ditched my Garmin XT exactly due to the RUT problem that has been present in all garmin models for years, if you don't turn off the garmin recalculate function you will end up in a RUT loop at some point & it just completely ruins a day/trip
                    I opted for a large dedicated rugged android running MRA directly, it works very well
                    Due to the large battery there is no need to wire it to the bike, no charging/cabling issues & the best benefit is that when you plan your routes in MRA your routes are immediately available in the navigation app no need to worry about transfer the route or what format to use, the route is just there synced to your navigation device
                    & yes MRA does allow you to see the customized waypoint names but only stupidly 750m before you reach it as you can see from this thread
                      @Al-Cohen If you use MRA Navigation Next you need to turn on waypoint information to see the name and any notes that you have written displayed on screen.
                      Go to Navigation settings > Screen layout > Waypoints and then choose to show Eiter via points or all waypoints.
                      If you now go to Audio you can choose to have names and notes read aloud to you.
                        Al Cohen
                        Thanks guys. I had all Screen layout settings turned on, but Waypoint was set to Via so I changed it to All. During my 5 mile test yesterday I did not notice any Via names displayed, but I will try again and pay closer attention when I get within 750m.
                        Yesterdays test included 3 devices while driving my Kia Soul -- MRA Nav Next on my Samsung S24 phone, MRA displayed with Android Auto in the automobile, and my Gramin nuvi. I had previously turned off voice prompts, but have enabled that too for all waypoint notifications during the next test.
                        I will test again with just my phone and AA in the car. I'm pretty certain I only saw actual waypoint names displayed in the nuvi, but we'll see. It definately is nice to have my route synched automatically and not have to worry about exporting/importing them.
                        Last point -- regarding RUT behavior... I purposely skipped a Via point and continued on the route. It seemed as though the app was continually trying to direct me back to the Via points, even after I had gone through other Shape and Via points. In the Functional settings, the info box for "Skip waypoints automatically" states that viapoints are never skipped -- how then is this different from Garmin RUT behavior?
                          Al Cohen
                          To clarify the last paragraph - is seemed like the app continually tried to route me back to the skipped Via point, even after going past other Shape and Via points on the route. So how is this different than Garmin RUT behavior? (This behavior is why I almost never use Via points in my routes.)
                            @Al-Cohen I think maybe you misunderstand the nature of the Garmin RUT problem,
                            when a Garmin devices gets into a RUT it is not specifically to do with Via points,
                            when a Garmin Ruts the system is trying to route to 2 different points at the same time & it is impossible for the user to correct by skipping points, the only way to recover is restart the route/device.
                            With MRA a Via point will never be "automatically" skipped unless you actually pass/drive through it
                            So if you deviate off the route & pass a Via point you have to manually skip it by clicking the point icon in the top right or selecting a point further along the route after the Via point to continue on the path
                            Sometimes with MRA when you think you have skipped a point but the system may be busy & not register your manual skip input, so it looks like it is trying to take you back, you just have to re-skip the point
                              Al Cohen
                              I understand now. And a quick test did show the waypoint name, plus the audio. And I was able to skip a waypoint. So, I think all my issues/concerns are addressed! I'm no longer afraid to use Via points 🙂
                              Thanks again for the quick feedback. No Garmin XT2 for me - now I just have to decide on the right phone and mount 🙂
                              Mzokkundefined
                              Al Cohenundefined
                              Al Cohen
                              Exrm193undefined
                              Exrm193
                              • Tussenstop/routepunt toevoegen tijdens navigeren
                                Leike Lodiersundefined
                              • Gas Stations not displaying
                                Lenny Oundefined
                                Lenny O
                              • Layout My Routes
                                Alida Veenstraundefined
                                Alida Veenstra
                              • Font for the distance to the next turn to smal
                              • Geen routelijn
                              • Statement on map spinning
                              • 'Toon route' optie eenvoudiger beschikbaar maken
                              • Routekleur
