  4. Automatic switch Distance to next Via Point / Final Destination
20 Posts 8 Posters 2.8k Views 5 Watching
  • Rajpundefined Offline
    Rajp
    Hello, I know there is an option to switch the duration and distance summary between the next via point or the final destination, but you need to enter the options to switch between one or the other.
    Any chance we can add an “automatic” option in this setup?
    The “Automatic” option would then switch to displaying the duration and distance to the next via point and final destination on a timed basis, say every 3 to 4 seconds. That way you could see the summaries without having to manually select and switch. Of course, if there are no via points then just show the final destination summary
    Nick Carthewundefined Dae 0undefined 2 Replies Last reply
    • Rajpundefined Rajp
      @Rajp I understand why you are requesting this because this is my most used function with my SilverFox Bluetooth controller. 😀
      Jörgenundefined Con Hennekensundefined 2 Replies Last reply
        Jörgenundefined Offline
        @Nick-Carthew can you switch with the SilverFox between the displayed times?
        iPhone 12 pro (iOS 18.7.1)
        Oukitel RT3 pro (Andr. 14)
        Samsung XCover 4 (Andr. 9 Pie)
        More information about Workshops here
        • Jörgenundefined Jörgen
          @Jörgen Yes, as I said, it is my most used function.
            Guzzistundefined Offline
            @Nick-Carthew nice to switch this by remote controller Silverfox!
            I would like to do this also by my remote controller. But I need still to wait until the connection type for Remote 2 controller from DMD (Thork Racing) has been developed for MyRoute-App 😢
              @Nick-Carthew said in Automatic switch Distance to next Via Point / Final Destination:
              This is no default method is it? Did you remap buttons?
              Nick Carthewundefined Guzzistundefined 2 Replies Last reply
                @Con-Hennekens No re- map, it’s default.
                  Dae 0undefined Offline
                  Dae 0
                  @Rajp said in Automatic switch Distance to next Via Point / Final Destination:
                  I made this same suggestion many months ago, as Scenic does this and it’s brilliant. It allows you to gauge the remainder of the day without having to mess about pressing buttons etc.
                  It’s especially handy if leading a group, as someone inevitably asks over the intercom what time lunch is or if we’re on time for the end of day arrival.
                    @Con-Hennekens said in Automatic switch Distance to next Via Point / Final Destination:
                    ...This is no default method is it? Did you remap buttons?
                    Oh - how could be done a remap of remote controller buttons? I thought, only in settings, the correct remote controller must be selected.
                    • Guzzistundefined Guzzist
                      @Guzzist the controller (like the BarButtons) is sending letters (as you can type on a keyboard). For Android there is an App (sorry, forgot the name) where you can remap what the controller sends.
                      This is helpful for controller that do not send the Keys you need for MRA.
                      I do not know what key is needed to switch the display.
                      @Nick, can you open an editor and push the button for the display change and let us know what letter is sent?
                        This is all listed in the manuals 🙂
                        Go to https://www.myrouteapp.com/support > "MyRoute-app" > "Bluetooth controllers".
                        For SilverFox, it's an "A" 😉
                        Con Hennekensundefined Jörgenundefined 2 Replies Last reply
                          As much as I understand some people's wish for this automatic switch, I just want to highlight also that it might draw eyes to the screen until your desired information comes along. It could be considered dangerous.
                          Rajpundefined 1 Reply Last reply
                            @Corjan-Meijerink, I get it... there is no A in BarButtons 😉
                            (they could if they gave up repetitive zooming by long press).
                              Rajp
                              @Con-Hennekens alternate solution could be to tap that summary panel which then switches, tap again to switch back. So you can cycle through the various summary info by simply tapping that info summary panel.
                              white.mouseundefined Con Hennekensundefined 2 Replies Last reply
                                white.mouseundefined Offline
                                @Rajp I think this is a better idea.
                                Having the constant change show is too distracting for my liking.
                                And going to the menu every time to switch is also inconvenient.
                                The solution is indeed what @Raip suggests. Just click on the screen in the box to switch.
                                met een R1250RT met TFT en BMW Connected Ride App; de Garmin Zumo XT en My Route App in combinatie met de Carpuride W702 (voor Android op de Motor!)
                                  Too bad. Do you know someone who can extend the BarButtons code?
                                  I will ask a friend, but is not easy.
                                    That's already the case long time... 😉
                                      @Jörgen, yes, Joost, the developer of BarButtons... 😉 But he has been very quiet for a long time already.
                                        Rajp
                                        @Con-Hennekens on the phone app yes, but not on CarPlay, sorry I was referring to CarPlay screen
                                          @Corjan-Meijerink said in Automatic switch Distance to next Via Point / Final Destination:
                                          Hello Corjan,
                                          I tried this out and compared it with the information on the support page. I first realised that all letters have to be sent as a code in lower case and not in upper case as described. (for BarButtons N=n, D=d and C=c)
                                          I can not check this for Silverfox, but I think it should also be written in lower case here.
                                          Assuming Joost (or someone else) changes the code and you could send an ‘a’ for the display switch, would you then add this function for BarButtons in MRA?
                                          Rajpundefined
                                          Rajp
                                          Dae 0undefined
                                          Dae 0
                                          • Update 5.0.2 - Free drive
                                            Erik Plaggenborgundefined
                                            Erik Plaggenborg
                                            3.0k
                                          • How do I follow a track not Navigate it
                                            Benjamin Ralstonundefined
                                            Benjamin Ralston
                                          • geen visuele waarschuwing flitscamera (snelheidsradar)!
                                          • cant use app just to view map when riding
                                          • Waaldijk Afsluitingen
                                          • app wont start
                                          • Mobile data usage
