  2. Routes & Tracks
  3. IRAN planning problems
12 Posts 4 Posters 2.1k Views 1 Watching
  • DANIELZ77undefined Offline
    DANIELZ77
    Hi, i am trying to prepare tracks for Iran
    example: https://www.myrouteapp.com/it/social/route/10647187?mode=share
    it doesn't work properly and i do not understand why. I need to export in GARMIN XT and i know i have to use here maps.
    Open street shows me better maps but finally doesn't works.
    In garmin i will use openstreets Iran map normal or DEM.
    2nd problem roads names are in arabic is there a tips to see in english?
    Rob Veermanundefined Con Hennekensundefined 3 Replies Last reply
    • Nick Carthewundefined Nick Carthew moved this topic from [Web] Problems, Bugs and other Issues on
    • DANIELZ77undefined DANIELZ77
      Rob Veermanundefined Offline
      @DANIELZ77 Have you tried changing the profile of the route to car? I rode almost the same route in October 2024 using an OSM map on a Garmin ZUMO XT.
        @DANIELZ77 I used the OSM map that I downloaded from BBBike and it showed a lot of Latin names that sometimes were translated in a bit crooked way, but still understandable.
          Con Hennekensundefined Online
          @DANIELZ77, maybe not everyone knows this, but it is perfectly possible to load OSM maps to your Garmin device. If you do that, also the advised map to use in the planner is the OSM map.
          Check out https://garmin.bbbike.org/ if you are interested in this.
          DANIELZ77undefined 1 Reply Last reply
            DANIELZ77
            @Con-Hennekens Ty in advance for your precious help. But my problem is not on my garmin xt device but in myrouteappweb.... the planner doesn't work on Iran map using openstreet or here maps. I don't know what's wrong.
              DANIELZ77
              @Con-Hennekens i used bbbike and i know i can load on garmin those open maps. My problem is on myrouteweb planner that doesn't works on any map with iran.
                @DANIELZ77, commercial providers like TomTom lack an enormous amount of detail, I can see that, probably not allowed by the regime. The OSM map seems to be pretty detailed, though in Arabic. I opened your route and I can plan without problem. What exactly makes it unusable for you?
                  DANIELZ77
                  @Con-Hennekens i send 2 simple waypoints and the route is illogic ….. it goes inside the airport 😂 and the hotel destination is unavaiable. I dont know what to do
                    @DANIELZ77, if this is what you mean:
                    I don't see why this is illogical. just a road that goes near an airport. If you wat another route, just add shaping points.
                      DANIELZ77
                      This is the problem. waypoints not respected and i must pass inside airport 🙂 i think that iranias will shot me 🙂
                      • Tony 13undefined Offline
                        Tony 13
                        tried it on my Web browser, Firefox and all seemed to work OK. Weypoints in sensible places and route line followed the road. But only when using OSM, which aligns with Google satelite. HERE and Tom Tom looked useless. The HERE route does go through the airport, but not on the line shown in your screen shot
                        • Tony 13undefined Tony 13
                          DANIELZ77
                          @Tony-13 said in IRAN planning problems:
                          so considering that I have to create tracks that will have to run on the garmin XT.... what should I do? how should I set up myroute? thank you for your help
                          Tony 13undefined
                          Tony 13
                          DANIELZ77undefined
                          DANIELZ77
                          • Scrolling waypoint info
                          • Different route colour for later parts on same screen.
                            Robert Laudensackundefined
                            Robert Laudensack
                          • Updated beta! 5.0.1 (433)
                          • New update! (5.0.1)
                            1.1k
                          • "Show next waypoint information" - another hidden UI filter!
                            Andy Wundefined
                            Andy W
                          • Centering issue
                          • App restarting when Bluetooth keyboard connected (WunderLINQ)
