  4. Remotek-one firmware 2.0.0
38 Posts 8 Posters 22.0k Views 6 Watching
    https://support.myrouteapp.com/nl/support/solutions/articles/12000100670-bluetooth-controllers
    thanks @Corjan-Meijerink & @Stanisław
    the knowledge is often there, the trick is in finding it 😂
    BMcG 1 Reply Last reply
    • BMcG BMcG
      & with a little knowledge comes great danger ..... or at least a lot of more questions
      1. In the "Input Settings" section of MRA settings there is the option "Standard"
      The url "Bluetooth Controllers" does not mention anything about what "Standard" means.
      I understand it is difficult to relate a key press number as in the other controller tables when just describing a generic controller but is there a Standard Code = Function table?
      1. The Remotek controller works pretty much exactly as described in the table except for as @Stanisław says double click right arrow (3) is reserved by the controller to toggle between navigation apps selected in the Remotek app.
        This is quite a nice idea as it means it is possible to switch quickly & easily between MRA & Osmand, so it might work that you could be navigating with dual apps & switch between them with a simple click. So the documentation here for the Remotek controller is not correct.
      2. & this is the real reason for posting ...... there seems to be no input key mapped in the MRA Remotek setting for the function Skip Waypoint.
        Other controllers seem to be using a key code D for this function.
        Could MRA's Remotek Input settings table be configured to accept a key input, possibly a LongPress down arrow (4) to generate a code D so that it was possible to Skip Points ?
        (or is there skip point key code already?)
      3. I think something should be possible as I have used the KeyMapper app to set long press down arrow (4) to generate a code D & much to my surprise this allows me to Skip Points when I have the Input Setting set to "Standard"
        So Standard maybe almost a more useful setting to use when navigating with a Remotek
        Some other functions are different in Standard, the menu button seems to be double click down (4), hence my question 1
      For me option 3 where the MRA input setting table is modified to include a Skip Waypoint code for the Remotek controller would be the best solution
      • Stanisław
        I have just tested it with the 2.0 Remotek firmware and MRA 382 version. The doubleclick action still does not seem to work. With the 1.xx firmware doubleclick up opens the MRA menu, doubleclik down changes ETA selection. Should it work with 2.0 firmware as well?
        Staszek
          Hello everyone,
          I've been using the Remotek One with an iPhone Xr for a while, and it still has version 1.x.x.
          With the new MRA version from V4.3.6 it works very well now, and skipping WP now works with my solution.
          Important: Under Settings on the iPhone!!
          • Under: Accessibility \ Keyboards & text input \ set the keyboard control to "Off". Otherwise I have the problem that the MRA crashes outside of navigation. But with the setting selected here to "Off" it always works very well.
          With the MRA input setting, then as a Remotek One, the following works very well, but you have to make sure that the BT Remotek One keyboard is set to iOS, i.e. press the two arrow keys at the top and bottom together and wait to see if it flashes red and green for iOS. If it's green and green you have to repeat it again and then the red and green flashes briefly. "red, green stands for BT button as iOS" because "green, green stands for BT button as Android.
          Result of my application in the MRA navigation under iOS:
          • Arrows "left, right, up, down," pan over the map.
          • Arrow "+" / "-" corresponds to zooming
          • Arrow DC right, click twice quickly then release, = skip WP.
          • and other functions which I will describe separately....
          The correctly selected basic settings are important, if the above does not work, the BT keyboard must be reset once by pressing "arrow up, and + and -" at the same time for more than 5 seconds until it flashes red. Then delete the pairing under BT in the iPhone and pair it again on the iPhone. Then set it up for iOS as described above, etc.
          Good luck, I am very happy with my iOS solution.
          Best wishes from Münster
          Hallo zusammen,
          ich hab ja schon länger das Remotek One mit einem iPhone Xr im Einsatz, dieses immer noch mit der Version 1.x.x.
          Mit der neuen MRA Version ab V4.3.6 geht es jetzt sehr gut, auch das WP überspringen geht jetzt mit meiner Lösung.
          Wichtig: Unter Einstellungen am iPhone !!
          • Unter : Bedienhilfen \ Tastaturen & Texteingabe \ die Tastatursteuerung auf "Aus" zu stellen. Ich habe sonst das Problem das die MRA außerhalb der Navigation abstürzt. Mit der aber hier gewählten Einstellung auf "Aus" geht es immer sehr gut.
          Bei der MRA Eingabeeinstellung, dann als Remotek One geht folgendes sehr gut, dabei ist aber darauf zu achten das die BT Remotek One Tastatur auf iOS steht heißt, die zwei Pfeiltaste oben unten zusammen drücken und warten ob es kurz rot, grün für iOS blinkt, bei grün, grün muss man es noch einmal wiederholen dann kommt das kurz rot, grün blinken. "rot, grün steht für BT Taste als iOS" denn "grün, grün steht für BT Taste als Android.
          Ergebnis bei meiner Anwendung in der MRA Navigation unter iOS:
          • Pfeile "links, rechts, oben, unter," über die Karte schwenken.
          • Pfeil "+" / "-" entspricht dem Zoomen
          • Pfeil DC rechts, zwei mal kurz klick dann loslassen, = WP überspringen.
          • und weitere Funktionen die beschreibe ich aber separat....
          Wichtig sind die richtig gewählten Grundeinstellungen, wenn das oben beschriebene nicht gehen sollte muss die BT Tastatur einmal resettet werden indem man "Pfeil oben, und + und - " gleichzeitig für mehr als 5sek. drückt, bis es rot blinkt. Danach auch die Kopplung unter BT im iPhone löschen und neu am iPhone koppeln. Danach dann wie oben beschrieben für iOS einstellen usw.
          Viel Erfolg, ich bin für meine iOS Lösung damit sehr zufrieden.
          VG aus Münster
          Stanisław 1 Reply Last reply
            Hello everyone,
            Hallo zusammen,
            VG aus Münster
            @Hubert-Thoring thank you for the info, I will test it with my backup phone which is an old Iphone. Currently my main solution for MRA is an Android phone and it works fine with 1.xx firmware. My question was triggered by the info that 2.xx is now supported by MRA, I wanted to check it.
            Staszek
            Dave J 0 1 Reply Last reply
            • Stanisław Stanisław
              @Stanisław There is a Remotek Firmware 2.1 in beta at the moment and the DC functionality works correctly as previously stated in the MRA Support Area.
              Ducati Multistrada V4 Rally
              iPhone 18 Pro
              CHIGEE AIO-6 LTE
              Google Pixel 6 Pro
              • Dave J 0 Dave J 0
                @Dave-J-0 Where is it accessible? I can see nothing more then 2.0 in the remotek application nor on www.remotek.no website.
                Staszek
                  @Stanisław There was a mention recently on Remotek Facebook saying about the new firmware and about gaining access to the new firmware beta if you wanted to test. The link to the post: https://m.facebook.com/story.php?story_fbid=pfbid0ty4HfaUsQSxyq8XoawKJHG37ztswACjNVP4aX76QXccD3AFBajqnYiw5NYoGkc3Bl&id=100086173189244
                  iPhone 18 Pro
                  CHIGEE AIO-6 LTE
                  Google Pixel 6 Pro
                  • Dave J 0 Dave J 0
                    @Dave-J-0 Yes, I have already found it on FB, thanks!
                    Staszek
                      @Stanisław
                      @Dave-J-0
                      @Brian-McG
                      For your information:
                      This now works as described in the appendix, after the new MRA update V 4.3.6 with the Remotek One V 1.1.2.
                      Thanks for this @Corjan-Meijerink , a translation into English will be provided later.
                        @Stanisław
                        @Dave-J-0
                        @Brian-McG
                        @Corjan-Meijerink :
                        How can I upload a file as a PDF here?
                          @Corjan-Meijerink :
                          @Hubert-Thoring pdf is not possible.
                          Glad it all works as intended 🙂
                            @Stanisław
                            @Dave-J-0
                            @Brian-McG
                            a translation into English ....
                            • Stanisław
                              I tested Remotek-one yesterday with new android tablet and +/- buttons don't work properly, no zoom but panning instead of it. Tested with both 2.1 and 1.1.2 firmware versions, with the phone the same. Could anyone confirm that it is a problem of the new version of MRA?
                              Staszek
                                @Stanisław Have you selected Remotek One as input device in MRA?
                                  @Corjan-Meijerink yes, of course, and before it worked correctly with firmware 1.1.2. What's more - zooming does work on initial screen with the map but not in the navigation mode, that's why I suppose it can be related to the recent changes in the app.
                                  Staszek
                                  Corjan Meijerink Hubert Thoring 3 Replies Last reply
                                    @Stanisław hmm no clue then.
                                    As discussed in this thread, it all worked as intended and we haven’t changed anything regarding this.
                                    Maybe @Hubert-Thoring can test his.
                                      #27
                                      @Stanisław
                                      So, everything is going very well for me since the V4.3.6 also more than zooming and panning the map, the same applies to the latest app V4.3.8 still exactly as described in the previous list here in the thread.
                                      Note: I use iOS with an iPhone Xr with the old Remotek One version 1.x.x as delivered in 6.6.2024. I have no indication of the version, for that I would need an Android phone and the Remotek One app which is not available for iOS.
                                      Important: with iOS iPhone mobile phone
                                      • Keyboard Control Off
                                      • Input keyboard on Remotek
                                      • Set Remotek One to iOS
                                      I can only give my support for iOS / iPhone application.
                                      Best regards Hubert 👋
                                        #28
                                        @Stanisław
                                        Here's a video, for a better view, it works more than well for me 👋
                                        Link zum Video von Remotek One und MRA V4.3.8
                                          @Stanisław
                                          @Hubert-Thoring Thank you for the video. I have checked once more and found the reason, I have just uninstalled the Remotek application now and it started to work - I mean zoom. What's more, in this case right doubleclick works as skip next waypoint, with application installed it was covered by switching to another application, set up in the settings. So it is almost good now. The only problem I can see is switching to the top view mode by zooming or panning. It is quite strange and afterwords I can not go back to the dynamic mode using left doubleclick. It is quite random, I will test it more and check if it is a real problem.
                                          Staszek
                                          MartinW 1 Reply Last reply
                                          MartinW
                                          MartinW
                                          TenWheels
                                          TenWheels
                                          • Béta to no-béta
                                            Parantapa
                                            Parantapa
                                            John Matthews 0
                                            John Matthews 0
