  4. Remotek-one firmware 2.0.0
38 Posts 8 Posters 21.2k Views 6 Watching
  • Dave J 0 Dave J 0
    @Stanisław There was a mention recently on Remotek Facebook saying about the new firmware and about gaining access to the new firmware beta if you wanted to test. The link to the post: https://m.facebook.com/story.php?story_fbid=pfbid0ty4HfaUsQSxyq8XoawKJHG37ztswACjNVP4aX76QXccD3AFBajqnYiw5NYoGkc3Bl&id=100086173189244
    @Dave-J-0 Yes, I have already found it on FB, thanks!
    Staszek
    • Stanisław Stanisław
      @Stanisław
      @Dave-J-0
      @Brian-McG
      For your information:
      This now works as described in the appendix, after the new MRA update V 4.3.6 with the Remotek One V 1.1.2.
      Thanks for this @Corjan-Meijerink , a translation into English will be provided later.
        @Stanisław
        @Dave-J-0
        @Brian-McG
        @Corjan-Meijerink :
        How can I upload a file as a PDF here?
          @Corjan-Meijerink :
          @Hubert-Thoring pdf is not possible.
          Glad it all works as intended 🙂
            @Stanisław
            @Dave-J-0
            @Brian-McG
            a translation into English ....
            • Stanisław
              I tested Remotek-one yesterday with new android tablet and +/- buttons don't work properly, no zoom but panning instead of it. Tested with both 2.1 and 1.1.2 firmware versions, with the phone the same. Could anyone confirm that it is a problem of the new version of MRA?
              Staszek
                @Stanisław Have you selected Remotek One as input device in MRA?
                Stanisław 1 Reply Last reply
                  @Corjan-Meijerink yes, of course, and before it worked correctly with firmware 1.1.2. What's more - zooming does work on initial screen with the map but not in the navigation mode, that's why I suppose it can be related to the recent changes in the app.
                  Staszek
                  Corjan Meijerink Hubert Thoring 3 Replies Last reply
                    @Stanisław hmm no clue then.
                    As discussed in this thread, it all worked as intended and we haven’t changed anything regarding this.
                    Maybe @Hubert-Thoring can test his.
                      #27
                      @Stanisław
                      So, everything is going very well for me since the V4.3.6 also more than zooming and panning the map, the same applies to the latest app V4.3.8 still exactly as described in the previous list here in the thread.
                      Note: I use iOS with an iPhone Xr with the old Remotek One version 1.x.x as delivered in 6.6.2024. I have no indication of the version, for that I would need an Android phone and the Remotek One app which is not available for iOS.
                      Important: with iOS iPhone mobile phone
                      • Keyboard Control Off
                      • Input keyboard on Remotek
                      • Set Remotek One to iOS
                      I can only give my support for iOS / iPhone application.
                      Best regards Hubert 👋
                        #28
                        @Stanisław
                        Here's a video, for a better view, it works more than well for me 👋
                        Link zum Video von Remotek One und MRA V4.3.8
                          @Stanisław
                          @Hubert-Thoring Thank you for the video. I have checked once more and found the reason, I have just uninstalled the Remotek application now and it started to work - I mean zoom. What's more, in this case right doubleclick works as skip next waypoint, with application installed it was covered by switching to another application, set up in the settings. So it is almost good now. The only problem I can see is switching to the top view mode by zooming or panning. It is quite strange and afterwords I can not go back to the dynamic mode using left doubleclick. It is quite random, I will test it more and check if it is a real problem.
                          Staszek
                            martin-phogel.de
                            martin-phogel.de
                            martin-phogel.de
                            Exactly the same experience here. With the Remotek app installed, zoom in/out works on the overview map, but not when navigating (panning up/down instead). With the app uninstalled, zooming works when navigating as well. The only downside is the missing DC right to switch apps, but that's acceptable.
                            Thanks @Stanisław for this tip - I would never have thought of that by myself!
                            • TenWheels
                              TenWheels
                              TenWheels
                              The exact same thing happens to me. When I enable the Accessibility service in the Remotek app, the remote control no longer responds as expected while driving a route. I will send an email to Remotek with my findings. With the Accessibility service disabled, switching between the two profiles no longer works.
                              Android 14, Remotek firmware 2.1.0, MRA 4.3.8
                              • TenWheels TenWheels
                                martin-phogel.de
                                martin-phogel.de
                                martin-phogel.de
                                @TenWheels said in Remotek-one firmware 2.0.0:
                                But the question is whether a change in the Remotek app is helpful because zoom in/out works in the MRA overview map; the problem only occurs during navigation. Obviously, MRA interprets the keyboard codes sent by the controller differently.
                                  @Martin-Wilcke open an editor and push the Remotek button to see which code (which letter) is send, that helps to see problems.
                                    martin-phogel.de
                                    martin-phogel.de
                                    martin-phogel.de
                                    #34
                                    @Jörgen said in Remotek-one firmware 2.0.0:
                                    Yes, that can be done. But this shows the codes that are sent directly from the controller. However, the problem discussed here only arises if the Remotek app is activated and intercepts and modifies the codes sent.
                                    I would have to place the app between the controller and the editor to see this, but I don't know how.
                                    But I'm not seeking this any further because I don't care. I use the controller without the Remotek app activated anyway because without the app, DC3 (double-click on button 3) skips the upcoming route point, which I like to use. With the Remotek app activated, DC3 switches between configurable apps (e.g. MRA and Google Maps), which I don't need.
                                    • TenWheels
                                      TenWheels
                                      TenWheels
                                      Remotek has just released an update on the Play Store, and now the remote control works as intended. I'm happy about it!
                                      It's wonderful when a software issue is addressed quickly and effectively. It makes life so much easier 🙂
                                        martin-phogel.de
                                        martin-phogel.de
                                        martin-phogel.de
                                        @TenWheels
                                        Excellent news! Will give it a try later…
                                          #37
                                          @TenWheels
                                          @Stanisław
                                          @Brian-McG
                                          @Dave-J-0
                                          @Martin-Wilcke
                                          Hey Corjan, I have to ask again here, because it only crashes with the really best MyRouteApp for me as described below with the MRA navigation. All other apps such as GuRuMaps, Kurver, Google Maps, etc. have no problem with this.
                                          I turn off the keyboard control in the MRA navigation, but actually I could use even more Remotek One functions, such as switching between two apps in the test. That's exactly what I'm missing because I compare MRA with curvy, sorry I just like to test, ... Don't worry I like MRA better.!
                                          Starting point:
                                          Base: iOS, iPhone Xr and then the accessibility in iOS with activated keyboard control .... and the Remotek One.
                                          Can operate the normal MRA app but in the MRA navigation the MRA app always crashes after a short time, as already described elsewhere in the past. Can there perhaps be an MRA reason because the other users here also have problems with the Remotek app on Android ... or am I the only iPhone iOS user in the application here.
                                          VG
                                          Hey Corjan, ich muss hier noch einmal fragen, da es bei mir nur bei der wirklich für mich besten MyRouteApp so wie untern beschrieben weiterhin mit der MRA Navigation zum Absturz kommt. Alle anderen Apps wie GuRuMaps, Kurviger, Google Maps usw. haben damit kein Problem.
                                          Ich schalte bei der MRA Navigation die Tastatursteuerung aus, aber eigentlich könnte ich noch mehr Remotek One Funktionen nutzen wie zum Beispiel zwischen zwei Apps im Test zu wechseln. Genau das fehlt mir gerade weil ich MRA mit Kurviger vergleiche, sorry ich teste halt gerne, … Keine Angst MRA gefällt mir besser.!
                                          Ausgangsbasis:
                                          Basis: iOS, iPhone Xr und dann die Bedienungshilfe im iOS mit eingeschaltete Tastatursteuerung …. und der Remotek One.
                                          Kann die normale MRA App bedienen aber in der MRA Navigation stürzt die MRA App immer nach kurzer Zeit ab, wie schon in der Vergangenheit an anderer Stelle beschrieben. Kann es doch vielleicht einen MRA Grund geben da es bei den anderen Anwendern hier ja auch Probleme mit der Remotek App unter Android gibt … oder bin ich hier der einzige iPhone iOS User in der Anwendung.
                                          VG
                                          martin-phogel.de
                                          martin-phogel.de
                                          TenWheels
                                          TenWheels
                                            Rene van Maanen
                                            Rene van Maanen
                                            Òscar
                                            Òscar
