  4. Expert Review of route
26 Posts 7 Posters 13.8k Views 3 Watching
    @Greenham
    Shaping points (soft points) can be skipped without the Garmin sending you back to a skipped shaping point.
    You must visit via points (hard points) or skip them manually.
    Only start a route if you:
    Have a connection with at least 3 satellites,
    Are on the route or are close to the route.
    Never start a route in the garage or at the kitchen table, because then the Zumo has to calculate to your starting point.
    Again, use a maximum of 28 via points and place them at critical points or where you want to stop. For the rest, just use shaping points. I myself use a maximum of 7 via points in my route and form the route with sufficient shaping points.
    Greenham
    Greenham
    Greenham
    @Hans-van-de-Ven-MR-MRA
    Thank you,
    I can reduce the hard points and use more soft points.
    But
    QUESTION .... Does the Zumo XT use the soft points when its calculating the route using the route I want to take.
    HABVEN aka MrMRA Marinus van Deudekom 2 Replies Last reply
    • Greenham Greenham
      Thank you,
      But
      @Greenham
      Yes
      • Greenham Greenham
        Thank you,
        But
        @Greenham The XT has a nasty habbit of thinking it can make a better route then the one you planned. To force the XT to do what YOU want add extra shapingpoints. Use the compare function in the planning mode to see what TomTom and OSM do whit your route. It gives you a small inside of what might happen to your route if you didn't put in enough shapingpoints
        Greenham 1 Reply Last reply
        • Guzt
          Guzt
          Guzt
          wrote on last edited by Guzt
          • only use shaping points (hands) where relevant (fuel stop, coffee stop, lunch stop etc...) and use different colours accordingly.
          • once your route finished with the car activity profile using the HERE map set, optimise it by changing route calculation from fastest (standard) to shortest and adjust to original. Switch back to fastest and adjust again if necessary.
          • if wanted, now you may switch to the TT map set and do the same.
          • use the gpx 1.1 (route, track poi) for your XT.
          • you can leave the recalculation mode on your Garmin device to automatic without any problem.
          Nick Carthew Marinus van Deudekom Greenham 3 Replies Last reply
          • Guzt Guzt
            @Guzt
            Just for clarity, Via points are hand shaped not shaping points.
            • Guzt Guzt
              @Guzt If you use recalculate on on the XT you're in for trouble. sooner or later the thing will for shure mess up your carefully planned route. The XT has a will of its own. So my advise is leave it of.
              when using the 1.2 export using the Drive app. The route, witch must have some viapoints in it, will be shown on your XT. I alway project the track witch comes automaticly with the 1.2 export under the route so if you deviate dfrom the route you can still come back to the route using your eyes. If you have recalculate on, that would bee the chance for the XT to mess up your route and believe me it will for shure.
              have fun
              Guzt 1 Reply Last reply
              • Guzt Guzt
                Greenham
                Greenham
                Greenham
                @Guzt said in Expert Review of route:
                #1 Shaping vs Via points. Got that. Only use VIA points where you actually want to stop.
                #2 Heres where I get confused by your comment, I started with the motorcycle profile and the (Here) default. How do I optimize changing from fastest to shortest
                I don't understand the back and forth of fastest and shortest
                I have compared the route with TT in the past
                #3 I just learned from you guys recently to use GPX 1.1
                #4 I understand the Leave recalculation on the Zumo to automatic
                Guzt 2 Replies Last reply
                • Greenham Greenham
                  Guzt
                  Guzt
                  Guzt
                  @Greenham download this document from my google drive for full explanation
                  [link text]https://drive.google.com/file/d/1Zwt-5yrJSFWJCLw-997z3XFbFyAUY6en/view?usp=drive_link(link url)
                    have fun
                    Guzt
                    Guzt
                    Guzt
                    @Marinus-van-Deudekom Did I mentioned to use 1.2? Don't think so.
                    Greenham Marinus van Deudekom 2 Replies Last reply
                    • Greenham Greenham
                      Many have helped me understand the Garmin Zumo XT and GPX 1.1 vs 1.2 which has been very helpful.
                      A few helped me through a "seasonal closures" routing issue.
                      I have completed the Day 1 of what will be a 3 day trip in June. Would anyone be willing to review it and offer any suggestions? Good, Bad or indifferent?
                      https://www.myrouteapp.com/route/open/10473886
                      Greenham
                      Greenham
                      Greenham
                      @Greenham
                      This is great. I won't pretend to understand why you have to save as a track, then load it and compare with the Route, but I will do it.
                      In the Motorcycle profile it does allow me to route optimize. Or is it doing nothing.
                      I used Chat GPT to create an English version if you want it.
                      THANK YOU AGAIN
                      • Guzt Guzt
                        Greenham
                        Greenham
                        Greenham
                        @Guzt
                        You say in the doc when downloading to Garmin to do it in. 1.1 format
                        • Greenham Greenham
                          Guzt
                          Guzt
                          Guzt
                          @Greenham In the toolkit under optimize you have the possibility to change the route calculation. That option is only available in the HERE map set when you make your route using the car/auto mobile profile.
                          You can either add a copy of the route (hamburger menu - routes - add) or make the track underlying (which I prefer) visible as reference (I already have an uploaded track of the route as I make all my routes mostly in Basecamp).
                          When one recalculates with shorter distance e.g. the route will differ from the original. By dragging the recalculated route to the track or reference route, you force the route to follow the original as intended. Hence the reason that one can leave auto-calculation to on on the gps when using gpx 1.1
                          Greenham 2 Replies Last reply
                          • Guzt Guzt
                            Greenham
                            Greenham
                            Greenham
                            @Guzt
                            Thank you again. I finally did it. I used your steps and saw 1 or 2 places that the track and the rote did not align. Fixed that, changed to shortest, no issues, exported to my Garmin in 1.1 Route.Track.POI
                            I've learned a much from you. Thank you
                            Mike
                            Here is the English version of your instructions
                            https://drive.google.com/drive/folders/1khcVV8Wp56ploC0WzzSaf3bm-no57mve?usp=drive_link
                            • Guzt Guzt
                              @Guzt exactly that would be my advise
                              I see that you still use Basecamp from way back when. Keep up with up progressive planning of MRA and make the world a bit more beautifull
                              • Guzt Guzt
                                Greenham
                                Greenham
                                Greenham
                                wrote on last edited by Greenham
                                #22
                                @Guzt
                                1 last question.
                                What do you do when the tracklog and the route don't line up, but you want to KEEP the route. I can't move the Tracklog to match.
                                Will the Garmin follow my route or the tracklog?
                                This is the issue with GPS's and Motorcycles. If you want to take a more scenic route will the GPS let you?
                                Mike
                                  Greenham
                                  Greenham
                                  Greenham
                                  Here is an example of what you are talking about. using @Guzt Workflow and using Tracklogs to compare your DESIRED route to the Tracklog I get these anomalies
                                  Clarksville 12025-01-30 114939.png Clarksville2 12025-01-30 114939.png Clarksville3 12025-01-30 114939.png
                                  Notice the gray line is the Tracklog the dark line is my preferred route of travel. Will these Tracklogs be the route the Zumo will take me?
                                  Finally I have this anomaly with a Tracklog/Route comparison.
                                  I've tried all kind of fixes like moving shaping points adding Via points, still get this odd occurrences. The Tracklog is Red, the route is black.
                                  • Greenham Greenham
                                    @Greenham Did you get those anomalys when switching between shortest en fastest?
                                    That can only be done using the Car profile. In the bike profile you don't have that choise.
                                    For planning I stricktly use the car profile.
                                    I compare the prefered route (planned in the Here map) with the TomTom and OSM maps and make shure adding extra shaping points to the route when there's an anomaly. Then in the end when I'm satisfied and the 3 maps are alike I transfer the route to the XT, using the Drive app.
                                    I don't use any avoid items in the planner and I dopn't use any in the XT. That way the route stays the same. Make sure that recalculating in your XT is OFF.
                                    Why: although there's a lot of different opinions on this theme, if you deviate from the route, let's say there's roadworks going on and the route is blocked, and you have recalculate ON, the XT will break free from its harness, the route, and grab it's change to change your route. There's a 100% garantee that it will mess up your rouite.
                                    If you want us to say something about the anomalys you've mentioned, share such a route here and make shure it's set to public.
                                    have fun
                                      have fun
                                      Greenham
                                      Greenham
                                      Greenham
                                      @Marinus-van-Deudekom said in Expert Review of route:
                                      have fun
                                      It's the only route (So far) that has done this. I do your the CAR profile, I don't use any avoidances. I downloaded the tracklog at @Guzt outlined in his paper, then compared with both the fastest and shortest comparisons.
                                      Thanks for your thoughts.
                                      Mike
                                      • Greenham Greenham
                                        have fun
                                        Mike
                                        Guzt
                                        Guzt
                                        Guzt
                                        #26
                                        @Greenham I find it very strange that the saved and imported track differs from your initialy desired route. MRA is not always 100% accurate when exporting the track and can have some undesired peak paths which one should ignore. (Sometimes when I import a BC track, the stranges things happen).
                                        I imported your route, saved it as a track and imported this track in my tracklogs
                                        [link text]https://www.myrouteapp.com/nl/social/track/707609?mode=share(link url)
                                        Went back to the route and and made the track visible. Lowered the routing points to 20 and adjusted the route to the track (The blue routing numbers). Recalculated with shortest distance and adjusted the route to the track. Switched back to fastest distance and changed the map set to TT. Problems occured after routing point 29 where there is no road any more but a trail. So on the TT map the route is no longer following the track but redirected.
                                        [link text]https://www.myrouteapp.com/profile/routes/17526#options-route-social(link url)
                                        For the rest I had no problems at all to optimize your route.!Trail - no road.JPG Trail - Michelin overlay.JPG trail - google maps satelite.JPG altered itinerary.JPG
                                        Guzt
                                        Guzt
                                        Greenham
                                        Greenham
                                          MartinW
                                          MartinW
                                          MartinW
                                          MartinW
                                          Rory Burke
                                          Rory Burke
                                        • Béta to no-béta
