  4. Bulk Upload of POI's
25 Posts 8 Posters 11.3k Views 6 Watching
  • nomko nomko
    Da's heel apart, die ik het in ChatGPT dan krijg ik dit te zien:
    Geen .gpx bestand zoals bij @Dikke-Wim. Doe ik iets verkeerd?
    Dikke Wim
    Dikke Wim
    Dikke Wim
    @Nomko-Nomden
    Ik heb ChatGPT gebruikt en daarbinnen de ChatBot "Travel Guide". Helaas kun je die maar zeer beperkt gratis gebruiken. Dus gisteravond moest ik wachten om verder te kunnen.
    Maar uiteindelijk wordt er een GPX file gegenereerd en een KML file op mijn verzoek om in Google Earth e.a. te kunnen zien.
    Zie hieronder wat ik bedoel met "Travel Guide">
    Mzokk 1 Reply Last reply
    • Dikke Wim Dikke Wim
      @Nomko-Nomden
      @Dikke-Wim you can also use Qgis to harvest POI's from OSM mapping.
      You need two add ins to get the information QuickOSM
      Which gives a dialog like this.
      And POI exporter which allows export as a GPX file that MRA can read.
      Dikke Wim 1 Reply Last reply
      • Mzokk Mzokk
        Dikke Wim
        Dikke Wim
        Dikke Wim
        @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
        MartinW Mzokk 2 Replies Last reply
          MartinW
          MartinW
          MartinW
          wrote on last edited by MartinW
          @Dikke-Wim @Mzokk
          Here's another attempt in three simple steps:
          1. Launch a query on overpass-turbo.eu
          1. export as gpx
          1. upload into MRA
          BertM Dikke Wim 2 Replies Last reply
          • MartinW MartinW
            @Dikke-Wim @Mzokk
            1. export as gpx
            1. upload into MRA
            I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
            I use Excel to make them and then convert to GPX.
            MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
            Greenham 1 Reply Last reply
            • MartinW MartinW
              @Dikke-Wim @Mzokk
              1. export as gpx
              1. upload into MRA
              Dikke Wim
              Dikke Wim
              Dikke Wim
              @Martin-Wilcke
              Thank you very much! It seems to work great....
              However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
              Do you have any idea how to fix this? See screendumps below.
              See e.g. Cornwall with many castles
              Cornwall without any castles
              MartinW 1 Reply Last reply
                @Martin-Wilcke
                MartinW
                MartinW
                MartinW
                @Dikke-Wim said in Bulk Upload of POI's:
                Hmmm... Maybe you need to zoom in?
                Overpass:
                Imported:
                • MartinW MartinW
                  Overpass:
                  Imported:
                  Dikke Wim
                  Dikke Wim
                  Dikke Wim
                  @Martin-Wilcke
                  Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
                  Any suggestions what I do wrong?
                  Example of the map with castles in Cornwall
                  No castles in Cornwall after importing the GPX file
                  the KML file shows more castles in Google Earth than the GPX file in MRA
                  MartinW 3 Replies Last reply
                    @Martin-Wilcke
                    MartinW
                    MartinW
                    MartinW
                    @Dikke-Wim
                    OK - let's focus on "Crane Castle" as an example; it's this one:
                    Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
                    In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
                    Does it show up?
                      @Martin-Wilcke
                      MartinW
                      MartinW
                      MartinW
                      @Dikke-Wim
                      And one more note:
                      I have just noticed that "historic=castle" can be modelled both as a ‘node’ (point) and as a ‘way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
                      That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
                      Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
                        @Martin-Wilcke
                        MartinW
                        MartinW
                        MartinW
                        @Dikke-Wim
                        OK - I got it.
                        You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
                        Here's the result
                        https://hidrive.ionos.com/lnk/LhseBgcKc
                        for the query:
                        Sorry for the confusion!
                        Dikke Wim JP d 2 Replies Last reply
                          @Dikke-Wim Somewhat less work than the method you describe👍
                          • MartinW MartinW
                            @Dikke-Wim
                            OK - I got it.
                            Here's the result
                            for the query:
                            Dikke Wim
                            Dikke Wim
                            Dikke Wim
                            @Martin-Wilcke
                            Thanks Martin. It works now much better (see below).
                            • Mzokk Mzokk
                              Dikke Wim
                              Dikke Wim
                              Dikke Wim
                              @Mzokk
                              What method do you mean? I don't get it.
                              For me: the easier the better!
                                @Martin-Wilcke
                                MartinW
                                MartinW
                                MartinW
                                @Dikke-Wim
                                • MartinW MartinW
                                  @Dikke-Wim
                                  OK - I got it.
                                  Here's the result
                                  for the query:
                                  JP d
                                  JP d
                                  JP d
                                  @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. 🙏
                                  • BertM BertM
                                    Greenham
                                    Greenham
                                    Greenham
                                    @BertM
                                    Yes this is what I am trying to do. Add my own POI's
                                    BertM 1 Reply Last reply
                                    • Greenham Greenham
                                      @BertM
                                      @Greenham said in Bulk Upload of POI's:
                                      @BertM
                                      As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA 🙂
                                      the today status of the tools is the following
                                      • Import simple POI GPX files into Excel
                                      • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                                      • Export the POI file to GPX format
                                      • Double Click on the filled in row and the POI wil open in Google maps.
                                      Excel file with Ribbon (KML does not work yet)
                                      MOHO hotels GPX imported into Excel
                                      3rd Item in the list selected and button "Show in Google Maps" selected
                                      Import in MRA from GPX file
                                      Import in Basecamp with selected symbol
                                      Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                                      Send me your email in a PB and I send you the current file with the following status:
                                      • Made and only tested in Excel/Windows10
                                      • Error handeling is still poor in the progarmming
                                      • Program as is, it works on my system, not tested on other equipment.
                                      • Program is made in MS VBA and not tested in other programs.
                                      regards,
                                      Bert
                                      MartinW
                                      MartinW
                                      JP d
                                      JP d
                                      Dikke Wim
                                      Dikke Wim
                                      Greenham
                                      Greenham
                                        MartinW
                                        MartinW
                                        MartinW
                                        MartinW
                                        Rory Burke
                                        Rory Burke
                                      • Béta to no-béta
