  4. Bulk Upload of POI's
25 Posts 8 Posters 9.4k Views 6 Watching
  • Greenham Offline
    Greenham Offline
    Greenham
    Is there an easy way to bulk upload POI's? I am referring to the use of a spreadsheet/CVS that I would properly add all my desired POI's into a spreadsheet then upload them ALL?
    It would be really handy to have a formatted example of a spreadsheet/CVS with all the proper headings for easy population. They could be easily shared, added too etc.
    It has to be fairly easy as this is just one big database.
    Am I right?
    Dikke Wim BertM Adrian Avram 3 Replies Last reply
    • Greenham Greenham
      Am I right?
      Dikke Wim Offline
      Dikke Wim Offline
      Dikke Wim
      @Greenham
      Just tried this in ChatGPT and it works !!!
      All castles in the UK in a GPX and a KLM file.
      Greenham 1 Reply Last reply
      • Dikke Wim Dikke Wim
        @Greenham
        Greenham Offline
        Greenham Offline
        Greenham
        @Dikke-Wim that is brilliant. But how do you get them all in a poi file that all routes should have access to.
        Dikke Wim 1 Reply Last reply
        • Greenham Greenham
          Dikke Wim Offline
          Dikke Wim Offline
          Dikke Wim
          @Greenham
          In MyRoute App you can upload POI's. After that you go can make them visible als POI's in Library (Beheren in Dutch).
          • nomko Offline
            nomko Offline
            Banned
            wrote on last edited by nomko
            Da's heel apart, die ik het in ChatGPT dan krijg ik dit te zien:
            Geen .gpx bestand zoals bij @Dikke-Wim. Doe ik iets verkeerd?
            • Greenham Greenham
              Am I right?
              BertM Offline
              BertM Offline
              @Greenham said in Bulk Upload of POI's:
              Am I right?
              Yes that is possible, but the POI in MRA is quite rudimentary, you can only enter a name in the database.
              here is an example of a file that you can read in GPS Visulizer for example and convert to GPX.
              https://www.gpsvisualizer.com/convert_input?convert_format=gpx
              For myself I have made a VBA program in Excel that converts the above data into a GPX file, which I upload in MRA.
              The reason for this is that MRA has some trouble with the CSV files and that Excel subconsciously converts my CSV numbers.
              I am currently busy converting the Excel VBA to Openoffice and expanding the GPX export so that I can enter more data such as warnings and heights that my Garmin device can use.
              Please note that you have to divide the different POIs, you cannot change the category in MRA. they all get the same icon.
              Below my (Chaotic) own POI library, by uploading them differently you can use different icons.
              • Greenham Greenham
                Am I right?
                Adrian Avram Offline
                @Greenham I have a POI file that I am constantly updating and I use this website. I upload the file, add points, then download the new updated file.
                https://www.poieditor.com/
                Adrian
                🚙Renaul Duster with onboard AA/CarPlay Unit
                • nomko nomko
                  Dikke Wim Offline
                  Dikke Wim Offline
                  Dikke Wim
                  @Nomko-Nomden
                  Ik heb ChatGPT gebruikt en daarbinnen de ChatBot "Travel Guide". Helaas kun je die maar zeer beperkt gratis gebruiken. Dus gisteravond moest ik wachten om verder te kunnen.
                  Maar uiteindelijk wordt er een GPX file gegenereerd en een KML file op mijn verzoek om in Google Earth e.a. te kunnen zien.
                  Zie hieronder wat ik bedoel met "Travel Guide">
                  Mzokk 1 Reply Last reply
                    @Nomko-Nomden
                    Mzokk Offline
                    Mzokk Offline
                    @Dikke-Wim you can also use Qgis to harvest POI's from OSM mapping.
                    You need two add ins to get the information QuickOSM
                    Which gives a dialog like this.
                    And POI exporter which allows export as a GPX file that MRA can read.
                    • Mzokk Mzokk
                      Dikke Wim Offline
                      Dikke Wim Offline
                      Dikke Wim
                      @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
                      martin-phogel.de Mzokk 2 Replies Last reply
                        martin-phogel.de Offline
                        martin-phogel.de
                        @Dikke-Wim @Mzokk
                        Here's another attempt in three simple steps:
                        1. Launch a query on overpass-turbo.eu
                        1. export as gpx
                        1. upload into MRA
                        BertM Dikke Wim 2 Replies Last reply
                          @Dikke-Wim @Mzokk
                          1. export as gpx
                          1. upload into MRA
                          BertM Offline
                          BertM Offline
                          I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
                          I use Excel to make them and then convert to GPX.
                          MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
                            @Dikke-Wim @Mzokk
                            1. export as gpx
                            1. upload into MRA
                            Dikke Wim Offline
                            Dikke Wim Offline
                            Dikke Wim
                            @Martin-Wilcke
                            Thank you very much! It seems to work great....
                            However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
                            Do you have any idea how to fix this? See screendumps below.
                            See e.g. Cornwall with many castles
                            Cornwall without any castles
                              @Martin-Wilcke
                              martin-phogel.de
                              @Dikke-Wim said in Bulk Upload of POI's:
                              Hmmm... Maybe you need to zoom in?
                              Overpass:
                              Imported:
                                Overpass:
                                Imported:
                                Dikke Wim Offline
                                Dikke Wim Offline
                                Dikke Wim
                                @Martin-Wilcke
                                Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
                                Any suggestions what I do wrong?
                                Example of the map with castles in Cornwall
                                No castles in Cornwall after importing the GPX file
                                the KML file shows more castles in Google Earth than the GPX file in MRA
                                martin-phogel.de 3 Replies Last reply
                                  @Martin-Wilcke
                                  martin-phogel.de
                                  @Dikke-Wim
                                  OK - let's focus on "Crane Castle" as an example; it's this one:
                                  Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
                                  In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
                                  Does it show up?
                                    @Martin-Wilcke
                                    martin-phogel.de
                                    @Dikke-Wim
                                    And one more note:
                                    I have just noticed that "historic=castle" can be modelled both as a ‘node’ (point) and as a ‘way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
                                    That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
                                    Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
                                      @Martin-Wilcke
                                      martin-phogel.de
                                      @Dikke-Wim
                                      OK - I got it.
                                      You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
                                      Here's the result
                                      https://hidrive.ionos.com/lnk/LhseBgcKc
                                      for the query:
                                      Sorry for the confusion!
                                      Dikke Wim JP d 2 Replies Last reply
                                        Mzokk Offline
                                        Mzokk Offline
                                        @Dikke-Wim Somewhat less work than the method you describe👍
                                          @Dikke-Wim
                                          OK - I got it.
                                          Here's the result
                                          for the query:
                                          Dikke Wim Offline
                                          Dikke Wim Offline
                                          Dikke Wim
                                          @Martin-Wilcke
                                          Thanks Martin. It works now much better (see below).
                                          martin-phogel.de
                                          martin-phogel.de
                                          JP d
                                          JP d
                                          Dikke Wim
                                          Dikke Wim
                                          Greenham
                                          Greenham
                                            jan rodeyns
                                            jan rodeyns
                                            willo 3 0
                                            willo 3 0
                                          • Planned routes not available during lack of Internet connection
                                            Montorsi Paolo 0
                                            Montorsi Paolo 0
                                          • Welke instelling
                                          • Bug: snelweg vermijden opheffen na wegvallen verbinding? + vraagje gpx file
                                          • opslaan naar plantomtom
                                          • Update 5.2.2 - Quick fix
                                            1.1k
