  4. Bulk Upload of POI's
25 Posts 8 Posters 11.3k Views 6 Watching
  • Dikke Wim Dikke Wim
    @Martin-Wilcke
    Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
    Any suggestions what I do wrong?
    Example of the map with castles in Cornwall
    No castles in Cornwall after importing the GPX file
    the KML file shows more castles in Google Earth than the GPX file in MRA
    MartinW
    MartinW
    MartinW
    @Dikke-Wim
    OK - let's focus on "Crane Castle" as an example; it's this one:
    Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
    In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
    Does it show up?
      @Martin-Wilcke
      MartinW
      MartinW
      MartinW
      @Dikke-Wim
      And one more note:
      I have just noticed that "historic=castle" can be modelled both as a ‘node’ (point) and as a ‘way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
      That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
      Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
        @Martin-Wilcke
        MartinW
        MartinW
        MartinW
        @Dikke-Wim
        OK - I got it.
        You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
        Here's the result
        https://hidrive.ionos.com/lnk/LhseBgcKc
        for the query:
        Sorry for the confusion!
        Dikke Wim JP d 2 Replies Last reply
          @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
          @Dikke-Wim Somewhat less work than the method you describe👍
          Dikke Wim 1 Reply Last reply
          • MartinW MartinW
            @Dikke-Wim
            OK - I got it.
            Here's the result
            for the query:
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Martin-Wilcke
            Thanks Martin. It works now much better (see below).
            MartinW 1 Reply Last reply
            • Mzokk Mzokk
              Dikke Wim
              Dikke Wim
              Dikke Wim
              @Mzokk
              What method do you mean? I don't get it.
              For me: the easier the better!
                @Martin-Wilcke
                MartinW
                MartinW
                MartinW
                @Dikke-Wim
                • MartinW MartinW
                  @Dikke-Wim
                  OK - I got it.
                  Here's the result
                  for the query:
                  JP d
                  JP d
                  JP d
                  @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. 🙏
                  • BertM BertM
                    I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
                    I use Excel to make them and then convert to GPX.
                    MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
                    Greenham
                    Greenham
                    Greenham
                    @BertM
                    Yes this is what I am trying to do. Add my own POI's
                    BertM 1 Reply Last reply
                    • Greenham Greenham
                      @BertM
                      @Greenham said in Bulk Upload of POI's:
                      @BertM
                      As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA 🙂
                      the today status of the tools is the following
                      • Import simple POI GPX files into Excel
                      • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                      • Export the POI file to GPX format
                      • Double Click on the filled in row and the POI wil open in Google maps.
                      Excel file with Ribbon (KML does not work yet)
                      MOHO hotels GPX imported into Excel
                      3rd Item in the list selected and button "Show in Google Maps" selected
                      Import in MRA from GPX file
                      Import in Basecamp with selected symbol
                      Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                      Send me your email in a PB and I send you the current file with the following status:
                      • Made and only tested in Excel/Windows10
                      • Error handeling is still poor in the progarmming
                      • Program as is, it works on my system, not tested on other equipment.
                      • Program is made in MS VBA and not tested in other programs.
                      regards,
                      Bert
                      MartinW
                      MartinW
                      JP d
                      JP d
                      Dikke Wim
                      Dikke Wim
                      Greenham
                      Greenham
                        MartinW
                        MartinW
                        MartinW
                        MartinW
                        Rory Burke
                        Rory Burke
                      • Béta to no-béta
