  4. Bulk Upload of POI's
25 Posts 8 Posters 10.8k Views 6 Watching
  • Dikke Wim Dikke Wim
    @Mzokk Thanks a lot. But.... is a lot of work I guess. Therefore I prefer AI who takes over the difficult stuff. I'm doing some experiments with AI. Curious how things work out.
    MartinW
    MartinW
    MartinW
    wrote on last edited by MartinW
    @Dikke-Wim @Mzokk
    Here's another attempt in three simple steps:
    1. Launch a query on overpass-turbo.eu
    1. export as gpx
    1. upload into MRA
    BertM Dikke Wim 2 Replies Last reply
    • MartinW MartinW
      @Dikke-Wim @Mzokk
      1. export as gpx
      1. upload into MRA
      I do not think @Greenham want to harvest POI's but to put his own POI's into MRA in bulk.
      I use Excel to make them and then convert to GPX.
      MRA only uses the description but If I load them into my Garmin I get the other fields also. I am now busy to find out how to bulk import a GPX into my little housemade tool.
      Greenham 1 Reply Last reply
      • MartinW MartinW
        @Dikke-Wim @Mzokk
        1. export as gpx
        1. upload into MRA
        Dikke Wim
        Dikke Wim
        Dikke Wim
        @Martin-Wilcke
        Thank you very much! It seems to work great....
        However, not all dots of castles of South UH that are shown on the map are found in MRA when imported.
        Do you have any idea how to fix this? See screendumps below.
        See e.g. Cornwall with many castles
        Cornwall without any castles
        MartinW 1 Reply Last reply
          @Martin-Wilcke
          MartinW
          MartinW
          MartinW
          @Dikke-Wim said in Bulk Upload of POI's:
          Hmmm... Maybe you need to zoom in?
          Overpass:
          Imported:
          Dikke Wim 1 Reply Last reply
          • MartinW MartinW
            Overpass:
            Imported:
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Martin-Wilcke
            Unfortunately even when I zoom in more than in the example above, no additional castles appear. Only "few" of the cirkels with castles in the overpass.eu website, are visible.
            Any suggestions what I do wrong?
            Example of the map with castles in Cornwall
            No castles in Cornwall after importing the GPX file
            the KML file shows more castles in Google Earth than the GPX file in MRA
            MartinW 3 Replies Last reply
              @Martin-Wilcke
              MartinW
              MartinW
              MartinW
              @Dikke-Wim
              OK - let's focus on "Crane Castle" as an example; it's this one:
              Please have a look at the GPX you've uploaded with an editor and search for "Crane", there should be a match like this:
              In MRA, search for "Portreath" and zoom in to a scale of 1 km / 1 mile or less:
              Does it show up?
                @Martin-Wilcke
                MartinW
                MartinW
                MartinW
                @Dikke-Wim
                And one more note:
                I have just noticed that "historic=castle" can be modelled both as a ‘node’ (point) and as a ‘way’ (path, here in the sense of area). They appear as yellow dots for nodes and red dots for ways/areas.
                That's why my example query node ["historic"="castle"]; is not ideal, because it only finds castles that are modelled as a point.
                Better, as in your example, is nwr ["historic"="castle"]; as it includes nodes, ways and relations.
                  @Martin-Wilcke
                  MartinW
                  MartinW
                  MartinW
                  @Dikke-Wim
                  OK - I got it.
                  You need an out centre (instead of an out geom) to create a single node for ways/areas. This will generate waypoints for both types (nodes and ways) when exporting as GPX.
                  Here's the result
                  https://hidrive.ionos.com/lnk/LhseBgcKc
                  for the query:
                  Sorry for the confusion!
                  Dikke Wim JP d 2 Replies Last reply
                    @Dikke-Wim Somewhat less work than the method you describe👍
                    • MartinW MartinW
                      @Dikke-Wim
                      OK - I got it.
                      Here's the result
                      for the query:
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      @Martin-Wilcke
                      Thanks Martin. It works now much better (see below).
                      • Mzokk Mzokk
                        Dikke Wim
                        Dikke Wim
                        Dikke Wim
                        @Mzokk
                        What method do you mean? I don't get it.
                        For me: the easier the better!
                          @Martin-Wilcke
                          MartinW
                          MartinW
                          MartinW
                          @Dikke-Wim
                          • MartinW MartinW
                            @Dikke-Wim
                            OK - I got it.
                            Here's the result
                            for the query:
                            JP d
                            JP d
                            JP d
                            @Martin-Wilcke this is amazing never knew how to use this feature! It would be of great help if the MRA team @Corjan-Meijerink could make a YouTube tutorial on this. 🙏
                            • BertM BertM
                              Greenham
                              Greenham
                              Greenham
                              @BertM
                              Yes this is what I am trying to do. Add my own POI's
                              BertM 1 Reply Last reply
                              • Greenham Greenham
                                @BertM
                                @Greenham said in Bulk Upload of POI's:
                                @BertM
                                As another member of this forum asked me the same because I replied here, I have been dusting off my 20 year old programming skills in Excel VBA 🙂
                                the today status of the tools is the following
                                • Import simple POI GPX files into Excel
                                • Edit the imported file and add Symbol, Description, Street, Phone etc for import into Garmin devices
                                • Export the POI file to GPX format
                                • Double Click on the filled in row and the POI wil open in Google maps.
                                Excel file with Ribbon (KML does not work yet)
                                MOHO hotels GPX imported into Excel
                                3rd Item in the list selected and button "Show in Google Maps" selected
                                Import in MRA from GPX file
                                Import in Basecamp with selected symbol
                                Data added in Excel and transferred to Garmin GPX, see also the different symbols in the same GPX
                                Send me your email in a PB and I send you the current file with the following status:
                                • Made and only tested in Excel/Windows10
                                • Error handeling is still poor in the progarmming
                                • Program as is, it works on my system, not tested on other equipment.
                                • Program is made in MS VBA and not tested in other programs.
                                regards,
                                Bert
                                MartinW
                                MartinW
                                JP d
                                JP d
                                Dikke Wim
                                Dikke Wim
                                Greenham
                                Greenham
                                • Kaart niet zichtbaar
                                  BĂ© Jeuring
                                  BĂ© Jeuring
                                • Xpert overlay not clear
                                  Corrado Miniati 0
                                  Corrado Miniati 0
                                • Google maps
                                  Ed Bos 0
                                  Ed Bos 0
                                • Trains like Ferries?
                                  Corrado Miniati 0
                                  Corrado Miniati 0
