  4. color of route when the waypoints overlap
11 Posts 7 Posters 1.4k Views 6 Watching
  • Christian Siegelundefined Offline
    Christian Siegel
    Hi, I really enjoy using the app for planning and navigating.
    One thing is certainly confusing for me when on a route for example I reach a roundabout and it's the same roundabout where I come through later from another direction it gets very confusing unless you look at the arrows or distance/number of exit. Would it be possible to make the color fade for the occasion that occurs later in the route?
    Con Hennekensundefined David Rudgleyundefined Brian McGundefined 3 Replies Last reply
    • Nick Carthewundefined Nick Carthew moved this topic from [Web] Suggestions and Discussion on
    • Christian Siegelundefined Christian Siegel
      @Christian-Siegel , That would be odd, since a faded line indicates that you already passed. The white arrows in the routeline are indication of where to go, and also the shown exit in the next-instruction tile on the top left of the screen. I do undertsand the confusion though. Setting your line wider in the app settings will likely enhance the readability of the white arrows. Would that help?
      Christian Siegelundefined 1 Reply Last reply
        David Rudgleyundefined Offline
        David Rudgley
        wrote on last edited by David Rudgley
        @Christian-Siegel Yes I experienced the same issue yesterday, the arrow that shows the exit is the same colour and width as the road so it looks like there is a gap in the route. I tried changing the map colours today and on the phone app it looks like the arrow now has an outline so that helps. I need to try if the same map is replicated on the Android Auto mirror, if this fixes the issue I'll report back.
        MRA Gold Planner + App + Navigation Next user
        Android Pixel 9 Pro XL
        TomTomGo as backup
        KTM 1290 Super Adventure S
        Quad Lock + Phone +Carpuride W702
        KTM 790 Duke
        Quad Lock + Phone
          Christian Siegel
          @Con-Hennekens will try that
          David Rudgleyundefined 1 Reply Last reply
            David Rudgley
            @Christian-Siegel I experimented on Android Auto yesterday and changing the map colours in the App under
            [Settings]
            [Navigation Settings]
            [Map Layer]
            [Map Style]
            trying different combinations of
            <Colour scheme>
            <Edition>
            The settings made here are also shown on the Android Auto version.
            For me, this only affects the small local roads that by default are shown in white on the map.!PXL_20241029_153716492~2.jpg
            TomTomGo as backup
            KTM 790 Duke
            Quad Lock + Phone
              I’ll look into it 🙂
                Brian McGundefined Offline
                Hi @Christian-Siegel if you have planned the route you should be aware of where the crossover is & can place points on the exits of the junction
                You should then be able to see which route is the correct number in the sequence
                If your riding a track then this wont help
                  I've made some improvements regarding this for the 4.3.3 update.
                  These changes are now going to beta.
                    Christian Siegel
                    @Brian-McG that's a good idea, good practice to adopt
                    • Rob-zundefined Offline
                      Rob-z
                      I think its the same question, here in dutch: https://forum.myrouteapp.com/topic/8315/witte-pijl-in-andere-kleur-mogelijk
                      • Rob-zundefined Rob-z
                        Adrian Avramundefined Offline
                        @Rob-z fixed now if you update the app to the latest version.
                        Adrian
                        Samsung S24 Ultra and iPhone 13 with Android Auto / CarPlay
                        David Rudgley
                        Christian Siegel
                        Rob-zundefined
                        Rob-z
                        • Update 5.0.2 - Free drive
                          Ewout 2undefined
                          Ewout 2
                        • Totale afstand van alle routes in eenzelfde map.
                          Nomko Nomdenundefined
                          Nomko Nomden
                        • app wont start
                        • Mobile data usage
                        • App freezes when you change POI size during navigation
                          3.1k
                        • How do I follow a track not Navigate it
                          Benjamin Ralstonundefined
                          Benjamin Ralston
