  4. help with Garmin Zumo XT
31 Posts 7 Posters 16.1k Views 4 Watching
  • paul69 paul69
    @Mzokk said in help with Garmin Zumo XT:
    Track is in list.
    please correct me if i am wrong, as i have not had an XT for some time now
    but off memory, you would not be able to see the track in the tracks menu if explore was running, hence why i posted the link to thread explaining how to remove explore.
    but I am only guessing from memeory as I do not have an XT, so maybe my input is pointless
    wrote on last edited by Mzokk
    #21
    @paul69 I don't use explore so the XT reverts to the old Garmin method of displaying a track by ticking it in the menu. The Drive app works fine without explore being installed on your phone or linked to your XT unit.
    You obviously have to manually untick the track when you have finished using it.
    paul69 1 Reply Last reply
    • paul69 paul69
      Track is in list.
      @paul69 I am thinking of going down the route of using MRA for navigation as well as route planning. Sometimes the testing gets a bit ridiculous.
      • Mzokk Mzokk
        @Mzokk
        K1600 GTL
        Oukitel RT3
        iPhone 13 Pro, carpuride 702b
        • Mzokk Mzokk
          #24
          @Mzokk
          this is what i have been trying to explain to people, you do not get this option with explore activated.
          replied to this a bit late, but never mind
          for those looking in, this refers to 3 posts above this one
          K1600 GTL
          Oukitel RT3
          • paul69 paul69
            hi @Mike-wiruth
            just found this which was written by the font of knowledge on the zumo forum explaining how to get rid of explore.
            https://www.zumouserforums.co.uk/app.php/ZXT-P56
            this is also has an effect on viewing the routes/tracks in the XT menus, but thankfully i do not have to put up with the nuances of the XT any longer thanks to MRA
            Mike wiruth
            Mike wiruth
            Mike wiruth
            @paul69 Paul, thanks very much. I went to the link and followed the instructions and got rid of explore on my xt. I also signed up for the zumo forum. This should be a great place to get more zumo related answers. Thanks again for your help.
            Mike W
            2013 Honda Goldwing
            Bushtec Trailer
            Garmin Zumo XT
            Nebraska
            • Mzokk Mzokk
              @Mike-wiruth the method I use to transfer routes and navigate using the XT are as follows.
              I usually plot my routes on the computer screen (unless I'm on tour) as its easier to work with a 27" screen that a phone. I transfer my routes from the phone to the XT via the App. 5cc3c46a-de36-4866-9b06-452417a41cee-image.png
              This is not an ideal route but will illustrate some issues that can arise with the XT
              I download using GPX1.1 because this shows how you shaped the route using MRA and allows you to fix a route that does not go where you want on the XT. I also download the track of the route which will be as planned in MRA.
              Route Received
              Track Received
              Open Trip planner route will be in list.
              Track is in list.
              Open Route (Address near my house removed)
              Open Track Default is blue but I change the colour to yellow.
              Open the route and Track and make the track visible on the XT
              You can see that I wanted to go along the coast but the XT's routing logic is taking me back to a town and then back to the intended route as designed. This can be fixed by putting in an extra shaping point in the XT.
              Or by ensuring there are enough waypoints in the route you designed in MRA.
              I created a bespoke map theme for my XT that makes the Track line thicker and this can be seen below the route line even when navigating. It gives a heads up if the XT is going away from your intended route. I keep recalculate on the unit as "Prompted" and only use recalculate if I can't navigate back to my intended route using the screen.
              Mike wiruth
              Mike wiruth
              Mike wiruth
              @Mzokk So how do you display both the track and the route? I checked my xt and went to trip planner and opened up the trip I designed. Then what do you do? Go back and open the track too? When I downloaded it I chose gpx 1.2 route, track, poi
              Mike W
              2013 Honda Goldwing
              Bushtec Trailer
              Garmin Zumo XT
              Nebraska
              • Mzokk Mzokk
                Route Received
                Track Received
                Track is in list.
                Mike wiruth
                Mike wiruth
                Mike wiruth
                @Mzokk Also where in settings do you change the color of routes and tracks? Also, how did you get those great screen shots of your xt screen? Thanks for all your hard work of posting this reply. Great work. I was a great help. You might regret it though, I'm a learner, always wanting to learn more and I might burden you with questions. LOL
                Mike W
                2013 Honda Goldwing
                Bushtec Trailer
                Garmin Zumo XT
                Nebraska
                • Mike wiruth Mike wiruth
                  @Mike-wiruth of you got rid of explore in your XT in the settings you can choose to display any track and choose the with and color.
                  They are display under your route so is you go of route it's instantly visible
                  Mike wiruth 1 Reply Last reply
                    Mike wiruth
                    Mike wiruth
                    Mike wiruth
                    @Marinus-van-Deudekom How do you do it? I can't seem to open them both up at the same time. Also, need to know where to go to change the color of the track. Thanks for any help you can give me.
                    Mike W
                    2013 Honda Goldwing
                    Bushtec Trailer
                    Garmin Zumo XT
                    Nebraska
                    Mzokk 1 Reply Last reply
                      @Mike-wiruth Hi Mike if you go into tracks this is the sequence.
                      Open Tracks
                      Click on the spanner to show the track on the map. This stays on until you unclick it even if you are not navigating.
                      To change colour and width of the track you click on the spanner and scroll to the menu Item
                      So you can set up the track of the route you intend to run at any time and the track will stay until you untick it.
                      • Mzokk Mzokk
                        Open Tracks
                        Mike wiruth
                        Mike wiruth
                        Mike wiruth
                        @Mzokk Great, thanks for those steps. When you set the properties of the track, to see both at once, do you have to Start the track, then back out and start the route? I looked at the route, and when I first looked at it I could see what looked like the track on the outside of the route, I made the track the widest and color in red. But, when I zoomed in, I couldn't see the track anymore. But, I guess the good news is the track was the same as the route. No deviation.
                        Mike W
                        2013 Honda Goldwing
                        Bushtec Trailer
                        Garmin Zumo XT
                        Nebraska
                        Mike wiruth
                        Mike wiruth
                        TomOnTour
                        TomOnTour
                        Reinhard-32
                        Reinhard-32
                        • Points of interest
                          Lluís Casals
                          Lluís Casals
                          4.1k
                        • Altitude numbers size
                          JosepD
                          JosepD
                          4.1k
