  4. help with Garmin Zumo XT
31 Posts 7 Posters 16.1k Views 4 Watching
  • paul69
    hi @Mike-wiruth
    just found this which was written by the font of knowledge on the zumo forum explaining how to get rid of explore.
    https://www.zumouserforums.co.uk/app.php/ZXT-P56
    this is also has an effect on viewing the routes/tracks in the XT menus, but thankfully i do not have to put up with the nuances of the XT any longer thanks to MRA
    K1600 GTL
    Oukitel RT3
    iPhone 13 Pro, carpuride 702b
    Dave J 0 Mike wiruth 2 Replies Last reply
    • paul69 paul69
      hi @Mike-wiruth
      @paul69 have had similar problems to you with an XT2 and the awful Tread App changing routes and points as a result of the app and device sync. Garmin have really not done a good job with the software for a very good device.
      XT2 is a backup now with me relying on MRA on a CarPlay display. Working a treat and the new changes are brilliant.
      Ducati Multistrada V4 Rally
      iPhone 15 Pro
      CHIGEE AIO-6 LTE
      paul69 1 Reply Last reply
      • Dave J 0 Dave J 0
        @Dave-J-0 said in help with Garmin Zumo XT:
        i took this route too a couple of years ago, but the XT has long gone now.
        I believe that MRA is a really good piece of software and once oyu get used to using it ther are very little if any issues.
        recently did a 2000m tour of Scottish Highland and Lake district, without a hitch, all pre planned routes worked as they should, i also had to use the in app route planner due to road closure and this also worked superbly, and this was only in beta stage at that point.
        K1600 GTL
        Oukitel RT3
        • Mike wiruth Mike wiruth
          @Marinus-van-Deudekom I deleted Garmin Explore from my phone. I then went to my navigator and am in the process of wirelessly sending the file to my xp via Garmin Drive. It takes forever. This is a simple route that I created to test it. Seems to be hung up.
          @Mike-wiruth The transfer from Garmin Drive to the XT should be almost instant.
            @Mzokk Great information, can you post the link for the Garmin forum that you use? I got the XT because my other garmin kept changing my custom route if I took a wrong turn or stopped for gas. Very frustrating. I'm excited about making custom routes in MRA. I just have to get it all figured out on the best method to import it to my XT. Right now I just plug in my xt and drop the file into the gpx folder. Garmin explore doesn't seem to work with the xp. It says that the xt in not a supported device. I have some confusion on what file type to download is as. 1.1 gpx route, track, poi????? And when I open it on the XT if I need to open it in the trip planner or track or what. Can you help with that explaining the method you use? Thanks very much for taking the time to reply and thanks in advance for any help you can give me.
            @Mike-wiruth the method I use to transfer routes and navigate using the XT are as follows.
            I usually plot my routes on the computer screen (unless I'm on tour) as its easier to work with a 27" screen that a phone. I transfer my routes from the phone to the XT via the App. 5cc3c46a-de36-4866-9b06-452417a41cee-image.png
            This is not an ideal route but will illustrate some issues that can arise with the XT
            I download using GPX1.1 because this shows how you shaped the route using MRA and allows you to fix a route that does not go where you want on the XT. I also download the track of the route which will be as planned in MRA.
            Route Received
            Track Received
            Open Trip planner route will be in list.
            Track is in list.
            Open Route (Address near my house removed)
            Open Track Default is blue but I change the colour to yellow.
            Open the route and Track and make the track visible on the XT
            You can see that I wanted to go along the coast but the XT's routing logic is taking me back to a town and then back to the intended route as designed. This can be fixed by putting in an extra shaping point in the XT.
            Or by ensuring there are enough waypoints in the route you designed in MRA.
            I created a bespoke map theme for my XT that makes the Track line thicker and this can be seen below the route line even when navigating. It gives a heads up if the XT is going away from your intended route. I keep recalculate on the unit as "Prompted" and only use recalculate if I can't navigate back to my intended route using the screen.
            paul69 Reinhard-32 Mike wiruth 5 Replies Last reply
            • Mzokk Mzokk
              Route Received
              Track Received
              Track is in list.
              @Mzokk said in help with Garmin Zumo XT:
              Track is in list.
              please correct me if i am wrong, as i have not had an XT for some time now
              but off memory, you would not be able to see the track in the tracks menu if explore was running, hence why i posted the link to thread explaining how to remove explore.
              but I am only guessing from memeory as I do not have an XT, so maybe my input is pointless
              K1600 GTL
              Oukitel RT3
              Mzokk 2 Replies Last reply
              • paul69
                hi,
                the above wording does not make my query clear
                If explore is running and you send track and routes as either 1.2 or 1.1 to the XT using drive app, am i correct in thinking the tracks cannot be seen in the tracks menu.
                yes that makes more sense
                K1600 GTL
                Oukitel RT3
                • Mzokk Mzokk
                  Route Received
                  Track Received
                  Track is in list.
                  Reinhard-32
                  Reinhard-32
                  Reinhard-32
                  @Mzokk I do so in the same manner and it works fine.
                  Kindly regards
                  Reinhard
                  Montana 700i and Mac
                  • Mzokk Mzokk
                    Route Received
                    Track Received
                    Track is in list.
                    i did this too, it was brilliant way to see if the route had gone off somewhere else, instantly noticeable
                    K1600 GTL
                    Oukitel RT3
                    • paul69 paul69
                      Track is in list.
                      wrote on last edited by Mzokk
                      #21
                      @paul69 I don't use explore so the XT reverts to the old Garmin method of displaying a track by ticking it in the menu. The Drive app works fine without explore being installed on your phone or linked to your XT unit.
                      You obviously have to manually untick the track when you have finished using it.
                      • paul69 paul69
                        Track is in list.
                        @paul69 I am thinking of going down the route of using MRA for navigation as well as route planning. Sometimes the testing gets a bit ridiculous.
                        • Mzokk Mzokk
                          @Mzokk
                          K1600 GTL
                          Oukitel RT3
                          • Mzokk Mzokk
                            #24
                            @Mzokk
                            this is what i have been trying to explain to people, you do not get this option with explore activated.
                            replied to this a bit late, but never mind
                            for those looking in, this refers to 3 posts above this one
                            K1600 GTL
                            Oukitel RT3
                            • paul69 paul69
                              hi @Mike-wiruth
                              Mike wiruth
                              Mike wiruth
                              Mike wiruth
                              @paul69 Paul, thanks very much. I went to the link and followed the instructions and got rid of explore on my xt. I also signed up for the zumo forum. This should be a great place to get more zumo related answers. Thanks again for your help.
                              Mike W
                              2013 Honda Goldwing
                              Bushtec Trailer
                              Garmin Zumo XT
                              Nebraska
                              • Mzokk Mzokk
                                Route Received
                                Track Received
                                Track is in list.
                                Mike wiruth
                                Mike wiruth
                                Mike wiruth
                                @Mzokk So how do you display both the track and the route? I checked my xt and went to trip planner and opened up the trip I designed. Then what do you do? Go back and open the track too? When I downloaded it I chose gpx 1.2 route, track, poi
                                Mike W
                                2013 Honda Goldwing
                                Bushtec Trailer
                                Garmin Zumo XT
                                Nebraska
                                • Mzokk Mzokk
                                  Route Received
                                  Track Received
                                  Track is in list.
                                  Mike wiruth
                                  Mike wiruth
                                  Mike wiruth
                                  @Mzokk Also where in settings do you change the color of routes and tracks? Also, how did you get those great screen shots of your xt screen? Thanks for all your hard work of posting this reply. Great work. I was a great help. You might regret it though, I'm a learner, always wanting to learn more and I might burden you with questions. LOL
                                  Mike W
                                  2013 Honda Goldwing
                                  Bushtec Trailer
                                  Garmin Zumo XT
                                  Nebraska
                                    @Mike-wiruth of you got rid of explore in your XT in the settings you can choose to display any track and choose the with and color.
                                    They are display under your route so is you go of route it's instantly visible
                                    Mike wiruth 1 Reply Last reply
                                      Mike wiruth
                                      Mike wiruth
                                      Mike wiruth
                                      @Marinus-van-Deudekom How do you do it? I can't seem to open them both up at the same time. Also, need to know where to go to change the color of the track. Thanks for any help you can give me.
                                      Mike W
                                      2013 Honda Goldwing
                                      Bushtec Trailer
                                      Garmin Zumo XT
                                      Nebraska
                                      Mzokk 1 Reply Last reply
                                        @Mike-wiruth Hi Mike if you go into tracks this is the sequence.
                                        Open Tracks
                                        Click on the spanner to show the track on the map. This stays on until you unclick it even if you are not navigating.
                                        To change colour and width of the track you click on the spanner and scroll to the menu Item
                                        So you can set up the track of the route you intend to run at any time and the track will stay until you untick it.
                                        • Mzokk Mzokk
                                          Open Tracks
                                          Mike wiruth
                                          Mike wiruth
                                          Mike wiruth
                                          @Mzokk Great, thanks for those steps. When you set the properties of the track, to see both at once, do you have to Start the track, then back out and start the route? I looked at the route, and when I first looked at it I could see what looked like the track on the outside of the route, I made the track the widest and color in red. But, when I zoomed in, I couldn't see the track anymore. But, I guess the good news is the track was the same as the route. No deviation.
                                          Mike W
                                          2013 Honda Goldwing
                                          Bushtec Trailer
                                          Garmin Zumo XT
                                          Nebraska
                                          Mike wiruth
                                          Mike wiruth
                                          TomOnTour
                                          TomOnTour
                                          Reinhard-32
                                          Reinhard-32
                                          • Points of interest
                                            Lluís Casals
                                            Lluís Casals
                                            4.1k
                                          • Altitude numbers size
                                            JosepD
                                            JosepD
                                            4.1k
