  4. Remotek-One Exchange of experiences
105 Posts 11 Posters 82.9k Views 8 Watching
    @Hubert-Thoring I really understand that the issue you are having is annoying, yet the amount of posts you dedicate to this, is getting slightly irritating 😉
    Anyhow, I did the following tests with the Remotek controller I have here.
    As always, please refer to the manual of the device itself: https://www.remotek.no/manual
    As stated there, multiple profiles are available. Ensure the map profile is selected.
    1 Map profile – to get there do SCH1 Arrow Up (1 green blink, alternates with roadbook)
    If you have issues with the device, you can switch between Android and iOS mode as they send different keycodes. You do this by holding arrows up and down for about one second.
    To switch between Android and iOS mode (in case the zoom buttons and relocate function behaves strange), hold buttons Arrow Up and Arrow Down for about one second, until it blinks red-green for iOS and green for Android. Repeat to switch back.
    Now that I have the device setup in map profile and in Android mode (yes indeed, Android mode even on iOS. I selected this because otherwise things worked strange).
    Arrow up, down, left & right do as expected.
    Zoom as expected.
    DC left = c/l, center / switch camera mode (works)
    DC up = k, open menu (works) --- close again with zoom out, confirm with zoom in
    DC right = m, start navigation / skip waypoint (works)
    DC down = n, toggle the ETA (works)
    No crashes or whatsoever 🙂
    The only real issue this controller has is that a single click on a pan button is registered as 3 clicks, you'll see this in the menu.
    @Corjan-Meijerink:
    Hey Corjan, thanks, yes I know all the settings, I've done everything described in the manual for iOS, for example also under iOS accessibility "arrow keys delete" so that the map panning works at all, and then tested everything back and forth, also as an Android keyboard, but then no +/- zooming works.
    No matter what I test, the app crashes outside of navigation. I use my Remotek-One so that I can +/- zoom as an iOS keyboard and under MRA input I had to choose standard.
    Which setting did you choose in the MAR under settings:
    • Standard?
    or
    • Remotek-One?
    What is the difference in the MRA anyway, and what can be seen differently there?
    From what you describe, thanks again for the test, it could really be due to the device version, mine is much newer (RT-One 286) and yours, as you already wrote to me, is (RT-One 131) so a lot older.
    I will report this to Dag Jenssen and see what he says.
    Best regards
      @Corjan-Meijerink:
      • Standard?
      or
      • Remotek-One?
      Best regards
      @Hubert-Thoring said in Remotek-One Exchange of experiences:
      Standard?
      or
      Remotek-One?
      The last one as that is the device we are using 😉
        Standard?
        or
        Remotek-One?
        @Corjan-Meijerink: Thank you 🙏 this will help us to narrow down the error.
          Hier zwei Videos, zur Anwendung in der Navigation und dem noch zu klärenden Absturz der App außerhalb der Navigation.
          In der Navigation macht es echt Laune, ich nutze es z.Z. in der Einstellung iOS da geht das „-/* Zoomen“ dafür kein Zentrieren und die MRA speziellen Funktionen nicht, aber Klärungen laufen.
          Es scheint ein Gerätetyp Fehler zu sein, Update soll bald kommen …
          Hardware/Software:
          iPhone Xr in iOS 17.5.1
          Remotek-One im Android Mode (Video)
          Video 1
          Anwendung in der Navigation Beispielhaft für iOS Handy Klick hier …
          Video 2
          Beispiel Absturz Außerhalb der Navigation Klick hier …
            Hardware/Software:
            Video 1
            Video 2
            As expected 🙂
            • Hubert Thoring Hubert Thoring referenced this topic on
              As expected 🙂
              @Corjan-Meijerink Hey Corjan, das habe ich heute zufällig beim weiteren testen festgestellt,..
              MRA mit iOS und mit meiner Remotek One (286)
              • Schalte ich unter iOS unter Bedienungshilfen die Tastaturhilfen „Aus“ dann gibt es keinen MRA Absturz mehr. 😎
              Es scheint eine Kollision zu entstehen unter iOS wenn man im allgemeinen MRA Menü ist, und die Tastaturhilfen „Ein“ geschaltet ist.
              • mit Tastaturhilfe „Aus“ geht es jetzt mit der Remotek One so wie ich es brauche, da ohne Absturz. Im Eingabemodus Remotek One oder Standart, fehlt mir zur Zeit noch das Zentrieren aber das macht die MRA ja nach kurzer Zeit auch selbst, wenn man keine Eingabe mehr macht.
              @Corjan-Meijerink :
              • wie war das bei deinem Test mit deiner Tastatur, war die Tastaturhilfe eingeschaltet ?
              • Könnte der Absturz vielleicht doch auch noch ein Thema bei iOS und der MRA in diesem aufgezeigten Fall sein ?
              Hinweis:
              Da Dag im Urlaub ist werde ich im das auch noch einmal per Mail mitteilen.
              Corjan Meijerink Hubert Thoring 2 Replies Last reply
                @Corjan-Meijerink :
                Hinweis:
                @Hubert-Thoring I am sorry, my experiences remain the same.
                No crashes ever 🙂
                  No crashes ever 🙂
                  @Corjan-Meijerink : Danke
                  Lynchy67 1 Reply Last reply
                    @Hubert-Thoring
                    Wow! are your issues still not resolved.
                    If I remember correctly you had an issue with the Remotek One not working using the Remotek One Input within MRA.
                    I believe that you had to use the Standard Import Setting instead!
                    That right there seems like a defect to me.
                    You should insist they send you another Unit.
                    • Lynchy67 Lynchy67
                      @Hubert-Thoring
                      @Lynchy67 : Ich bin dran, Dag hat Urlaub, wollte mir zuvor aber noch ein Update schicken ... also abwarten.
                        @Hubert-Thoring
                          No crashes ever 🙂
                          @Corjan-Meijerink : Hello Corjan, Sorry, that's what Dag is writing now, it's a shame that he probably won't be able to contact you by email.
                          Is that possible?
                          Here is the email copy from today:
                          Hi Hubert
                          Sorry for the delayed feedback, but I have been a lot off grid for a long time and at the same time had a lot of work to do.
                          Anyway, my feedback is this:
                          The crash. This is and will always be a MRA issue. Nothing I can do about it. It crashes in iOS here too with the latest release. If MRA can´t handle an external controller which every other app with external control handles well (not a single crash in Guru Maps, Osmand and others), then they must do something about it. However, they don´t respond to my emails, and very few users use MRA. I bet they will solve it one day though.
                          So I recommend for now to switch to for example Guru Maps, an excellent map software with all functions on the remote available.
                          Kind regards
                          Dag
                          Dag Jenssen - Remotek AS
                          dag@remotek.no
                          Tlf +47 995 47 284
                          www.remotek.no
                          Wireless controllers for iOs and Android
                            @Corjan-Meijerink :
                            Hinweis:
                            @Corjan-Meijerink :
                            Hinweis:
                            @Corjan-Meijerink : Gibt es hier zu dem was Dag schreibt einen möglichen Zusammenhang, denn meine Remotek One geht mit allen anderen Apps auch bei mir ohne Absturz, auch wenn die Bedienungshilfe, hier dann die Tastatursteuerung "EIN" geschaltet ist. Es ist irgendwo der Fehler aber ? Bitte sprecht doch mal mit Dag darüber. VG
                              Nice how nobody wants it to be their issue.
                              Fun fact, I've never received an email from him or a support ticket.
                              Not sure how (or even if) he contacts us 😉
                              I have the Remotek device, use iOS and have no crashes.
                              Other bluetooth controllers do not crash the app 🙂
                              There is something wrong but he doesn't seem to collaborative about it.
                              Might be us, might be the device.
                              I suspect the latter, he the first 😉
                              Hubert Thoring Lynchy67 2 Replies Last reply
                                @Corjan-Meijerink : ich sitze da wohl zwischen zwei Stühlen 😥
                                  And just for further clarification I have no issues with the Remotek One on Android.
                                  • Lynchy67 Lynchy67
                                    @Lynchy67 : Which No. Xxx does your Android BT Remotek One xxx have.
                                    When pairing, the number is displayed.
                                    • Lynchy67 Lynchy67
                                      @Lynchy67
                                      Hiermit s. Bild, geht es jetzt bei mir aktuelle ohne MRA Absturz, mehr brauche ich nicht, dann in der sauberen iOS gesamten MRA Anwendung.
                                      BT Kopplung:
                                      • Remotek One und MRA
                                      • In der MRA Einstellung Eingabe Standart
                                      • iOS Remotek One Tastatur.
                                      Dabei ist es zwingend notwendig die iOS Bedienungshilfe / Tastatursteuerung auf „AUS“ zu stellen.
                                      Dann geht es in MRA fehlerfrei bei der Navigation oder auf bei den normalen Karten sehr gut.
                                      Funktion:
                                      • Karte rechts, links, oben, unten
                                      • „-/+ Zoomen
                                      Schalte ich im iOS am Handy die Tastatursteuerung EIN, dann geht einiges mehr, aber nur innerhalb der MRA Navigation, aber außerhalb der MRA Navigation stürzt die MRA ab.
                                      Andere Apps lassen sich dann auch ohne Absturz damit gut bedienen, dazu muss diese Tastatursteuerung EIN sein.
                                        @Lynchy67
                                        BT Kopplung:
                                        Funktion:
                                        • „-/+ Zoomen
                                        #21
                                        Hallo zusammen,
                                        ich hab ja schon länger das Remotek One mit einem iPhone Xr im Einsatz, dieses immer noch mit der Version 1.x.x.
                                        Mit der neuen MRA Version ab V4.3.6 geht es jetzt sehr gut, auch das WP überspringen geht jetzt mit meiner Lösung.
                                        Wichtig: Unter Einstellungen am iPhone !!
                                        • Unter : Bedienhilfen \ Tastaturen & Texteingabe \ die Tastatursteuerung auf "Aus" zu stellen. Ich habe sonst das Problem das die MRA außerhalb der Navigation abstürzt. Mit der aber hier gewählten Einstellung auf "Aus" geht es immer sehr gut.
                                        Bei der MRA Eingabeeinstellung, dann als Remotek One geht folgendes sehr gut, dabei ist aber darauf zu achten das die BT Remotek One Tastatur auf iOS steht heißt, die zwei Pfeiltaste oben unten zusammen drücken und warten ob es kurz rot, grün für iOS blinkt, bei grün, grün muss man es noch einmal wiederholen dann kommt das kurz rot, grün blinken. "rot, grün steht für BT Taste als iOS" denn "grün, grün steht für BT Taste als Android.
                                        Ergebnis bei meiner Anwendung in der MRA Navigation unter iOS:
                                        • Pfeile "links, rechts, oben, unter," über die Karte schwenken.
                                        • Pfeil "+" / "-" entspricht dem Zoomen
                                        • Pfeil DC rechts, zwei mal kurz klick dann loslassen, = WP überspringen.
                                        • und weitere Funktionen die beschreibe ich aber separat....
                                        Wichtig sind die richtig gewählten Grundeinstellungen, wenn das oben beschriebene nicht gehen sollte muss die BT Tastatur einmal resettet werden indem man "Pfeil oben, und + und - " gleichzeitig für mehr als 5sek. drückt, bis es rot blinkt. Danach auch die Kopplung unter BT im iPhone löschen und neu am iPhone koppeln. Danach dann wie oben beschrieben für iOS einstellen usw.
                                        Viel Erfolg, ich bin für meine iOS Lösung damit sehr zufrieden.
                                        VG aus Münster
                                          Hallo zusammen,
                                          VG aus Münster
                                          @Corjan-Meijerink : Diese Funktionen s. Datei im Anhang, kann ich seit der MRA V 4.3.6 nutzen. So bin ich mehr als begeistert.
                                          • 4
                                          • 5
                                          • 6
                                          martin-phogel.de
                                          martin-phogel.de
                                          silberfuchs67
                                          silberfuchs67
                                          Huibertus
                                          Huibertus
                                          ConiKost
                                          ConiKost
                                          Westerwald_Rider
                                          Westerwald_Rider
                                          • F014 WP Numbering illogical
                                          • Map colours and side roads
                                          • GPX POI Editor
                                            RainerT
                                            RainerT
                                          • F013 Facilities/POIs – A search function covering the entire map is unfortunately missing here.
                                          • Route MRA importeren in Google Maps
                                          • OSM Routing with MRA
                                          • F016 Colors only change after leaving the planning
